Thanks for this great plugin. Though it took me a bit to find all the pieces of information to make it go. Was thinking you might add some of the following information to your original post to help new users out. Just a suggestion.
F.A.Q:
Q: Where do i input my AniDB.net username and password?
A: You need to manually edit the com.plexapp.agents.anidb.xml file. This file is found in the /Plug-in Support/Preferences/ directory ( depends on your platform). If the file doesn’t exist yet, you can also manually create it with the following template:
<?xml version='1.0' encoding='utf-8'?><br />
<PluginPreferences><br />
<username>username</username><br />
<password>password</password><br />
</PluginPreferences>
**Q:** The scanner shows up now, but I am still unable to select the anidb option. It's grayed out. How do I enable it?
**A:** That's normal. What you're doing on that screen is enabling other agents to contribute to Plex's metadata. It doesn't make sense for AniDB to contribute to itself so it's greyed out. It needs to be the primary metadata agent for the section. Assuming you've got a section created in your PMS manager, open the section you created for your anime TV/Movies, click Edit Session, then on the box that pops up, hit 'Advanced' and change your Primary Metadata Agent to AniDB.
**Q:** My shows are still showing up as Season 1, Season 2, etc, instead of their absolute numbering.
**A:** This happens because the Plex Series Scanner will assume that Episode 100 is Episode 00 of Season 1, and things go haywire. If you are watching shows with > 100 episodes (eg Bleach, Naruto, Fairy Tail, One Piece and so on) you will also want to install the BABS scanner [found here](http://forums.plexapp.com/index.php/topic/31081-better-absolute-scanner-babs/). Once it is installed, open the section you created for your anime TV/Movies, click Edit Section, then on the box that pops up, hit 'Advanced' and change your Media Scanner to BABS.
