I have some shows that are XVID AVI’s
I tried to convert to .MP4 and .MKV in Handbrake, however Plex doesn’t see them
The MP4 is Video AVC and Audio AAC
The MKV is Video is the same.
What are the right settings
Hi @JuiceWSA That is a link for naming conventions. Mine are named correctly, as others files do appear.
I think it was my Handbrake settings.
I followed one of your links and re-did it and it worked.
So thanks for putting those links on
I stopped taking people at their word regarding file naming - long ago.
You’re gonna have to prove it.
B)
Other Files Appear
in no way means
They’re named correctly.
FileBot (link in my signature) can handle that naming/structuring for you automatically or manually in seconds.
What FileBot can’t do is remove possible embedded metadata in the Title Field of MP4/M4V files. Plex will read this info and prefer it over a perfect file name/structure, but you can combat that situation by moving Local Media Assets to the bottom of every agent list you can find. All tabs in TV Shows and Movies here:
https://support.plex.tv/hc/en-us/articles/200241558-Agents
Just drag LMA to the bottom of the list and drop it. If you do have embedded metadata this will cure the issue, if you don’t it won’t matter. LMA will do what it has to from the bottom.
Renaming/restructuring is best performed OUTSIDE the library and you may need to write a new bundle for the show or movie so The Plex Dance® was invented:
The Plex Dance®:
All Steps. In Order. No Shortcuts.
If it’s working now, but suddenly stops working - and for future reference I include the above.
