Android 16 Plex crashes on open
Server Version#: n/a
Player Version#: 2025.25.0
My Plex android app crashes when opening.
Running android 16, been happening since updated
Have uninstalled app, cleared app data and cache etc, does not help and best I can do is watch content on the website …
Can’t give you any logs because I can’t get them. Happy to send a video demonstrating.
The Plex arrow starts swiping but then app crashes. It gets to ask me if I want notifications although it doesn’t matter what I select as the app closes immediately.
Phone make / model? So others can try to replicate.
On pixel 8 pro, android 16 build BP3A.250905.014
Details if relevant
Timezone Europe/London
Have doh DNS
No VPN
Attached display size in case that’s relevant
Happy to help with any other system oddities. Have animation transition time to .5x also..
Video demonstrating the issue
Thanks for the info. It will help Plex troubleshoot.
Just to give you an example of how things can vary, I’ve a Pixel 6a, Android 16 and the app works OK. There have been other differences between the Pixels. Some models play EAC3 audio and on some there is just silence.
I am having the same issue on my Wife’s phone after setting her up on a Pixel 8 from a Pixel 6. I used the Android switch option to restore the Pixel 8 from the Pixel 6. The Plex app will just open for half a second and then close. If I clear cache\data, I get the permisisons prompt for notifications, but then crashes.
I have a Pixel 8 and the app works fine.
Using the latest version from the Play Store and on the latest Android version.
Hi, I gathered some adb logs
adb-plex.log (119.4 KB)
If you want more info please let me know what. This is from adb logcat | grep plex
I plugged in the phone, started logcat and opened Plex a few times.
On the third open it asked me for Notification permissions, then crashed. Dialog stayed and i allowed. Restarted again, crashed.
I can confirm it. Pixel 9 pro xl, BP3A.250905.014
I’ve get the new phone. After the restoring the backup it didn’t work, I’ve already tried to delete the app and install it one more time, but it didn’t help
P.S By the Beta is the same
Have the same issue on a Pixel Tablet running Android 16. Bought it brand new, didn’t migrate anything to it. Plex app crashes right on a start. Tried everything I could think of, nothing works for the latest versions. Only thing that works in installing an older APK, specifically APKs that use the old version naming standard, e.g. 10.26.0.2578. Any of the APKs that have years in them do not work, e.g. 2025.26.0.
I am having the same issue with a new Google Pixel Tablet running Android 16. I am running Plex version 2025.27.0. The error that I get after trying to open Plex a few times is “Plex keeps stopping”.
Any updates?
I have the same problem. The application crashes immediately on launch. It does not work on Google Pixel 9 (Android 16). I must say that this is not the only application that has operational problems on this version of Android. I believe that the problems are caused by a change in the permissions to the phone’s memory. So far, I know of these applications that are negatively affected (not working) by this version of Android. Plex / OneSnyc / Audiobookshelf / Folder Widget.
Has anyone made any progress?
Hey so this is still an issue lol. Pixel 7 on Android 16, just installed Plex and created a new account for use with the family and it still closes instantly. Don’t even get a permissions prompt.
Tried cache clear etc, and even messed with power settings and default stuff to see if it would improve.
At Christmas I finally solved this problem after a month. My wife got an identical phone for Christmas where all the applications showing the problem worked. The problematic and affected applications were (KODI, PLEX, DJI MIMO, FOLDER WITGET, ONESNYC, AUDIOBOOKSHELF). I found out that after upgrading from the default firmware, the symlink to the main memory of the phone was incorrectly created. This can happen with previously manufactured phones. There is no such jump in versions with newer phones. The problem was completely solved after upgrading to version 16 by performing a restart to factory settings. This was identified by the fact that the storage/xxxx-xxxx directory was located in the root of the memory. The OneSync application did not work and reported that it did not have access to the memory /storage/emulated/0. I hope this helps and helps someone.
