Android (mobile and TV) Direct Play issues
Server Version#: 4.108.0
Player Version#: 10.0.0.4149
I have a remote server, with an nginx reverse proxy. The strangest thing is that my android devices can’t play original quality videos. The issue is not the device/internet since if on a device I use the browser, the playback is fine. This also happens on videos where the original bitrate is lower than transcoded on others.
On the server I just have a mysterious:
DEBUG - Failed to stream media, client probably disconnected after 57566860 bytes: 32 - Broken pipe
I am attaching a log from the Android TV network log below. You can see that I forced a transcode at 23:36:23 and this it worked immediately. This is a similar symptom to my mobile Android as well.
10-01 23:35:11.591 i: [MediaDecisionEngine] Transcode server selected: XXXX
10-01 23:35:11.592 i: [MediaDecisionEngine] Analyzing media: 1280x720 4688kbps (Container: mkv, Video: h264, Audio: eac3)
10-01 23:35:11.595 i: Creating PlayerActivity.
10-01 23:35:11.596 i: [Activity] Resuming the application, attempting to download item and children.
10-01 23:35:11.597 i: [Boot] PlayerActivity took 1ms to run create behaviours.
10-01 23:35:11.629 i: Resuming PlayerActivity.
10-01 23:35:11.652 i: [PlayerActivity] Creating fragment
10-01 23:35:11.655 i: [Player][DimensionsLayout] Resizing: 100 x 100
10-01 23:35:11.659 i: [video] User maximum h264 profile determined: 51
10-01 23:35:11.663 i: [video] Device recommended h264 profile determined: 51
10-01 23:35:11.663 i: [DisplayBehaviour] Activity has been changed, searching for available modes.
10-01 23:35:11.679 i: [DisplayBehaviour] Current Mode ID: 1 / {id=1, width=1920, height=1080, fps=60.000004}
10-01 23:35:11.680 i: [DisplayBehaviour] Current mode detected as 1920x1080 @ 60.0000Hz (1).
10-01 23:35:11.682 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-01 23:35:11.682 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
10-01 23:35:11.870 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-01 23:35:11.874 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-01 23:35:11.896 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-01 23:35:11.908 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:35:11.909 i: [BufferHelper] Segment count: 1171
10-01 23:35:11.910 i: [ChaptersSheetHud] Found 0 chapters.
10-01 23:35:11.932 i: Fetching [method:GET] https://plex.xxxx.xx:443/video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=wan&maxVideoBitrate=200000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F27103&protocol=*&session=f5dcd19d982a56b4-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac_latm%2Caac%2Caac%2Cac3%2Calac%2Cdca%2Cdca%2Cdca%2Ceac3%2Cflac%2Cmp1%2Cmp2%2Cmp3%2Copus%2Cvorbis%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D8%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dopus)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=Smart%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Version=10.0.0.4149&X-Plex-Token=...8jGM&X-Plex-Language=en-us
10-01 23:35:11.934 i: [MenuSheetHud] Item changed (and fetched), invalidating settings…
10-01 23:35:12.029 i: [CurrentItemMetadataBehaviour] Fetched current item, success: true
10-01 23:35:12.030 i: [ChaptersSheetHud] Found 16 chapters.
10-01 23:35:12.031 i: [MenuSheetHud] Item changed (and fetched), invalidating settings…
10-01 23:35:12.072 i: [MediaSessionCallback] Pausing playback.
10-01 23:35:12.087 i: [ExoPlayer][EventLogger] playWhenReady [eventTime=0.70, mediaPos=0.00, window=0, period=0, false, USER_REQUEST]
10-01 23:35:12.090 i: [EngineEventManager] onBufferingStarted (isSeeking: false)
10-01 23:35:12.128 i: [Player][Timeline] Playback started (or buffering), scheduling updates
10-01 23:35:12.131 i: [TranscodeSession] Pausing…
10-01 23:35:12.133 i: [EngineEventManager] onBufferingEnded
10-01 23:35:12.175 i: [Player][View] Layout has been measured with a size of 1920 x 1080 (1920 x 1080).
10-01 23:35:12.176 i: [Player][DimensionsLayout] Resizing: 1920 x 1080
10-01 23:35:12.185 i: [ASS][Renderer] Surface has been created, connecting to renderer.
10-01 23:35:12.186 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=0.80, mediaPos=0.00, window=0, period=0, 1920, 1080]
10-01 23:35:12.207 i: [ASS][Renderer] Attempting to start renderer from setSurface.
10-01 23:35:12.208 w: [ASS][Renderer] Missing video size, can’t start renderer yet.
10-01 23:35:12.252 i: [SystemUIBehaviour] Hiding the system user-interface.
10-01 23:35:12.379 i: [MediaDecisionEngine] Server was happy with client’s original decision
10-01 23:35:12.404 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: true CanDirectStreamVideo: true CanDirectStreamAudio: true CanDirectPlaySubtitle: false CanTranscodeSubtitle: false CanDisplayVideo: true
10-01 23:35:12.419 i: [LoadControl] New bitrate: 4688, Maximum: 4688
10-01 23:35:12.434 i: [MediaDecisionMediaSource] Resetting mappable types.
10-01 23:35:12.533 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:35:12.536 i: [BufferHelper] Segment count: 1171
10-01 23:35:12.546 i: [MediaDecisionMediaSource] Loading from https://plex.xxxx.xx:443/library/parts/42862/1695507351/file.mkv?autoAdjustQuality=0&hasMDE=1&location=wan&mediaBufferSize=74944&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Smart%20TV&X-Plex-DRM=widevine%3Avideo&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:35:12.576 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:35:12.579 i: [BufferHelper] Segment count: 1171
10-01 23:35:12.610 i: [MediaDecisionMediaSource] Loading from https://plex.xxx.xx:443/library/parts/42862/1695507351/file.mkv?autoAdjustQuality=0&hasMDE=1&location=wan&mediaBufferSize=74944&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Smart%20TV&X-Plex-DRM=widevine%3Avideo&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:35:12.620 i: [AudioCapabilitiesHelper] Passthrough is set to auto over HDMI, supported capabilities:
10-01 23:35:12.622 i: [AudioCapabilitiesHelper] - ac3
10-01 23:35:12.636 i: [AudioCapabilitiesHelper] - eac3
10-01 23:35:12.639 i: [AudioCapabilitiesHelper] - dca
10-01 23:35:12.642 i: [AudioCapabilitiesHelper] - dca
10-01 23:35:12.647 i: [AudioCapabilitiesHelper] - dca
10-01 23:35:12.651 i: [MediaDecisionMediaSource] Opening https://plex.xxx.xxx:443/library/parts/42862/1695507351/file.mkv?autoAdjustQuality=0&hasMDE=1&location=wan&mediaBufferSize=74944&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Smart%20TV&X-Plex-DRM=widevine%3Avideo&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:35:12.654 i: [MediaDecisionMediaSource] Using ProgressiveMediaSource with FFmpegExtractor.
10-01 23:35:12.655 i: [MediaDecisionMediaSource] onMediaDecisionRefreshed (Sources: 1)
10-01 23:35:12.686 i: [ExoPlayer][EventLogger] timeline [eventTime=1.30, mediaPos=0.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
10-01 23:35:12.692 i: [ExoPlayer][EventLogger] period [?]
10-01 23:35:12.695 i: [ExoPlayer][EventLogger] window [?, seekable=false, dynamic=false]
10-01 23:35:12.698 i: [ExoPlayer][EventLogger] ]
10-01 23:35:12.702 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 0 ms)
10-01 23:35:12.955 i: [FFmpegExtractor] Initialised with new output.
10-01 23:35:12.960 i: [FFmpeg] [INFO] [CacheSource] Close requested, terminating.
10-01 23:35:12.962 i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
10-01 23:35:12.963 i: [FFmpeg] [INFO] [CacheSource] Closed successfully.
10-01 23:35:12.964 i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
10-01 23:35:12.965 i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been terminated successfully.
10-01 23:35:12.978 i: [FFmpegExtractor] Opening demuxer.
10-01 23:35:12.980 i: [FFmpeg] [INFO] [FFmpegExtractor] Connecting to ExoPlayer with IO cache in-between.
10-01 23:35:12.983 i: [FFmpeg] [INFO] [FFmpegExtractor] Preparing context for demuxing.
10-01 23:35:13.300 i: [FFmpeg] [INFO] [FFmpegExtractor] Requesting IO seek to 0 bytes.
10-01 23:35:13.304 i: [FFmpegExtractor] IO-seek has been requested, target of 0 bytes (whence 65536).
10-01 23:35:13.312 i: [FFmpegExtractor] IO-seek wanted to know the length, returning 4930964204 bytes.
10-01 23:35:13.335 i: [FFmpeg] [INFO] [FFmpegExtractor] IO seek completed to 4930964204 Interrupted: No Closed: No
10-01 23:35:13.340 i: [FFmpeg] [INFO] [CacheSource] Worker thread has been enabled and will start processing data.
10-01 23:35:13.372 i: [FFmpeg] [INFO] [CacheSource] Source seek requested to 4930954476 bytes with 0 whence.
10-01 23:35:13.408 i: [FFmpeg] [INFO] [CacheSource] Seek found to 4930954476 bytes.
10-01 23:35:13.409 i: [FFmpeg] [INFO] [FFmpegExtractor] Requesting IO seek to 4930954476 bytes.
10-01 23:35:13.439 i: [FFmpegExtractor] IO-seek has been requested, target of 4930954476 bytes (whence 0).
10-01 23:35:13.443 i: [FFmpegExtractor] IO seek request to 4930954476 bytes, current position 29331 bytes.
10-01 23:35:14.375 i: [HttpServer] /192.168.1.153:53272 - GET /logging
10-01 23:35:24.155 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:35:24.488 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:35:53.018 i: [HttpServer] /192.168.1.153:53281 - GET /logging
10-01 23:35:53.575 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:35:53.872 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:36:05.927 i: [InteractionBehaviour] Woke up, reason: Interface visibility has been toggled…
10-01 23:36:05.961 i: [SystemUIBehaviour] Showing the system user-interface.
10-01 23:36:09.108 i: [BottomSheet] onSheetExpanding
10-01 23:36:09.292 i: [BottomSheet] onSheetExpanded
10-01 23:36:17.492 i: [HttpServer] /192.168.1.153:53283 - GET /logging
10-01 23:36:23.576 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:36:23.636 i: [VideoQualityBehaviour] Quality has been updated to Convert to 720p HD (Medium).
10-01 23:36:23.644 i: [VideoQualityBehaviour] Playback restarting due to quality change.
10-01 23:36:23.650 i: [EngineEventManager] onPlaybackRestart: quality
10-01 23:36:23.728 i: [TranscodeSession] Stopping…
10-01 23:36:23.736 i: [TranscodeSession] Session already stopped.
10-01 23:36:23.769 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=72.39, mediaPos=0.00, window=0, period=0, 0, 0]
10-01 23:36:23.781 i: [Player][ExoPlayer] Setting given surfaceView
10-01 23:36:23.786 i: [ASS][Renderer] Surface has been destroyed, disconnecting.
10-01 23:36:23.789 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
10-01 23:36:23.794 i: [Player][DimensionsLayout] Resizing: 1920 x 1080
10-01 23:36:23.803 i: [DisplayBehaviour] New ExoPlayerEngine detected, enabling: false.
10-01 23:36:23.809 i: [Player][ExoPlayer] Using PlayQueueMediaSource
10-01 23:36:23.815 i: [ExoPlayerEngine] Media source has been created.
10-01 23:36:23.817 i: [MediaCodecVideoSyncRenderer] Setting allow dummy surface: false
10-01 23:36:23.822 i: [ASS][Renderer] Surface has been created, connecting to renderer.
10-01 23:36:23.836 i: [ExoPlayer][EventLogger] state [eventTime=72.45, mediaPos=0.00, window=0, period=0, IDLE]
10-01 23:36:23.850 i: [BottomSheet] onSheetHiding
10-01 23:36:23.851 i: [ExoPlayer][EventLogger] timeline [eventTime=72.47, mediaPos=0.00, window=0, periodCount=0, windowCount=0, reason=PLAYLIST_CHANGED
10-01 23:36:23.852 i: [ExoPlayer][EventLogger] ]
10-01 23:36:23.853 i: [FFmpegExtractor] Interrupting extractor for release.
10-01 23:36:23.853 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 0 ms)
10-01 23:36:23.854 i: [FFmpeg] [INFO] [FFmpegExtractor] IO seek completed to -1 Interrupted: Yes Closed: No
10-01 23:36:23.854 i: [FFmpeg] [INFO] [FFmpegExtractor] IO-seeking whilst interrupted, exiting.
10-01 23:36:23.855 i: [FFmpeg] [INFO] [FFmpegExtractor] Pre-Reading whilst closed, exiting.
10-01 23:36:23.855 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-01 23:36:23.856 i: [FFmpeg] [INFO] [CacheSource] Seek has returned with a response of -1414092869.
10-01 23:36:23.859 i: [FFmpeg] [WARN] [CacheSource] Encountered result whilst reading from source at 29331 bytes: Immediate exit requested (-1414092869).
10-01 23:36:23.862 i: [FFmpeg] [WARN] [CacheSource] Source or buffer is still interrupted.
10-01 23:36:23.863 i: [FFmpeg] [INFO] [CacheSource] Thread has been terminated.
10-01 23:36:23.864 i: [ExoPlayer][EventLogger] positionDiscontinuity [eventTime=72.47, mediaPos=0.00, window=0, reason=REMOVE, PositionInfo:old [mediaItem=0, period=0, pos=0], PositionInfo:new [mediaItem=0, period=-1, pos=0]]
10-01 23:36:23.865 i: [Player][ExoPlayer] onPositionDiscontinuity, Reason: 4
10-01 23:36:23.865 i: [ExoPlayer][EventLogger] mediaItem [eventTime=72.48, mediaPos=0.00, window=0, reason=PLAYLIST_CHANGED]
10-01 23:36:23.866 i: [ExoPlayer][EventLogger] playWhenReady [eventTime=72.48, mediaPos=0.00, window=0, true, USER_REQUEST]
10-01 23:36:23.867 i: [ExoPlayer][EventLogger] timeline [eventTime=72.49, mediaPos=0.00, window=0, periodCount=1, windowCount=1, reason=PLAYLIST_CHANGED
10-01 23:36:23.868 i: [ExoPlayer][EventLogger] period [?]
10-01 23:36:23.869 i: [ExoPlayer][EventLogger] window [?, seekable=false, dynamic=true]
10-01 23:36:23.869 i: [ExoPlayer][EventLogger] ]
10-01 23:36:23.869 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 0 ms)
10-01 23:36:23.870 i: [ExoPlayer][EventLogger] mediaItem [eventTime=72.49, mediaPos=0.00, window=0, reason=PLAYLIST_CHANGED]
10-01 23:36:23.872 i: [ExoPlayer][EventLogger] state [eventTime=72.49, mediaPos=0.00, window=0, BUFFERING]
10-01 23:36:23.895 i: [FFmpegExtractor] Demuxer context has been opened.
10-01 23:36:23.898 i: [FFmpeg] [INFO] [FFmpegExtractor] Successfully opened demuxer.
10-01 23:36:23.899 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-01 23:36:23.900 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=72.49, mediaPos=0.00, window=0, period=0, 1920, 1080]
10-01 23:36:23.902 i: [FFmpeg] [INFO] [FFmpegExtractor] Closing demuxer context.
10-01 23:36:23.911 i: [ASS][Renderer] Attempting to start renderer from setSurface.
10-01 23:36:23.912 w: [ASS][Renderer] Missing surface, can’t start renderer yet.
10-01 23:36:23.913 i: [FFmpeg] [INFO] [CacheSource] Close requested, terminating.
10-01 23:36:23.914 i: [FFmpeg] [INFO] [CacheSource] Terminating thread.
10-01 23:36:23.915 i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
10-01 23:36:23.916 i: [FFmpegExtractor] Extractor has been released.
10-01 23:36:23.916 i: [FFmpeg] [INFO] [CacheSource] Closed successfully.
10-01 23:36:23.916 i: [ASS][Renderer] Attempting to start renderer from setSurface.
10-01 23:36:23.917 w: [ASS][Renderer] Missing video size, can’t start renderer yet.
10-01 23:36:23.917 w: [MetricsSender] Error posting metrics. Response error code: 400
10-01 23:36:23.917 i: [MediaDecisionEngine] Starting media decision for: XXXXXXXXXXX (part index 0)
10-01 23:36:23.918 i: [MediaDecisionEngine] Transcode server selected: XXX
10-01 23:36:23.918 i: [MediaDecisionEngine] Analyzing media: 1280x720 4688kbps (Container: mkv, Video: h264, Audio: eac3)
10-01 23:36:23.935 i: [MediaDecisionEngine] Bitrate 4688 exceeds maximum allowed (3000)
10-01 23:36:23.949 i: [video] User maximum h264 profile determined: 51
10-01 23:36:23.950 i: [video] Device recommended h264 profile determined: 51
10-01 23:36:24.043 i: [BottomSheet] onSheetHidden
10-01 23:36:24.187 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:36:24.188 i: [BufferHelper] Segment count: 1171
10-01 23:36:24.199 i: Fetching [method:GET] https://plex.xxx.xx:443/video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F27103&protocol=*&session=f5dcd19d982a56b4-com-plexapp-android&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=3840x2160&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac_latm%2Caac%2Caac%2Cac3%2Calac%2Cdca%2Cdca%2Cdca%2Ceac3%2Cflac%2Cmp1%2Cmp2%2Cmp3%2Copus%2Cvorbis%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D8%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dopus)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=Smart%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Version=10.0.0.4149&X-Plex-Token=...8jGM&X-Plex-Language=en-us
10-01 23:36:24.604 i: [MediaDecisionEngine] Server was happy with client’s original decision
10-01 23:36:24.606 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: false CanDirectStreamVideo: false CanDirectStreamAudio: false CanDirectPlaySubtitle: false CanTranscodeSubtitle: false CanDisplayVideo: true Transcode Reason: Resolution or bitrate exceeds maximum allowed
10-01 23:36:24.609 i: [LoadControl] New bitrate: 3000, Maximum: 4688
10-01 23:36:24.610 i: [MediaDecisionMediaSource] Resetting mappable types.
10-01 23:36:24.611 i: [video] User maximum h264 profile determined: 51
10-01 23:36:24.611 i: [video] Device recommended h264 profile determined: 51
10-01 23:36:24.781 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:36:24.782 i: [BufferHelper] Segment count: 1171
10-01 23:36:24.785 i: [MediaDecisionMediaSource] Loading from https://plex.xxx.xx:443/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F27103&protocol=hls&session=f5dcd19d982a56b4-com-plexapp-android&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=3840x2160&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac_latm%2Caac%2Caac%2Cac3%2Calac%2Cdca%2Cdca%2Cdca%2Ceac3%2Cflac%2Cmp1%2Cmp2%2Cmp3%2Copus%2Cvorbis%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D8%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dopus)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=Smart%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:36:24.787 i: [video] User maximum h264 profile determined: 51
10-01 23:36:24.787 i: [video] Device recommended h264 profile determined: 51
10-01 23:36:24.964 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
10-01 23:36:24.966 i: [BufferHelper] Segment count: 1171
10-01 23:36:24.967 i: [MediaDecisionMediaSource] Loading from https://plex.xxx.xx:443/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F27103&protocol=hls&session=f5dcd19d982a56b4-com-plexapp-android&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=3840x2160&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac_latm%2Caac%2Caac%2Cac3%2Calac%2Cdca%2Cdca%2Cdca%2Ceac3%2Cflac%2Cmp1%2Cmp2%2Cmp3%2Copus%2Cvorbis%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D8%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dopus)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=Smart%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:36:24.969 i: [AudioCapabilitiesHelper] Passthrough is set to auto over HDMI, supported capabilities:
10-01 23:36:24.970 i: [AudioCapabilitiesHelper] - ac3
10-01 23:36:24.970 i: [AudioCapabilitiesHelper] - eac3
10-01 23:36:24.971 i: [AudioCapabilitiesHelper] - dca
10-01 23:36:24.975 i: [MediaDecisionMediaSource] Opening https://plex.xxxx.xx:443/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F27103&protocol=hls&session=f5dcd19d982a56b4-com-plexapp-android&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=3840x2160&X-Plex-Client-Identifier=f5dcd19d982a56b4-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac_latm%2Caac%2Caac%2Cac3%2Calac%2Cdca%2Cdca%2Cdca%2Ceac3%2Cflac%2Cmp1%2Cmp2%2Cmp3%2Copus%2Cvorbis%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D8%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dopus)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=Smart%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...8jGM&X-Plex-Version=10.0.0.4149.
10-01 23:36:24.978 i: [MediaDecisionMediaSource] Using HlsMediaSource with FFmpegExtractor.
10-01 23:36:24.982 i: [MediaDecisionMediaSource] onMediaDecisionRefreshed (Sources: 1)
10-01 23:36:25.482 i: [ExoPlayer][EventLogger] timeline [eventTime=74.10, mediaPos=0.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
10-01 23:36:25.483 i: [ExoPlayer][EventLogger] period [8406.00]
10-01 23:36:25.485 i: [ExoPlayer][EventLogger] window [8406.00, seekable=true, dynamic=false]
10-01 23:36:25.486 i: [ExoPlayer][EventLogger] ]
10-01 23:36:25.490 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 8406000 ms)
10-01 23:36:25.491 i: [EngineEventManager] onBufferingStarted (isSeeking: false)
10-01 23:36:25.492 i: [TranscodeSession] Media choice updated
10-01 23:36:25.494 i: [TranscodeSession] Pausing…
10-01 23:36:25.894 i: [FFmpegExtractor] Initialised with new output.
10-01 23:36:25.900 i: [FFmpegExtractor] Opening demuxer.
10-01 23:36:25.902 i: [FFmpeg] [INFO] [FFmpegExtractor] Connecting directly to ExoPlayer.
I have been banging my head on this for the past 2 weeks almost now. In my latest attempt I am tunneling from my remote machine straight to my local via a VPN and I still have issues. It is still only with Android and Android TV for some reason, everything else works flawlessly.
