I’m not in need of a lot of streams but I want the best picture so I’d like my AMD 5950x to handle the transcoding. Switched off HW and it tells me it isn’t “powerful” enough?
What am I missing?
What am I missing?
Are you perhaps transcoding video and burning subtitles (and transcoding audio)? A screenshot of the dashboard (with details expanded) will show what’s being transcoded to what. Some transcoding operations are single-threaded (I can’t remember which off the top of my head) and will not benefit from the extra cores.
Why did you switch off hardware transcoding?
Please state the technical makeup of the source file. Plex media info XML
I have an Asus AMD 6800XT LC GPU which isn’t ideal for transcoding HVEC so I want the CPU to handle that since it’s a 5850x 16/32 processor. Better quality.
since we’re getting the usual level of support here I bought a PNY P2000 to handle the HEVC files…
