Allow Agents to set Original Title
I’ve posted a thread about it here too but were recommended to post a request about it here.
Next month it’ll have gone at least 10 years since this was first requested, even that thread mentions “still not possible” meaning it’s been longer than that.
Please allow Agents/API to set the Original Title field, since this can already be done for Movie objects. Having personally a massive library of Anime and not having the Agent being able to set the field it can be difficult to find some entries for some users.
Specifically for anime there’s two equally common ways of writing/using titles, Romaji and English. (e.g Attack on Titan or Shingeki no Kyojin)
Setting this field manually for every entry is a very tedious process and it would really increase user QoL having Agents be able to set this.
Please consider this, thank you for reading.
Totally agree with you. TV Shows should be able to set and scrape the Original Title, as sometimes viewers, they would like to search the English original name, even though you set the Title to localised name, in my case, Vietnamese.
I wonder if this is an issue with the legacy agents. I’ve just tested this on my server which is using the Plex TV Series agent. From what I’ve seen, I can find shows by their original titles just fine.
Well, in my case, I use XBMCnfoTVImporter for customised NFO files. It works with Movies, but not the TV Shows. I just wonder why?
And this might be useful: Original Title does not work · Issue #91 · gboudreau/XBMCnfoTVImporter.bundle · GitHub
If you will ask me why not Plex Agent, my answer is to keep every metadata along with the media files, instead of saving those inside Plex. I had Plex crashed 2 times, got freshly re-installation and lost all metadata. So the next time if anything goes wrong with Plex, simply format the OS, re-install PMS, scan the media fiels, and bump!.. They’re all there. :slight_smile:
New Plex agent is good but I still use Hama Agent and Absolute Series Scanner for my Anime library, in which it can’t set the Original title field and haven’t been able to for at least 10-11 years now, unfortunately.
We need people with plex pass to vote for feature to change things. other ways are useless. Glad you like HAMA agent
