I wrote a simple plugin that was meant only as a template, this was intended to scan audio.
class TestAgent(Agent.Album):
name = 'Test Agent'
languages = [
Locale.Language.English,
primary_provider = True
fallback_agent = False
accepts_from = None
contributes_to = None
def search(self, results, media, lang, manual):
f = open('search', 'w')
f.write('Self:' + '\n')
f.write(str(self) + '\n\n\n')
f.write('Results:' + '\n')
f.write(str(results) + '\n\n\n')
f.write('Media:' + '\n')
f.write(str(media) + '\n\n\n')
f.write('Lang:' + '\n')
f.write(str(lang) + '\n\n\n')
f.write('Manual:' + '\n')
f.write(str(manual) + '\n\n\n')
f.close()
def update(self, metadata, media, lang, force):
I created the relevant files in the Plug-ins directory.
Info.plist:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<!-- Version should always be set to 2 -->
<key>PlexFrameworkVersion</key>
<string>2</string>
<key>CFBundleIdentifier</key>
<string>com.plexapp.agents.testagent</string>
<!-- This one does nothing with a value of Always On, but using a value of "daemon" keeps the plugin alive in the background -->
<key>PlexPluginMode</key>
<string>Agent</string>
<!-- List any client platforms supported in the plugin. -->
<!-- Possible values are * for all platforms, MacOSX, Windows, Linux, Roku, Android, iOS, Safari, Firefox, Chrome, LGTV, Samsung, PlexConnect and Plex Home Theater -->
<key>PlexClientPlatforms</key>
<string>*</string>
<!-- List any client platforms not supported in the plugin. -->
<key>PlexClientPlatformExclusions</key>
<string></string>
<!-- possible string values are the proper ISO two letter code for the country -->
<!-- A full list of values are available at http://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 -->
<key>PlexPluginRegions</key>
<array><string></string>
</array>
<!-- DEBUG OPTIONAL KEYS -->
<!-- possible values are 0 and 1. Setting it to "1" rather than "0" turns on debug logging -->
<key>PlexPluginDebug</key>
<array><string>1</string>
</array>
<!-- THESE BELOW ARE FOR AGENTS ONLY -->
<!-- this allows channels to access some python methods which are otherwise blocked, as well as import external code libraries, and interact with the PMS HTTP API -->
<key>PlexPluginCodePolicy</key>
<string>Elevated</string>
<!-- This key is used to show that the plugin is an agent. possible values are agent -->
<key>PlexPluginClass</key>
<string>agent</string>
<!-- This is used to send plugin log statements directly to stout when running PMS from the command line. Rarely used anymore-->
<key>PlexPluginConsoleLogging</key>
<string>0</string>
<key>PlexAgentAttributionText</key>
<string>Prints out data.</string>
</dict>
</plist>
DefaultPrefs.json:
My directory structure:
├── TestAgent.bundle
│ └── Contents
│ ├── Code
│ │ └── __init__.py
│ ├── DefaultPrefs.json
│ └── Info.plist
When loading this agent however it never shows up under my agents list.
Does anyone know what I’m doing wrong?
EDIT:
After running for 5-10 minutes this error seems to show up in the log:
Timeout or error reading status line from plug-in pipe [com.plexapp.agents.testagent], we’re killing it.
