Please make the buffer on Android TV more obvious. I cannot see a clear visual indicator how much has been buffered ahead in its current iteration.
An orange bar on the playback bar would be useful.
There is. If you can’t tell then it’s likely there isn’t much there. The type of media you are playing will have a significant effect on the amount of data that is cached.
I know there is one. I’m asking for it to be made a bit more apparent in the GUI and it’s a bit too subtle when a small amount of buffer is read, perhaps a change of colour to the Plex orange / yellow colour.
