It is still in beta so if you do decide to use it would be greatly appreciated if you could leave me some feedback on this post so I can make improvements!
Says it’s a TV Series renamer, any plans for movie rename?
Like @isaacrdz said you should be able to run it on mac since it runs on java as long as you have java installed on your system, which most people do
When it comes to movie renaming, I was thinking about adding that if the app becomes at least a bit popular, or if at least a few people use it. You can stay tuned on the blog to find out about any developments.
Does the program uses TVDB or something?
I’m trying to rename The Woody Woodpecker Show, the files are just like The Woody Woodpecker Show - 01, but nothing happens, just a msg on the main window saying RENAMING: The Woody Woodpecker Show - 01.avi .
Also, I know the program’s name is PlexFileRenamer, but does it also move/organize stuff to folders or it just rename?
I have no issues renaming stuff myself, but I was looking for some scraper/organizer and found your program. To me, the PITA is to manually seek seasons for shows like this, which has tons of seasons like Season 1940, Season 1941 and so on.
