Hi Guys
Is there anyway to get Amazon Drive to sync my files to the cloud using Cloud Sync?
Stuck on waiting to upload?
Did you add Amazon Drive to your list of cloud providers? You can add it from your Account Settings.
https://plex.tv/cloudsync/provider
Once added, Plex should sync to it no problem.
Write back if you are still having troubles.
Hi dericdd
Yes what I have done. Is made sure its my only provider.
If i sign into my amazon drive, the plex sync folder is created but my sync media just sits at waiting to be uploaded.
What a coincidence
It is a common problem with Amazon since 1 month.
