Android v2026.5.0 forcing transcode
Since the new update, files Direct Play just fine when selecting from home screen / on deck.
But after an episode finishes and it pops up with Play Again / Next Episode and then ON DECK below. If you choose something from ON DECK, it forces a transcode no matter what.
If you then close the stream, and go back to home page and select the exact same episode from ON DECK, it direct plays fine.
Can confirm the same behaviour on Android TV with the latest update on the Nvidia Shield TV Pro
