I have noticed a lot of album descriptions and reviews on PlexAmp are in some other language, like spanish of portuguese. I only use English. Why is this happening? and can I fix it?
Plexamp shows exactly the same data that other Plex clients show of the same library item.
If your Plexamp instance now suddenly shows a different language than your e.g. web app, then this can only mean that
- you are not looking at your own library. Do you use Plexamp to access Tidal? Do you have access to shared servers, which might be using a different language?
- you are looking at a different library. Do you have more than one audio library, of which one might have been set to a different language?
- something on the device where Plexamp has been installed on, is translating everything on the fly to Spanish (unlikely, but theoretically possible). Is Plexamp installed on a mobile device which uses Spanish as it’s default language?
