Analyze not doing anything
As the title says. I keep hitting analyze on a season, show, library and it does absolutely nothing. Doesn’t detect intros like I’m hoping for.
You must do it on a single episode.
Yeah, I’d just tried to re-trigger analysis on a show that I know had bad intro markers (due to a replacement in a bad file). Nothing happened when I hit analyze on the show level, which surprised me.
So yeah, select each episode. In a browser, you can click an “invisible button” that appears when you mouse over it next to the episode count on a season. This lets you select all episodes at once. Then on the orange-bordered menu that appears along the top, click ... > Analyze and it should do the trick:
Figured out where my issue was. Even though the intro detection is set to on in the main settings, it’s also a setting in the TV shows section itself and mine was off for both intro and credits. I also took the advice and analyzed by selecting episodes and it worked.
