AniDB metadata agent
It depends on what OS your media server run on. If it's OSX (Mac) then you can use the preferences dialog for the agent. Otherwise, you have to find the stored preferences file in the file system. So, what are you running? You can probably find the answer in one of the prevoius post in this thread though.
Hi. I’m using PMS v0.9.6.3.140-9c9f5ce and latest AniDB agent from unsupported Appstore (also tried v5 and v6 before). But it doesn’t work in the least…
[ plex_anidb_1.png ] Account-Data
[ plex_anidb_2.png ] com.plexapp.agents.anidb.xml
[ plex_anidb_3.png ] Library-Settings
[ plex_anidb_4.png ] Library
[ plex_anidb_5.png ] Log
Any suggestions?
Im getting errors on startup, here are the logfiles for v5 and 6, Plex Media Server v0.9.6.3.143-4466fb5 on Ubuntu Server 12.04
Could you post a full log file from agent start? I'm not sure what's going on, it seems as if all your movies are re-muxed as not file match is found? Try removing the agent completely (including all folders) and then re-install via Unsupported Appstore and see if that helps.
Do you have any custom python version installed that's picked up by Plex? It seems as if you're python isn't compatible with the AniDB library that the agent uses (adba).
Hello!
I’m having some problems figuring out how to install the pluging properly.
What I have done,
Downloaded the zip file from the first post (V.6) unziped and added the plugin to the following path (Running plex media server V 0.9.6.3 on Windows 7) C:\users\Username\AppData\Local\Plex Media Server\Plug-ins\AniDb.bundel
However I cant find anidb as an agent under my preferences on the media server homepage or the xml file for anidb under C:\Users\Username\AppData\Local\Plex Media Server\Plug-in Support\Preferences
and I’v restarted my computer several times.
Any ideas?
Actually I've just started getting the exact same crash on my QNAP (linux) box as well:
2012-07-13 21:38:56,108 - com.plexapp.agents.anidb         (-48b72950) :  CRITICAL (core:582) - Exception starting plug-in (most recent call last):<br />
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/core.py", line 575, in start<br />
    self.sandbox.execute(self.init_code)<br />
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 255, in execute<br />
    exec(code) in self.environment<br />
  File "/root/Library/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/__init__.py", line 1, in <module><br />
    import adba<br />
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 322, in __import__<br />
    return mod.load_module(_name)<br />
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 43, in load_module<br />
    module = RestrictedModule(name, path, sandbox)<br />
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/loader.py", line 30, in __init__<br />
    exec(code) in self.__dict__<br />
  File "/root/Library/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/adba.py", line 21, in <module><br />
    from aniDBAbstracter import Anime, AnimeDesc, Episode, File<br />
  File "/root/Library/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/aniDBAbstracter.py", line 18, in <module><br />
    import xml.etree.cElementTree as etree<br />
AttributeError: 'module' object has no attribute 'etree'<br />
<br />
Error starting framework core.
It looks like they've recently pushed out a new Framework and System bundle:
http://forums.plexapp.com/index.php/topic/43965-new-issues-in-the-last-day-or-two/
While the initial one that was pushed out was utterly broken for me, I deleted the bundles as suggested in the thread and that brought Plex back to life, however I've subsequently started getting the above exception. The Framework bundle includes an XML library. Whatever the update is they've pushed out, it's removed the specific XML functionality that adba is using, at least in Linux. Which sucks.
Fix:
in AniDBAbstracter.py and AniDBfileinfo.py, change:
<br />
to
<br />
from lxml import etree<br />
from lxml.etree import ElementTree as etree<br />
Not sure why this suddenly changed but it looks like it's working now. This might be a Linux-specific change?
Just wanted to say thanks. This solved my problem (first time setup) - I was able to see AniDB show up as an agent by editing these lines in both of these files. After this step, it showed up as an agent in the preferences(though it was grayed out and could not be checked marked) - in order to get the preferences file to show up, I right clicked one of my series and attempted to fetch metadata from AniDB. A file showed up finally. In windows 7 it was AppData\Local\Plex Media Server\Plug-in Support\Preferences\com.plexapp.agents.anidb.xml
In order to correctly modify these files, you might want to install Notepad++, which will make your life a hell of a lot easier. The com.plexapp.agents.anidb.xml file needs to have the lines changed to Yourusernamegoeshere and the changed to yourpass - Now everything is working great for me. If you're having problems, always remember to check your logs located (for me) at AppData\Local\Plex Media Server\Logs\PMS Plugin Logs\com.plexapp.agents.anidb.log
Thanks for all the work that everyone did to get this working.
Atomicstrawberry, thanks for your troubleshooting help. I’ll see if I can get a new release up next week, I’m on holiday right now and can’t get to my computer (as I need to test it on various platforms). It’s really annoying that they push these changes without any notification - it makes it a bit hard to keep up.
Windows 7 here
Anidb was working great for me previously (about a week ago maybe more)
today I renamed some of my folders which caused Fate/Zero (the main reason I use anidb keeping it separate from fate/stay night) and this caused it to delete the old entry and put a new one in.
Problem: I cannot search for anything anymore. It doesn’t matter what I use to search for nothing comes up.
Since I got the error with
File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\AniDB.bundle\Contents\Code\aniDBAbstracter.py", line 18, in
I decided to try the above 'fix' editing the two files.
After doing such I still have no search results :<
Here is the log below
http://pastebin.com/iE2NrdDH
Looks like it's trying to access your file on disk to calculate a hash to look it up in AniDB but the file path is broken or not there - most likely the old paths are still in Plex. Normally the scanner picks up on this and marks the old file paths for deletion from the database. Try running the 'empty trash' function in the media server manager before matching any metadata.
I have no empty trash function unless you mean "empty trash automatically after every scan" which is checked. No searches work including new files that have not had a previous scrape.
To test i added a new library section using BABS as the media scanner and AniDB as the primary metadata agent.
doing so the log is below.
2012-07-23 06:45:17,831 (17c) :  INFO (core:319) - Starting framework core - Version: 2.2.0.2, Build: 785d9fc (Wed Jul 11 04:41:48 UTC 2012)<br />
2012-07-23 06:45:17,831 (17c) :  DEBUG (core:331) - Using the elevated policy<br />
2012-07-23 06:45:17,831 (17c) :  DEBUG (core:419) - Starting runtime component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting caching component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting data component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting networking component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (networking:297) - Loaded HTTP cookies<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (networking:483) - Setting the default network timeout to 20.0<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting localization component.<br />
2012-07-23 06:45:17,845 (17c) :  INFO (localization:408) - Setting the default locale to en-us<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting messaging component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting debugging component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting services component.<br />
2012-07-23 06:45:17,845 (a08) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.anidb'<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting myplex component.<br />
2012-07-23 06:45:17,845 (17c) :  DEBUG (core:419) - Starting notifications component.<br />
2012-07-23 06:45:18,002 (17c) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.anidb in namespace 'metadata'<br />
2012-07-23 06:45:18,017 (17c) :  DEBUG (runtime:995) - Created a thread named 'load_all_services'<br />
2012-07-23 06:45:18,017 (1eb8) :  DEBUG (services:269) - Plug-in is not daemonized - loading services from system<br />
2012-07-23 06:45:18,032 (17c) :  DEBUG (runtime:995) - Created a thread named 'get_server_info'<br />
2012-07-23 06:45:18,032 (1bfc) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400'<br />
2012-07-23 06:45:18,032 (17c) :  DEBUG (core:138) - Finished starting framework core<br />
2012-07-23 06:45:18,032 (1eb8) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'<br />
2012-07-23 06:45:18,032 (17c) :  DEBUG (core:527) - Loading plug-in code<br />
2012-07-23 06:45:18,049 (1bfc) :  DEBUG (core:505) - Machine identifier is f35060f73571f81e2ecb57b673aa919675328ed8<br />
2012-07-23 06:45:18,049 (1bfc) :  DEBUG (core:506) - Server version is 0.9.6.3<br />
2012-07-23 06:45:18,391 (17c) :  DEBUG (core:533) - Finished loading plug-in code<br />
2012-07-23 06:45:18,486 (1eb8) :  DEBUG (services:356) - Loaded services<br />
2012-07-23 06:45:18,486 (1678) :  DEBUG (services:426) - No shared code to load<br />
2012-07-23 06:45:19,858 (17c) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentMovies<br />
2012-07-23 06:45:19,858 (17c) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 06:45:19,858 (17c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo2CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0CjIKczI0CmNvbS5wbGV4YXBwLmFnZW50cy5hbmlkYnMxMAppZGVudGlmaWVycjEKczEwCmFnZW50X2luZm8xCnIyCjkKcjMKczExCm1lZGlhX3R5cGVzcjQKczEyCmFjY2VwdHNfZnJvbW5zMTQKZmFsbGJhY2tfYWdlbnRuczE0CmNvbnRyaWJ1dGVzX3RvcjUKczkKbGFuZ3VhZ2VzYjFzMjAKcGVyc2lzdF9zdG9yZWRfZmlsZXNiMXMxNgpwcmltYXJ5X3Byb3ZpZGVyYjFzNQpwcmVmc3M1CkFuaURCczQKbmFtZTEKczUKTW92aWUyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 06:45:19,874 (17c) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentTV<br />
2012-07-23 06:45:19,874 (17c) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}, {'media_types': ['TV_Show'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 06:45:19,874 (17c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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■■■3cyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 06:45:19,890 (17c) :  INFO (core:578) - Started plug-in<br />
2012-07-23 06:45:19,890 (17c) :  DEBUG (socketinterface:137) - Starting socket server<br />
2012-07-23 06:45:19,890 (17c) :  DEBUG (runtime:995) - Created a thread named 'start'<br />
2012-07-23 06:45:19,890 (17c) :  INFO (socketinterface:161) - Socket server started on port 55126<br />
2012-07-23 06:45:19,890 (17c) :  INFO (pipeinterface:25) - Entering run loop<br />
2012-07-23 06:45:19,890 (17c) :  DEBUG (runtime:633) - Handling request GET /:/prefixes<br />
2012-07-23 06:45:19,890 (17c) :  DEBUG (runtime:720) - Found route matching /:/prefixes<br />
2012-07-23 06:45:19,890 (17c) :  DEBUG (runtime:811) - Response: [200] MediaContainer, 149 bytes<br />
2012-07-23 06:45:19,999 (1f10) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKNDU2YWE0MjMzODQxMzEwY3MxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEyczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3MxMgpGYXRlIFplcm8gSWlzNApzaG93czEKMXM2CnNlYXNvbnMxMDIKRTolNUNBbmltZSU1Q0ZhdGUlMjBaZXJvJTIwSUklMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTJfW2gyNjQtNzIwcF1bREVCQTZGNDVdJTJFbWt2czgKZmlsZW5hbWVzNDAKY2I4ZjFjNjYxZGRlYjc5MzljNmYwYWUxMjg5YjNhZjQwODEyYjE4M3M4CnBsZXhIYXNoczIKLTFzOApkdXJhdGlvbnM1CjI1MzkxczIKaWRyMAo_<br />
2012-07-23 06:45:20,029 (1f10) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKNDU2YWE0MjMzODQxMzEwY3MxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEyczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3MxMgpGYXRlIFplcm8gSWlzNApzaG93czEKMXM2CnNlYXNvbnMxMDIKRTolNUNBbmltZSU1Q0ZhdGUlMjBaZXJvJTIwSUklMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTJfW2gyNjQtNzIwcF1bREVCQTZGNDVdJTJFbWt2czgKZmlsZW5hbWVzNDAKY2I4ZjFjNjYxZGRlYjc5MzljNmYwYWUxMjg5YjNhZjQwODEyYjE4M3M4CnBsZXhIYXNoczIKLTFzOApkdXJhdGlvbnM1CjI1MzkxczIKaWRyMAo_<br />
2012-07-23 06:45:20,029 (1f10) :  INFO (agentkit:909) - Searching for matches for {'openSubtitlesHash': '456aa4233841310c', 'episode': '12', 'episodic': '1', 'show': 'Fate Zero Ii', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20II%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E12_[h264-720p][DEBA6F45]%2Emkv', 'plexHash': 'cb8f1c661ddeb7939c6f0ae1289b3af40812b183', 'duration': '-1', 'id': '25391'}<br />
2012-07-23 06:45:20,029 (1f10) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/25391/tree'<br />
2012-07-23 06:45:20,046 (1f10) :  WARNING (data:181) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting property name: line 8 column 9 (char 207)<br />
2012-07-23 06:45:20,046 (1f10) :  DEBUG (preferences:249) - Loaded preferences from DefaultPrefs.json<br />
2012-07-23 06:45:20,046 (1f10) :  DEBUG (preferences:172) - Reloaded the user preferences for com.plexapp.agents.anidb<br />
2012-07-23 06:45:24,460 (1da0) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKMzY4MzYyOGI2YzUwNmE1OXMxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEzczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3M5CkZhdGUgWmVyb3M0CnNob3dzMQoxczYKc2Vhc29uczEwNQpFOiU1Q0FuaW1lJTVDRmF0ZSUyMFplcm8lMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTNfW0JEXVtoMjY0LTcyMHBfQUMzXVs2Qjg5RjM4OV0lMkVta3ZzOApmaWxlbmFtZXM0MAozZTkzYTVlNTg2NmZkZjBkMWRkZTVjMjZiODUwMmRiMmNlODEwMjJhczgKcGxleEhhc2hzMgotMXM4CmR1cmF0aW9uczUKMjU0MDVzMgppZHIwCg__<br />
2012-07-23 06:45:24,460 (1da0) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKMzY4MzYyOGI2YzUwNmE1OXMxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEzczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3M5CkZhdGUgWmVyb3M0CnNob3dzMQoxczYKc2Vhc29uczEwNQpFOiU1Q0FuaW1lJTVDRmF0ZSUyMFplcm8lMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTNfW0JEXVtoMjY0LTcyMHBfQUMzXVs2Qjg5RjM4OV0lMkVta3ZzOApmaWxlbmFtZXM0MAozZTkzYTVlNTg2NmZkZjBkMWRkZTVjMjZiODUwMmRiMmNlODEwMjJhczgKcGxleEhhc2hzMgotMXM4CmR1cmF0aW9uczUKMjU0MDVzMgppZHIwCg__<br />
2012-07-23 06:45:24,460 (1da0) :  INFO (agentkit:909) - Searching for matches for {'openSubtitlesHash': '3683628b6c506a59', 'episode': '13', 'episodic': '1', 'show': 'Fate Zero', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E13_[BD][h264-720p_AC3][6B89F389]%2Emkv', 'plexHash': '3e93a5e5866fdf0d1dde5c26b8502db2ce81022a', 'duration': '-1', 'id': '25405'}<br />
2012-07-23 06:45:24,460 (1da0) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/25405/tree'<br />
2012-07-23 06:45:42,282 (1f10) :  INFO (logkit:16) - Auth exception msg: Command has timed out<br />
2012-07-23 06:45:42,282 (1f10) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'openSubtitlesHash': '456aa4233841310c', 'episode': '12', 'episodic': '1', 'show': 'Fate Zero Ii', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20II%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E12_[h264-720p][DEBA6F45]%2Emkv', 'plexHash': 'cb8f1c661ddeb7939c6f0ae1289b3af40812b183', 'duration': '-1', 'id': '25391'} (most recent call last):<br />
  File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\agentkit.py", line 918, in _search<br />
    agent.search(results, media, lang)<br />
  File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\AniDB.bundle\Contents\Code\__init__.py", line 243, in search<br />
    self.doSearch(results, media, lang)<br />
  File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\AniDB.bundle\Contents\Code\__init__.py", line 157, in doSearch<br />
    connection = self.connect()<br />
  File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\AniDB.bundle\Contents\Code\__init__.py", line 54, in connect<br />
    raise e<br />
AniDBCommandTimeoutError: Command has timed out<br />
<br />
2012-07-23 06:45:42,282 (1f10) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 06:45:42,391 (127c) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKNDU2YWE0MjMzODQxMzEwY3MxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEyczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3MxMgpGYXRlIFplcm8gSWlzNApzaG93czEKMXM2CnNlYXNvbnMxMDIKRTolNUNBbmltZSU1Q0ZhdGUlMjBaZXJvJTIwSUklMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTJfW2gyNjQtNzIwcF1bREVCQTZGNDVdJTJFbWt2czgKZmlsZW5hbWVzNDAKY2I4ZjFjNjYxZGRlYjc5MzljNmYwYWUxMjg5YjNhZjQwODEyYjE4M3M4CnBsZXhIYXNoczIKLTFzOApkdXJhdGlvbnM1CjI1MzkxczIKaWRyMAo_<br />
2012-07-23 06:45:42,391 (127c) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIwczYKbWFudWFscjEKczYKa3dhcmdzOQpzMTYKNDU2YWE0MjMzODQxMzEwY3MxNwpvcGVuU3VidGl0bGVzSGFzaHMyCjEyczcKZXBpc29kZXMxCjFzOAplcGlzb2RpY3MxMgpGYXRlIFplcm8gSWlzNApzaG93czEKMXM2CnNlYXNvbnMxMDIKRTolNUNBbmltZSU1Q0ZhdGUlMjBaZXJvJTIwSUklMjBbNzIwcCUyMEJsdVJheV0lNUNbVVRXXV9GYXRlX1plcm9fLV9TMDFFMTJfW2gyNjQtNzIwcF1bREVCQTZGNDVdJTJFbWt2czgKZmlsZW5hbWVzNDAKY2I4ZjFjNjYxZGRlYjc5MzljNmYwYWUxMjg5YjNhZjQwODEyYjE4M3M4CnBsZXhIYXNoczIKLTFzOApkdXJhdGlvbnM1CjI1MzkxczIKaWRyMAo_<br />
2012-07-23 06:45:42,391 (127c) :  INFO (agentkit:909) - Searching for matches for {'openSubtitlesHash': '456aa4233841310c', 'episode': '12', 'episodic': '1', 'show': 'Fate Zero Ii', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20II%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E12_[h264-720p][DEBA6F45]%2Emkv', 'plexHash': 'cb8f1c661ddeb7939c6f0ae1289b3af40812b183', 'duration': '-1', 'id': '25391'}<br />
2012-07-23 06:45:42,407 (127c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/25391/tree'<br />
2012-07-23 06:46:04,466 (1da0) :  INFO (logkit:16) - Auth exception msg: Command has timed out<br />
2012-07-23 06:46:04,466 (1da0) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'openSubtitlesHash': '3683628b6c506a59', 'episode': '13', 'episodic': '1', 'show': 'Fate Zero', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E13_[BD][h264-720p_AC3][6B89F389]%2Emkv', 'plexHash': '3e93a5e5866fdf0d1dde5c26b8502db2ce81022a', 'duration': '-1', 'id': '25405'} (most recent call last):<br />
    raise e<br />
<br />
2012-07-23 06:46:04,466 (1da0) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 06:46:19,910 (11b4) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoyNTM5MXMyCmlkczEyCkZhdGUgWmVybyBpaXM0CnNob3dyMAo_<br />
2012-07-23 06:46:19,926 (11b4) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoyNTM5MXMyCmlkczEyCkZhdGUgWmVybyBpaXM0CnNob3dyMAo_<br />
2012-07-23 06:46:19,926 (11b4) :  INFO (agentkit:909) - Searching for matches for {'id': '25391', 'show': 'Fate Zero ii'}<br />
2012-07-23 06:46:19,926 (11b4) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/25391/tree'<br />
2012-07-23 06:46:26,654 (127c) :  INFO (logkit:16) - Auth exception msg: Command has timed out<br />
2012-07-23 06:46:26,654 (127c) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'openSubtitlesHash': '456aa4233841310c', 'episode': '12', 'episodic': '1', 'show': 'Fate Zero Ii', 'season': '1', 'filename': 'E:%5CAnime%5CFate%20Zero%20II%20[720p%20BluRay]%5C[UTW]_Fate_Zero_-_S01E12_[h264-720p][DEBA6F45]%2Emkv', 'plexHash': 'cb8f1c661ddeb7939c6f0ae1289b3af40812b183', 'duration': '-1', 'id': '25391'} (most recent call last):<br />
    raise e<br />
<br />
2012-07-23 06:46:26,654 (127c) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 06:46:48,836 (11b4) :  INFO (logkit:16) - Auth exception msg: Command has timed out<br />
2012-07-23 06:46:48,836 (11b4) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '25391', 'show': 'Fate Zero ii'} (most recent call last):<br />
    raise e<br />
<br />
2012-07-23 06:46:48,836 (11b4) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
This is a different error now. Wait a few minutes or set up your media server to scan for new stuff every hour or so, anidb is timing out. Usually that means high traffic.
New log, same method
2012-07-23 18:40:17,950 (670) :  INFO (core:319) - Starting framework core - Version: 2.2.0.2, Build: 785d9fc (Wed Jul 11 04:41:48 UTC 2012)<br />
2012-07-23 18:40:17,950 (670) :  DEBUG (core:331) - Using the elevated policy<br />
2012-07-23 18:40:17,950 (670) :  DEBUG (core:419) - Starting runtime component.<br />
2012-07-23 18:40:17,950 (670) :  DEBUG (core:419) - Starting caching component.<br />
2012-07-23 18:40:17,950 (670) :  DEBUG (core:419) - Starting data component.<br />
2012-07-23 18:40:17,950 (670) :  DEBUG (core:419) - Starting networking component.<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (networking:297) - Loaded HTTP cookies<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (networking:483) - Setting the default network timeout to 20.0<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting localization component.<br />
2012-07-23 18:40:17,966 (670) :  INFO (localization:408) - Setting the default locale to en-us<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting messaging component.<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting debugging component.<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting services component.<br />
2012-07-23 18:40:17,966 (8ac) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.anidb'<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting myplex component.<br />
2012-07-23 18:40:17,966 (670) :  DEBUG (core:419) - Starting notifications component.<br />
2012-07-23 18:40:18,121 (670) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.anidb in namespace 'metadata'<br />
2012-07-23 18:40:18,138 (670) :  DEBUG (runtime:995) - Created a thread named 'load_all_services'<br />
2012-07-23 18:40:18,138 (874) :  DEBUG (services:269) - Plug-in is not daemonized - loading services from system<br />
2012-07-23 18:40:18,138 (670) :  DEBUG (runtime:995) - Created a thread named 'get_server_info'<br />
2012-07-23 18:40:18,138 (d48) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400'<br />
2012-07-23 18:40:18,153 (670) :  DEBUG (core:138) - Finished starting framework core<br />
2012-07-23 18:40:18,153 (874) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'<br />
2012-07-23 18:40:18,153 (670) :  DEBUG (core:527) - Loading plug-in code<br />
2012-07-23 18:40:18,168 (d48) :  DEBUG (core:505) - Machine identifier is f35060f73571f81e2ecb57b673aa919675328ed8<br />
2012-07-23 18:40:18,168 (d48) :  DEBUG (core:506) - Server version is 0.9.6.3<br />
2012-07-23 18:40:18,575 (670) :  DEBUG (core:533) - Finished loading plug-in code<br />
2012-07-23 18:40:18,684 (874) :  DEBUG (services:356) - Loaded services<br />
2012-07-23 18:40:18,684 (c74) :  DEBUG (services:426) - No shared code to load<br />
2012-07-23 18:40:20,009 (670) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentMovies<br />
2012-07-23 18:40:20,009 (670) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 18:40:20,009 (670) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo2CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0CjIKczI0CmNvbS5wbGV4YXBwLmFnZW50cy5hbmlkYnMxMAppZGVudGlmaWVycjEKczEwCmFnZW50X2luZm8xCnIyCjkKcjMKczExCm1lZGlhX3R5cGVzcjQKczEyCmFjY2VwdHNfZnJvbW5zMTQKZmFsbGJhY2tfYWdlbnRuczE0CmNvbnRyaWJ1dGVzX3RvcjUKczkKbGFuZ3VhZ2VzYjFzMjAKcGVyc2lzdF9zdG9yZWRfZmlsZXNiMXMxNgpwcmltYXJ5X3Byb3ZpZGVyYjFzNQpwcmVmc3M1CkFuaURCczQKbmFtZTEKczUKTW92aWUyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 18:40:20,025 (670) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentTV<br />
2012-07-23 18:40:20,025 (670) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}, {'media_types': ['TV_Show'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 18:40:20,025 (670) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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■■■3cyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 18:40:20,025 (670) :  INFO (core:578) - Started plug-in<br />
2012-07-23 18:40:20,025 (670) :  DEBUG (socketinterface:137) - Starting socket server<br />
2012-07-23 18:40:20,025 (670) :  DEBUG (runtime:995) - Created a thread named 'start'<br />
2012-07-23 18:40:20,025 (670) :  INFO (socketinterface:161) - Socket server started on port 58761<br />
2012-07-23 18:40:20,040 (670) :  INFO (pipeinterface:25) - Entering run loop<br />
2012-07-23 18:40:20,040 (670) :  DEBUG (runtime:633) - Handling request GET /:/prefixes<br />
2012-07-23 18:40:20,040 (670) :  DEBUG (runtime:720) - Found route matching /:/prefixes<br />
2012-07-23 18:40:20,040 (670) :  DEBUG (runtime:811) - Response: [200] MediaContainer, 149 bytes<br />
2012-07-23 18:40:20,197 (15d0) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQozMDI5MXMyCmlkczExCkFjY2VsIFdvcmxkczQKc2hvd3IwCg__<br />
2012-07-23 18:40:20,243 (15d0) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQozMDI5MXMyCmlkczExCkFjY2VsIFdvcmxkczQKc2hvd3IwCg__<br />
2012-07-23 18:40:20,243 (15d0) :  INFO (agentkit:909) - Searching for matches for {'id': '30291', 'show': 'Accel World'}<br />
2012-07-23 18:40:20,259 (15d0) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/30291/tree'<br />
2012-07-23 18:40:20,290 (15d0) :  WARNING (data:181) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting property name: line 8 column 9 (char 207)<br />
2012-07-23 18:40:20,290 (15d0) :  DEBUG (preferences:249) - Loaded preferences from DefaultPrefs.json<br />
2012-07-23 18:40:20,290 (15d0) :  DEBUG (preferences:172) - Reloaded the user preferences for com.plexapp.agents.anidb<br />
2012-07-23 18:40:22,520 (15d0) :  INFO (logkit:16) - Auth ok!<br />
2012-07-23 18:40:22,536 (15d0) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '30291', 'show': 'Accel World'} (most recent call last):<br />
  File "C:\Users\File Server\AppData\Local\Plex Media Server\Plug-ins\AniDB.bundle\Contents\Code\__init__.py", line 162, in doSearch<br />
    filePath = urllib.unquote(media.filename)<br />
  File "C:\Program Files (x86)\Plex\Plex Media Server\python26.zip\urllib.py", line 1170, in unquote<br />
    res = s.split('%')<br />
AttributeError: 'NoneType' object has no attribute 'split'<br />
<br />
2012-07-23 18:40:22,536 (15d0) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 18:41:04,891 (1a9c) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQozMDMwN3MyCmlkczE0CkJha2Vtb25vZ2F0YXJpczQKc2hvd3IwCg__<br />
2012-07-23 18:41:04,891 (1a9c) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQozMDMwN3MyCmlkczE0CkJha2Vtb25vZ2F0YXJpczQKc2hvd3IwCg__<br />
2012-07-23 18:41:04,891 (1a9c) :  INFO (agentkit:909) - Searching for matches for {'id': '30307', 'show': 'Bakemonogatari'}<br />
2012-07-23 18:41:04,891 (1a9c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/30307/tree'<br />
2012-07-23 18:41:04,969 (1a9c) :  INFO (logkit:16) - Reusing authenticated connection<br />
2012-07-23 18:41:04,969 (1a9c) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '30307', 'show': 'Bakemonogatari'} (most recent call last):<br />
<br />
2012-07-23 18:41:04,969 (1a9c) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
and here it is run on the original library using fate/zero II as the testing subject as it had a different error last time as you said.
2012-07-23 19:01:00,657 (130c) :  INFO (core:319) - Starting framework core - Version: 2.2.0.2, Build: 785d9fc (Wed Jul 11 04:41:48 UTC 2012)<br />
2012-07-23 19:01:00,657 (130c) :  DEBUG (core:331) - Using the elevated policy<br />
2012-07-23 19:01:00,657 (130c) :  DEBUG (core:419) - Starting runtime component.<br />
2012-07-23 19:01:00,657 (130c) :  DEBUG (core:419) - Starting caching component.<br />
2012-07-23 19:01:00,657 (130c) :  DEBUG (core:419) - Starting data component.<br />
2012-07-23 19:01:00,657 (130c) :  DEBUG (core:419) - Starting networking component.<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (networking:297) - Loaded HTTP cookies<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (networking:483) - Setting the default network timeout to 20.0<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting localization component.<br />
2012-07-23 19:01:00,673 (130c) :  INFO (localization:408) - Setting the default locale to en-us<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting messaging component.<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting debugging component.<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting services component.<br />
2012-07-23 19:01:00,673 (b70) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.anidb'<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting myplex component.<br />
2012-07-23 19:01:00,673 (130c) :  DEBUG (core:419) - Starting notifications component.<br />
2012-07-23 19:01:00,828 (130c) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.anidb in namespace 'metadata'<br />
2012-07-23 19:01:00,845 (130c) :  DEBUG (runtime:995) - Created a thread named 'load_all_services'<br />
2012-07-23 19:01:00,845 (16fc) :  DEBUG (services:269) - Plug-in is not daemonized - loading services from system<br />
2012-07-23 19:01:00,845 (130c) :  DEBUG (runtime:995) - Created a thread named 'get_server_info'<br />
2012-07-23 19:01:00,859 (1814) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400'<br />
2012-07-23 19:01:00,859 (130c) :  DEBUG (core:138) - Finished starting framework core<br />
2012-07-23 19:01:00,859 (16fc) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'<br />
2012-07-23 19:01:00,859 (130c) :  DEBUG (core:527) - Loading plug-in code<br />
2012-07-23 19:01:00,875 (1814) :  DEBUG (core:505) - Machine identifier is f35060f73571f81e2ecb57b673aa919675328ed8<br />
2012-07-23 19:01:00,875 (1814) :  DEBUG (core:506) - Server version is 0.9.6.3<br />
2012-07-23 19:01:01,282 (130c) :  DEBUG (core:533) - Finished loading plug-in code<br />
2012-07-23 19:01:01,391 (16fc) :  DEBUG (services:356) - Loaded services<br />
2012-07-23 19:01:01,391 (fe0) :  DEBUG (services:426) - No shared code to load<br />
2012-07-23 19:01:02,717 (130c) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentMovies<br />
2012-07-23 19:01:02,717 (130c) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 19:01:02,717 (130c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo2CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0CjIKczI0CmNvbS5wbGV4YXBwLmFnZW50cy5hbmlkYnMxMAppZGVudGlmaWVycjEKczEwCmFnZW50X2luZm8xCnIyCjkKcjMKczExCm1lZGlhX3R5cGVzcjQKczEyCmFjY2VwdHNfZnJvbW5zMTQKZmFsbGJhY2tfYWdlbnRuczE0CmNvbnRyaWJ1dGVzX3RvcjUKczkKbGFuZ3VhZ2VzYjFzMjAKcGVyc2lzdF9zdG9yZWRfZmlsZXNiMXMxNgpwcmltYXJ5X3Byb3ZpZGVyYjFzNQpwcmVmc3M1CkFuaURCczQKbmFtZTEKczUKTW92aWUyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 19:01:02,732 (130c) :  DEBUG (agentkit:1005) - Creating new agent class called AniDBAgentTV<br />
2012-07-23 19:01:02,732 (130c) :  DEBUG (agentkit:885) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}, {'media_types': ['TV_Show'], 'accepts_from': ['com.plexapp.agents.localmedia', 'com.plexapp.agents.opensubtitles'], 'fallback_agent': None, 'contributes_to': None, 'languages': ['en'], 'persist_stored_files': True, 'primary_provider': True, 'prefs': True, 'name': 'AniDB'}]<br />
2012-07-23 19:01:02,732 (130c) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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■■■3cyCnMyOQpjb20ucGxleGFwcC5hZ2VudHMubG9jYWxtZWRpYXMzMgpjb20ucGxleGFwcC5hZ2VudHMub3BlbnN1YnRpdGxlczEKczIKZW5yMAo_'<br />
2012-07-23 19:01:02,747 (130c) :  INFO (core:578) - Started plug-in<br />
2012-07-23 19:01:02,747 (130c) :  DEBUG (socketinterface:137) - Starting socket server<br />
2012-07-23 19:01:02,747 (130c) :  DEBUG (runtime:995) - Created a thread named 'start'<br />
2012-07-23 19:01:02,747 (130c) :  INFO (socketinterface:161) - Socket server started on port 60105<br />
2012-07-23 19:01:02,747 (130c) :  INFO (pipeinterface:25) - Entering run loop<br />
2012-07-23 19:01:02,747 (130c) :  DEBUG (runtime:633) - Handling request GET /:/prefixes<br />
2012-07-23 19:01:02,747 (130c) :  DEBUG (runtime:720) - Found route matching /:/prefixes<br />
2012-07-23 19:01:02,747 (130c) :  DEBUG (runtime:811) - Response: [200] MediaContainer, 149 bytes<br />
2012-07-23 19:01:02,872 (7e4) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxNzMzNnMyCmlkczEwCkZhaXJ5IFRhaWxzNApzaG93cjAK<br />
2012-07-23 19:01:02,904 (7e4) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxNzMzNnMyCmlkczEwCkZhaXJ5IFRhaWxzNApzaG93cjAK<br />
2012-07-23 19:01:02,904 (7e4) :  INFO (agentkit:909) - Searching for matches for {'id': '17336', 'show': 'Fairy Tail'}<br />
2012-07-23 19:01:02,904 (7e4) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/17336/tree'<br />
2012-07-23 19:01:03,121 (7e4) :  WARNING (data:181) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting property name: line 8 column 9 (char 207)<br />
2012-07-23 19:01:03,121 (7e4) :  DEBUG (preferences:249) - Loaded preferences from DefaultPrefs.json<br />
2012-07-23 19:01:03,121 (7e4) :  DEBUG (preferences:172) - Reloaded the user preferences for com.plexapp.agents.anidb<br />
2012-07-23 19:01:05,496 (7e4) :  INFO (logkit:16) - Auth ok!<br />
2012-07-23 19:01:05,496 (7e4) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '17336', 'show': 'Fairy Tail'} (most recent call last):<br />
<br />
2012-07-23 19:01:05,512 (7e4) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 19:01:31,282 (1f18) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxNzMzNnMyCmlkczEwCkZhaXJ5IFRhaWxzNApzaG93cjAK<br />
2012-07-23 19:01:31,296 (1f18) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxNzMzNnMyCmlkczEwCkZhaXJ5IFRhaWxzNApzaG93cjAK<br />
2012-07-23 19:01:31,296 (1f18) :  INFO (agentkit:909) - Searching for matches for {'id': '17336', 'show': 'Fairy Tail'}<br />
2012-07-23 19:01:31,296 (1f18) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/17336/tree'<br />
2012-07-23 19:01:31,483 (1f18) :  INFO (logkit:16) - Reusing authenticated connection<br />
2012-07-23 19:01:31,483 (1f18) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '17336', 'show': 'Fairy Tail'} (most recent call last):<br />
<br />
2012-07-23 19:01:31,483 (1f18) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
2012-07-23 19:01:57,115 (23cc) :  DEBUG (runtime:633) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxOTU1NnMyCmlkczEyCkZhdGUvWmVybyBJSXM0CnNob3dyMAo_<br />
2012-07-23 19:01:57,131 (23cc) :  DEBUG (runtime:720) - Found route matching /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZWIxczYKbWFudWFscjEKczYKa3dhcmdzMgpzNQoxOTU1NnMyCmlkczEyCkZhdGUvWmVybyBJSXM0CnNob3dyMAo_<br />
2012-07-23 19:01:57,131 (23cc) :  INFO (agentkit:909) - Searching for matches for {'id': '19556', 'show': 'Fate/Zero II'}<br />
2012-07-23 19:01:57,131 (23cc) :  DEBUG (networking:156) - Requesting 'http://127.0.0.1:32400/library/metadata/19556/tree'<br />
2012-07-23 19:01:57,161 (23cc) :  INFO (logkit:16) - Reusing authenticated connection<br />
2012-07-23 19:01:57,161 (23cc) :  CRITICAL (core:541) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'id': '19556', 'show': 'Fate/Zero II'} (most recent call last):<br />
<br />
2012-07-23 19:01:57,161 (23cc) :  DEBUG (runtime:811) - Response: [200] str, 16 bytes<br />
Is Plex actually seeing your files? The error it's throwing is basically trying to split the file name, but the file name isn't there i.e. there aren't any files. Obviously they'll have no metadata or anything but does your Plex Media Server actually see any episodes? I think something is getting confused, but it might be an actual plex problem rather than an AniDB one.
Are any other scanners working? Does it match if you use tvdb? Beyond that I'm a bit stuck, don't know the code well enough to suggest anything further. Personally I use this scanner and BABS and have had no issues beyond needing to do a few minor tweaks to work around some bugs, fixes for all of which except the etree one are already in the latest AniDB bundle.
Everything works minus Anidb. It sees all the episodes. For now I unmatched it and manually edited the meta data for each episode etc.
If I wanted to I could use TVDB to import fate/zero as fate/stay night and have by accident before causing it to merge with the real season 1 of fate/stay night. This causes me to actually have to remove the folder to split it back up per-say.
Regardless of all this, it is indeed an error specifically with the Anidb scraper. Everything else works perfectly. I guess I shall wait for the author to release his update, hah.
accidental double post. Don’t see the option of deleting.
Quicksmage, try adding the following line to __init__.py at row 161 (take care to use proper indentation)
Log("Unquoted filename is " + str(media.filename))
That should give something in the log file that might help troubleshooting. The update of the plugin that has been discussed previously has nothing to do with your problem, so that won't solve it.
New version - v7 - out on Unsupported Appstore and in first post. Fixes python imports.
