Android Mobile Beta Not Playing New Podcasts
So I just got accepted into the Android-Mobile Beta Testing (Thanks by the way) Downloaded the latest beta 7.10.0.8636 (8f40e8af) and when trying to listen to my podcasts this morning (while still in my house on the same network as my PMS) it would not load the newest podcast in one of my subscribed podcasts. Tried it several times, no luck. Tried it while on the road and when I got to work. Still just keeps spinning. Won’t load. Tried a podcast that was half-way through and it played fine.
Got home and tried to play in on the PMS directly (to rule out an issue with the episode itself) plays fine. Tried to load it on the Android beta app. Still won’t play.
What do you need from me to look into this? (New to the whole “beta” process)
Same problem here. Can’t listen to my podcasts this morning. Works fine on web browser. Android mobile version 7.10.0.8636. Seems to be all podcasts. I can’t even load ones I’ve listened to already.
seems like it should go into beta forum since this is related to beta :slight_smile:
https://forums.plex.tv/tags/c/testing/player-betas/android-mobile-beta/l/latest
Isn’t this posted in there?
mea culpa :stuck_out_tongue: you’re right.
