- unfortunately not. It is always a combination of folder structure and tags now.
- Plex doesn’t store Genre per track, yet. However, it supports a ‘Style’ per track from allmusic.com. Genre per track is still not ready.
- Don’t use it. It slows down scanning considerably.
- I think it simply uses the first one. Or it might be using the one which is tagged as ‘Front’.
Anyway, I don’t recommend to embed lots of artwork into your files. Just get a really high resolution version of the front cover and place that as a file namedcover.jpginto your album folder.
That was fast! ![]()
OK, not a big deal at the moment, as I can use “Merge” when I notice it.
Ok - “not ready” implies “it’s on the list”, and I’m fine with that.
OK, it would be nice, but not a big deal. I’ll add that to “wish list”! ![]()
OK, I’m asking because (as I’m sure you’ve noticed), I’m a bit OCD and sometimes I like different album art for different tracks, such as the original covers for different tracks on a compilation.
I like to push the envelope I guess!
Now that I’m really getting a feel for how Plex “thinks”, I’ll just experiment to get the results I’m looking for. I’ll probably post anything interesting I discover, if that’s ok. If I mark your last response as “Solution”, does that lock out further responses?
Thank you so much for all your help!
- Mark
That’s definitely not supported. It is Album Art after all, not Track Art.
