Server Version#: N/A
Player Version#: 10.18.1.1096
Hello.
I have a problem with the Folder View feature. I’m almost sure there was a way to indicate that a videos has been viewed.
Currently in folder view the grid of videos is shown (I think a list view would be great), but I have no way to quickly check if a video has been viewed. Some kind of indicator would be great. An icon, a colored symbol, whatever.
Thank you and best regards.
Do you have Watched Indicators disabled in Settings>Experience row>Watched Indicators for Personal Media
The following options are available in the Setting you indicate:
- Movies & TV shows
- Peliculas
- Programas y series de televisión
- Ninguno
The first option was selected. I’ve tested all the four options, with no luck.
Tested on the web app.
Viewed videos are marked with a small ‘check’ tick symbol.
Which device are you using?
This is an open folder with two things marked as watched
A 2019 Nvidia Shield Pro updated to. It’s latest version.
And yes, the screenshot you show is what I used to see.
@BigWheel, there is any update on this issue?
Still trying to reproduce it.
Thanks for the effort. If you need some more info or me trying something, tell me please.
Which type of video library are you viewing? Or does it happen in all the types when using folder view?
I’ve not tried other libraries in the Nvidia Shield, and can’t until some hours later.
I’ll try to give you the details. The UI is set in Spanish, so I my misstranslate some term.
This library is type ‘other videos’, using Ple Video Files Scanner. Agent is Personal Media.
The items in folder view, using the Web Plex, show the ‘tick’ if video is watched and also the bottom ‘progress bar’ if I’m watching it. It also works OK on my Android Plex app (on Samsung smartphone).
Later today I can check it on a Chromecast with Google TV.
@BigWheel, I’ve checked on my Chromecast with Google TV (the one 1080P with a remote) and the same happens here.
On web plex is working OK.
ok. I’m still trying to reproduce. I have the same devices and i get the marks so just trying to figure out what it could be
@BigWheel, there is any news on the issue? It still happens to me.
I still can’t reproduce the issue.
