Android Tv probleme Plex 1.3
Bonjour,
je viens d’installer plex sur mon android tv mais celle ci ne trouve pas mon server et me demande une version 1.3 ou supérieur alors que je viens de mettre la dernière mise a jour.
comment faut il faire
merci d’avance
That error is about Plex Media Server. Is your server running the latest version?
Cette erreur concerne le serveur multimédia Plex. Votre serveur utilise-t-il la dernière version?
via Google translate
Yes i have Version 1.15.4.994
I don’t see a server listed on your account. Did you sign into your server with this same account?
it’s johanfrago@gmail.com
Are you using the same account on the TV? You need to use the same account as the one you use for the server. Look under settings / account. It will tell you what you are using.
it’s ok with the same account, but it will works with my friends ?
You need to share your server with your friend. They can’t just access it freely.
See https://support.plex.tv/articles/201105738-creating-and-managing-server-shares/ for details.
