Amazon Drive upload speeds
Plex Gods,
I have been using Amazon Drive for months now as a means to backup my collections. I am super excited about the Plex Cloud, it is a dream come true… Kind of. I signed up for the beta as soon as i saw it was open. I have a 50Mbps upload speed and 100 down. I have been trying for Months to upload my collection and i still do not have it all up there on Amazon Drive. The absolute best speed i have been able to manage is 600k up! My first question is this; Are any of you seeing the same upload speeds to Amazon Drive that i am seeing? My second question is: Have you taken this slow upload into consideration? It is a absolutely fantastic Idea to have Amazon Host our backups, and i have been trying to make that work for years now. But, i don’t see it as a viable solution for those of us that have more than a few HD movies. Would love to hear what others upload speeds have been to Amazon Drive and if anyone was able to work around the slow uploads. I have an 2012 iMac running Yosemite. Thanks for being so Awesome!!!
I get a consistent 16Mbps transfer rate uploading ACD.
In Spain with a synology NAS I upload at 35 mbps…300/300 ffth
Where are you located? What are you using to upload? I’m in New Zealand with a 200/200 fibre connection and here’s what I’m currently getting with rclone:
Transferred:   982.685 GBytes (6.054 MBytes/s)
Errors:                 0
Checks:                24
Transferred:          782
Elapsed time:  46h10m3.2s
I usually get around 2.3MB/s which pretty much maxes my connections upload speed.
Im located in Ohio, USA. I am on Comcast. I wonder what is slowing me down???
Maybe my issue is I’m using Amazon’s uploader?
I would look at other tools like rclone.org
@hthighway thanks for pointing me to rclone recently. It works really well.
I get 16-18mbps upstream. Downstream from ACD I think my max sustained is about 68mbps or so.
My connection is 200mbps/20mbps down/up respectively.
It’s hard to beat how easy rclone is and the speed at which it works.
Setting up rclone now!! Thanks for the tips
I get 1.5 up with rclone??? At least that is double what i was getting.
Just as an FYI, my guess is you’re looking at about a 5M upload speed. The thing of it is, they’re talking about bits, not bytes. Your rates are just gonna suck. I’ve got the same issue with Time Warner.
Go to http://speedof.me/ and verify you are actually getting the speeds you are signed up for. You should be able to max out your connection.
Any suggestion on how to setup uploading when media is on external drive? I haven’t tried with amazon yet but Dropbox puts a folder on internal hard drive
speedof.me speedtest is 95.91 down and 12.9 up. So i should be getting at least 4 or 5 up right? Im guessing i have a bottleneck somewhere on my system.
I just created a folder in all of my external drives and moved the media to those folders to facilitate the uploads to Amazon. I can always move the media back to the root of the drive after the upload is completed.
I hit between 160-230mbps upload to Amazon from a gigabit fiber home connection using rclone. Maxed out ~ 100mbps using the ACD branded app.
In Spain Movistar 300/300 FTTH 35MB/s.
It is definitely an issue with my Home computer!! I tried to upload a few movies from my work account (500up and 500down) and I am getting 60MB/S up! I will try uploading using a different (more powerful computer) tonight and see if that makes a difference. hopefully that will help me determine if it is the computer or the internet provider.
