The Plex Dance ™
The purpose of this is to remove all cached metadata and xml data for an item that Plex usually keeps. This helps when you want to “start from scratch” for particular item
  1. move all files for the media item out of the directory your Library is looking at, so Plex will not “see” it anymore
  2. scan the library library (to detect changes)
  3. empty trash
  4. clean bundles (in the menu next to server name, when accessed under ‘More’. Or alternatively under Settings - [server name] - Manage - Troubleshooting.)
  5. double check naming schema and move files back
  6. scan the library
Support article: Library Actions
Plex not finding shows brought in by Sonarr
Undertekster
What is a Plex "bundle", and why would it need to be "cleaned"?
Can't get Plex to find TV series
Plex Metadata Issues For TV Show
Plex Music Matching Problems
S1001 (Network)
Two Episodes Keep Overlapping and Can't split (Lost S01E24 + 25)
Missing Movies,TV episodes, and posters
Music Import
Movie name Mr. & Mrs. Smith coming in under a movie called Red Folder
Origin of the "Plex Dance"
Missing movies
Plex cannot find SOME (media) files
Plexamp not showing all compilation albums
Wrong episode number and using TVDB database for all info
True gapless playback not working
[BUG] Can't access all TV Show Seasons
Plex displaying old MKV title tag despite clearing bundles and cache
Missing pictures
PMS 1.24.3.5033 database locked
En mappe under SERIER har delt sig?
Plex Not adding "Fear the walking dead" show and is confusing it with "The Walking Dead"
Trouble with new PC and previously viewable videos
Artist radio builds same list of songs each time
Plex no longer honoring "Various Artists" tag, every song gets its own album
Getting a "Conversion failed. Transcoder crashed or failed to start up" error
Metadata Language is mixed
Files Will not show in PLEX
[Solved] Photo Timeline Out of Order and Photos in Wrong Date
Replaygain for Music coming soon to Plex??? See attached picture ;)
Small percentage of files will not pull IMDb metadata
Bug report: after renaming files that were not parsed correctly mark as watched works bad
Stranger Things Season 2
How do you get episode names and info for Star Trek Original series?
Extras folder
Intro Detection doesn't run as a scheduled task only
When does Plex update its metadata cache?
DVD/Movie saved in chapters
file names reverting after import
(Solved) Weird issue: No matter how many movies I add in this library, these 4 are always in the front of 'Recently added'
"Fix Match" on Albums doesn't update track info
All my Various Artists albums show the album artist as John Williams in Plex
Plex not reading local metadata correctly
The Wolfman (1941) showing up as Frankenstein Meets the Wolfman (1943)
Special episodes for TV shows?
Can't properly match the show Travel Man: 48 hours in
New Plex Media Server TV show/series scanner and agent preview
Continue Watching item not synced
Episode names/metadata not loading
TV Shows not showing what I have
Redo thumbnails?
English SRT subtitle recognised as Southern Kurdish
TV Show names not importing correctly
Plex non vede alcuni file e di altri stravolge il nome
How to organize albums with multiple disks?
Multi-part Movie (non-stacked)
Play next episode
Can't see some TV show files
Converting stuck at 0 and not
Invasion (2021) Episode 9 missing metadata
Refresh Not Working
Doctor Who - new series displays Titles from the classic?
Movie extras are missing in action. Problem Solved
Plex music genres are offensive and make no sense
Why plex don't use gracenote track name ?
Can't pull Season/Episode Metadata, only the show itself
[RESOLVED] Reset subtitle setting
Plex is using metadata tags while Local Media Assets disabled
Missing TV Show Poster, Banner and Background
Duplicate Entries with multiple Library Paths?
Plex not listening to Musicbrainz Picard
[BUG] Multi-disc music rating copies across discs
Updated versions of Plex, additional metadata fields, retrieving metadata, locking files
TV Shows NOT pulling Metadata Show Agents
Problem with getting correct episode numbering
How to get The Flash into TV Library
close to suicide
Music albums are being split, how do I fix this?
Plex Music Missing Features
The Cleveland Show
Which is better for meta data IMDB or The Movie Database
There are no items in this library when using 'TV Shows' channel
TV Show Artwork Refusing to Download
Where is the folder location for the Scanner?
Musicbrainz -> Last.FM Metadata woes
Play external audio files in sync with video
Can I fix Genre naming / capitalization?
Issues with Disney metadata
Plex Won't Find My Show even though i follow naming scheme
How to batch poster artwork. 20+ episodes at one time
Naming Conventions Don't Work
PMS not using the metadata embedded in my MP4 files
Tricky TV special metadata
TV Posters gone after restoring backup.
Can't have both Blade Runner movies in
Metadata not working / incomplete
Movies Library getting switched to Videos?
Scanning Agent (again not working) status page
How do I best organise movies in multiple languages?
TV show (anime) doesn't show in plex server
Inconsistency with display name for TV local extras
Removing items from drag and drop poster options?
Two TV shows with same name (different years) - one not showing
Music Library Extras
Unable to match documentary from theTVDB
Why does Plex show me twice the same album?
[Help Needed] Strange behavior on PMS Version 1.5.1.3520
Plex in Synology is not able to find Metadata until a Stop / Restart is undertaken
Refresh Not working on Version 1.4.4.3495 (and 1.5.1.3520)
how to download subtitles.
"Plex Dance": Should the Plex Team spend the time to fix this?
Naming of movies and search by filename
TV Show matching issue
Removal of wrong Tidal music/album linked to movie file
Disc Season Episodes are Specials according to TvDB
Is there a problem with the TVDB
Some mkv files not being found by scan
Playing multichannel audio by default - video files
Why has Plex created a single Artist from a compilation
Not another Forced Subtitle Setup question - done a lot with no success
Movies not getting added to Plex
Is there any way to delete items directly from the database?
Fix subtitle offsets // mod: option to increase step size
TV Show: Plex Only Recognizing Half the Episodes.
Update metadata after change in themoviedb
Album disappeared after edit
How to correct PMS cataloging of Doctor Who (correct on 1 server, incorrect on 2nd server)
Domandine forse Banali ma ci provo :)
Media tagging error with close artist name
Episodes being categorized incorrectly
PMS picking up artirsts on albums as "Various Artists."
What is the correct way to Plex Dance?
Actors and theme music
TV Episodes Not Consistently Importing or Matching Metadata
Unmatched Albums in Music Library - How can I use ONLY local metadata?
Half of the episodes of a show won't upload
TV Show Metadata not working yet Show is in TheTBDB
PMS not updating artwork for TV Show seasons
Two Al Pacinos
Can't get Plex to recognize TV series (Louis Theroux)...tried EVERYTHING?!
One album being incorrectly identified as Various Artists instead of Alabama
Unable to match ANY film added using all agents
And...BOOM...Two usernames. Can we merge?
Custom posters for TV Shows
Plex Movie agent down?
Plex No Longer Seeing Local Poster Files / Movie Agent Problems
Multiple Movie Editions Renaming Bug?
TV Meta Data Oddity (Another one)
Movie with Multiple Sub-Movies or "Specials"
Issue with Plex Serie Scanner
Error in the fanart.tv agent
Is it best to use TVDB instead of Plex TV Series Search at first then Upgrade DB?
Storing movie extras in a separate location
Editing Movie title?
Anybody having trouble adding Hustler?
Matching albums and editing the release year
Daily Shows Matching Wrong Episode
One episode not matching: done all the usual checks
Help!! I am going mad!!!
Photo thumbnails not showing in android app
PMS Not removing some titles?
Plex scans correctly first time then rearranges everything on a rescan
Meta Data Not Updating From TheTVDB - Not Sure What Else to Try
Why doesn't LOCK mean LOCK when editing content details?
Server Knows Correct Movie, but Lists a Different one
Plex not downloading all metadata
Plex displaying file name instead of title
Music not showing up in Library
Naming all of MST3k
Matching against TheTVDB
Charles III
Fix Incorrect Match search is broken
How can i have plex only read file name not property title ?
Plex not detecting all video files - help please?
TheTVDB Agent...is it working at the moment?
Why does Plex put the album artist/artist as Handheld when it's Handel?
[How To] Change Ratings Provider
Matching individual seasons
Does 1 folder deeper than main folder causes non thumbnail view?
Bug: Plex scanner may ignore or destroy directory depending on contents
TV series Metadata found, mismatching/not matching. devoured by Cthulu for failing saniity check
Metadata won't update for TV shows
Hawaii Five-0 not added to library
Administration from mobile devices
Used to use TheRenamer for file naming... until TheTVDB went v2. Now what?
Why does Plex keep removing some of my media?
Upgrading file results in duplicate
[RESOLVED] Recently Added showing wrong data (Was Not a Plex issue)
Some movies are being ignored
Movie Rating Not Populating
Missing TV Shows
Problems adding new media
How to destroy a very nice app :(
PlexKodiConnect: Kodi Plex Integration Done Right
Duplicate files in a library
TV Shows naming odd
Plex changing movie title even though it's locked
Two TV Series with same name but different years - cannot get both to show in Plex
TV Show Series Issue: Octonauts
Matching Albums - Not including correct info
Star Wars Rebels complete series name convention
Plex won't add mp3 file
Music shuffle no longer works properly
Changed file dates, but still at the front of recently added
No "Match" of "Fix Match" option in TV shows section
Local TV Extras Agent
Plex shows no content after doing the Plex Dance. Server cannot be found
How to show title of Looney Tunes episodes
Forced subtitles default behavior not working
Organization of movies
TV Show Season Not Showing Up
How Do You Actually Utilize the .plexmatch File?
The Fix Match seems to have stopped working with The Movie Database
Magnum P.I. new series naming conventions?
I give up! Movie will not add to library!
Plex Loading TV Show Metadata But Not Posters / Artwork / Covers For Specific Seasons
Plex not detecting TV Shows! Please HELP!
Matching Issue - Series 1
Media playback error
New media in the movies library matches to wrong existing movies
I tried merging all my Starwars movies, now I can't unmerge them
Best strategy for groups of albums/series of albums (Music)
Plex Mixing up TV Shows
Plex not seeing subtitles
Naming convention with HD and 4K with different file extensions
Plex not picking up movie posters for certain movies
TV Shows not finding ANY matches
Incorrect TV show poster persisting
Music Library Doesn't Get Artist or Album Artwork
Cosmos: Possible Worlds ep 3,4 no metadata
No Summarys or release dates for movies
Manually adding a missing movie?
Metadaten werden von falscher Mediathek (und in falscher Sprache) geladen
Artist not showing genres and still showing in library after deletion
Can't for the life of me get Tom and Jerry added 4.22
Recently added movies strange behaviour
Why so many Unknown Artists
All tracks on unrecognised albums named the same
Tvdb dvd metadata not matching correctly
New music Metadata agent doesn't like compilation albums or albums by multiple artists
Movie extra not showing up ("-interview" tag)
Plex not adding all files for tv show - Solved
No matches found on all scans/manual
Plex Hates id3 tags
Artist metadata - genre field not populating
Imdb ratings doesn't update even when I refresh meta data
Newly added TV shows not showing in PMS
Bug: Movie "editions" cause severe playback latency, high cpu utilization, and playback failure
Plex Music indexer - FLAC artist albums indexed incorrectly as 'Various Artists' - BUG?
No Longer Matches Files with Properly Placed Articles
Single missing episode
Music track history shows "a few seconds ago"
Trying to add a folder to a Library without success
What does the unmatch command do
Show will not match
Posters and other image Metadata suddenly missing?
Plex isn't seeing Season Folders that Sonarr added
Inconsistent playback of blu-rays
TV shows folder noot shhowing titles in plex
Bad intro!
How do i fix the duplicate file issue?
Plex not naming the subsequent episodes of multi episode files properly
Background Art Not Appearing in Continue Watching on Plex Media Player/Plex Web App Only
SRT subtitles not being picked op anymore
Automatic metadata matching for recordings
Naming Files for Plex
Posters show in Library but no posters show in "Poster" field when editing indiv file
Plex pulling both Aired and DVD order
Tagging DVD Order Issues
Delete from Plex - Now Can't add it back to Plex...?
Cross Season File Duplication Problem
One single movie not matched?
Does Plex Staff provide assistance?
Cannot add song which never appeared on any album, also cannot DELETE album
Trouble getting Plex to recognize TV Shows
TV-Serien: Keine Metadaten auf deutsch
Cowboy Bebop (2021)
Missing artist photos when adding new music, even after Fix Match
4k Videos Not Mapped to 4K Search Filter
Adding TV Show to another as a different version
TV Episode not matching into current series
Incorrect artist art coming by default
Plex Not Fetching Metadata for Certain Seasons of Shows
What To Expect From PLEX in 2018 // CES 2018 Interview
Feature Request: Forced Subtitle Track Preferred.
Plex Won't Recognize Prince "The Hits_The B-Sides" Album
Automatic collections? I don't remember asking for that...
Android "nvidia shield" not grabbing any trailers?
Movie listed many times with multiple parts and different sources
Why has this movie also matched against five extras from another movie?
Moving film from one folder to another
Problem with Plex Media scanning
Episode or Movie info showing 2 files, however only 1 exists (they show as duplicates)
TV Shows suddenly not showing up on Home
Charmed 2018
Suddenly stopped downloading metadata for shows
Plex not picking up any matches as of 3 days ago
Plex erkennt keinen mp4-Film
Renaming not solving my "unfound" TV show problems
Jujutsu Kaisen Specials Folder doesn't appear
House of Cards (UK)
Problem with album artwork showing as band image (and more)
Missing HD Movies
Scan not removing old link files
WAV files indexing escpecialy compilation cds
Metadata problem or thetvdb.com
Plex is not adding a show
Actor thumbnails appearing and disappearing
3 movies, same title, same release year
Date of Music Album field 'Originally Available' is set to most recent year found
Metadata for TV series will not be downloaded, no matter what(?)
Newly added movies not downloading posters. did not make any changes to system
Why is the 'Plex Dance' even a thing?
Some files does not appear in the Plex
Plex Premium Music: Artist missing
Local music artwork not being scraped
Mismatch between web app and desktop views
How to name a file to get a correct match
Error after updating from PlexMediaServer-1.7.6 to 1.8.0 (and later) on a Synology
PMS and MKV Header Info
Music albums matched, but not detected as matched other things
Extras and Trailers showing up but I have disabled "Find trailers and extras automatically"
Plex Not seeing 6 seasons of a Series
Wrong Chapter Thumbnails on Andriod
Plex will not download meta data for some movies
Why are all my Various Artists albums showing as ‘Bob Marley’, despite being properly tagged?
Split apart mismatch gets wrong added date
Made for TV Movies
Metadata no longer being updated / downloaded
Subtitles - Help Please
Plex not separating TV Show into Seasons
Multi disc in one ablum shows as multiple albums
*Some* TV shows do not have episode names or descriptions
Weird 'On Deck' Behaviour
Movie matching does not work anymore
Specials named correctly but not grabbing info?
Another how to convert and play XVID file
Extra step for "Match" to appear in three dot menu.
Specials not picking up name
TV Series name matching research
Plex wont recognize certain .MKV files.
Conversion failed. The transcoder crashed or failed to start up.
How do I add external subtitles with local media assets agent disabled?
Recorded TV shows (UK) not generating episode thumb image (screenshot)
WAV files showing blank in Plexamp
WIndows Music Files Metadata And How It relates To Plex Fields in Compilation/Multi Artist Albums
How do I name Planet Earth II Blu Ray?
DVD Order Agent
Songs in album showing up twice (and only one is playable) - question and solution?
TV Show not adding despite being formatted correctly
Nach Ordner bzw Namen sortieren nicht möglich?
Matching and Fix Match no longer working?
Plex on Synology DSM 7 - Library Will Not Detect ALL NAS Music Files
TV Show Library not populating
Plex Music adding lower quality artwork to music
Anomalies in Plexamp's Tidal Artist Sonic Recommendations
Please give us a better metadata for private videos
Refresh of library is not picking up changed file metadata
Issue With Plex Not Finding Correct Metadata
Multi-episode tv-shows: Files incorrectly recognized
(UPDATED with VIDEOS) December Plex Pass Community Roundtables
How to force an update Popularity track ratings?
Issue with TV Show Stuck (US) (2022): TVDB 416590
[Bug] Edition does not go away after removing tag from filename
Create chapter markers for movies
I was told by plex on twitter to post about the transcoder was unable to process this media error
Wrong year for Timecode (2016)
Wrong auto mapping - stuck with wrong artwork
What to do if an artist doesn't show up?
Playback Error occurs when trying to play video after editing its file name
Why does metadata not download for The Late Show with Stephen Colbert as of season 2?
Why is Plex only recognizing some of my Tv show episodes (files are named correctly)
Feature I'd love to see (Win + PS4)
Media Files not discovered at all after a re-organization
[implemented] Movie Collections
Difficulty With ESPN 30 for 30 series
Plex incorrectly identifying TV episodes
Cant connect to my server
Problem to retrieving metadata from tvdb
How-to handle TRIBUTE albums?
Wrong Metadata on Series (TV-Show Series)
Upgrade to PMS 1.0.x and Lyrics are gone/no longer showing
Loudness Data lost and won't rescan after library move
Meta Data
Tag support for ROBUST music library organization
Is there a limit on number of files or folders?
Show names for audio tracks and subtitles in MP4 files
Bug Report: Incorrect "Recently Added" Sorting Due to File Modification Date
Hard Knocks (2001) TVDB airing order not pulling metadata
How to mirror tags update to library?
TV episodes with numbers not recognized correctly
A single show, multiple episodes, not being found or added on scan
Plex TV Agent bad data for episodes. TheTVDB and TMDB are both correct
Can't play Plex on any Apple device
Special Edition movies not auto-matching
"Get Info" has no Media info but XML does
Distinguish 2x Emma (1996) with Paltrow and Beckinsale respectively
SpongeBob SquarePants S4 and S5 not respecting TTVDB DVD order
Best way to rescan Music File Tags?
Plex and forced subtitles (Game of Thrones, Star Wars, etc.)
Playback Stopped - Couldn't retrieve the play queue for this item. Please try again
RARBG Titles not updating after change
Issues with Naruto (2002) after updating to new metadata
Library scan keeps marking shows as unwatched, and removing seasons
Plex Has Over-ridden My Previous Movies Folder Metadata - How do I recover it?
Breaking Bad will not appear in TV Shows
Verständnis Frage zu Serien Episoden
(Solved) TV shows do not show in app
Plex TV Agent Pulling Data From Wrong Season (Super Friends)
Episode snapshots off by one episode
Plex doesn't recognize videos converted to h265 anymore
Films not showing up in Plex
Sorting Order by TVDB (DVD)
Strange recognition of videos
Plex not recognizing single .flac file for an album (everything else organized as required)
Why Is Plex Not Matching on one server but is on another
How do I clear a music library of all albums/tracks?
Possible New Bug in file name detection?
"Refresh All Metadata" question
Plex Library Management Sucks
Record Label embedded Metadata for Music Media
Issue with certain movie file names not being detected
Unmatched episodes from specific season, why?
Plex mixing my shows
Same name show causes confusion
Restore Deleted Movie
Trailers not working
Plex shows duplicate thumbnails in TV show
FreeBSD matching since moving to the new "Plex Movie" function
What is going on with Mystery Science Theater 3000 matching?!
Metadata mis-match - "Bob (Hearts) Abishola"
Version of Sailor Moon Not In TVDB
Library meta data scrapping problems
Plex not recognizing certain episodes in a TV show
Music tracks being inserted and renamed as the same as another track on the album
"Failing exchange for lack of track matches"
TV Shows missing TheTVDB in Windows and Linux
There is no option for Show lyrics for local music in Samsung Tizen
Fighting the plex agent with Battlestar Galactica (modern)
Help with naming movie extras
Plex Media Server not recognizing files after updating Synology DSM 7.3
Narcos mexico season 1 not being picked up by plex
Cartoons won't match
Intro/Credits detection does not work
Scrubs (2026) suddenly folded into Scrubs
Plex completely mis-identifies some movies
Unable to Remove entries from the Unmatched Filter for certain TV Episodes
Match for Show Only Populates First Episodes of Seasons
Plex shows duplicates of file which have never existed
Horace and Pete (2016) not recognized by Plex TV Series
Two incorrect issues with media matching
Night Gallery - Can't get TVDB Aired order to work
Noah movie keeps disappearing
Accentuated characteres bug for trailers on Synology NAS
How to add unlisted film/tv program into the databases or ask for others to add them?
TV show extras not showing up
Season specific Backgrounds loading wrong
Plex keeps changing home videos release date to 1969
Why do 2 different Music tracks, in different albums, with different names, get the same GUID?
Sonic Analysis, do folks bother with it?
Plex local posters not applying to media
Space Above And Beyond Naming Issue
Anime Series "Seasons" not interpreted correctly
Corrupt Sonic analysis?
Plex uses search results instead of metadata tags (like title)
Plex media library no longer updating automatically
Videos not showing correct title
Subtitles not working with TV Show extras?
Music library weird behavior
We need more control with TRASH CAN
Music Scanner not respecting "Prefer local metadata", mismatching VA and OST album artists
One movie Folder will Not Show Up in Plex Library ( Star Trek )
TV: Plex will not add/recognize TV show despite hint to TVDB
Sonic Analysis fails due to ~259 character file path limit in Plex Transcoder
Plex matching is bad and I've exhausted all tricks
TV series grouping issue
Recently Added TV has old version in the first place
Missing Movies In A Library
Option to remove / delete files from Plex without deleting it from disk
Subtitles... and Audio format
Show not matching the TVDB Aired order
Incorrect Track Number and Disc Tags on Releases - Fix Match does not solve it
Plex won't add a show
Incorrect Metadata being pulled for Panty & Stocking Season 1 (2010)
Plex matches successfully, but no cover image
Scrubs 2026 was detected and now it's not
No episode names for season 8 of The Flash
Missing one episode from series in scan
Subtitles off sync by hours
Some Seasons Showing - Others Not
Aaaarrrggghhhhh! stop changing my cover art!
Movie Origanization
Plex is incorrectly naming an episode
Plex TV Agent forces wrong match with no way of correcting to accurate TVDB show
Regenerate Video Preview Thumbnails for Individual Movies
Multi-episode naming now broken?
I changed my Synology NAS password. It broke everything. Changed it back, hasn't fixed anything
Library does not display albums correctly
Multi-series episode matching BUG
Where did the Movie Go?
Half matched movies
Pinned support topic for metadata in Plex TV Series agent that needs fixing?
Plex NFO Agent Forum Preview
Unable to finish update of metadata for movies[windows]
TV Shows not showing names or posters
I think i solved it, some files don't show on plex server?
Plex not recognizing codec 'profile' changes
Absolute Order Problem for "One Piece"
All recently added TV has release date of Feb 7, 2036
Splitted albums
Plex skipped an episode
Movie name not showing correctly - 5 Flights Up shows as 5.Flights.Up.2014.720p
Plex combined the same show that is in two different libraries
Shield TV Pro - End of Episode video shrinks and can't watch credits fullscreen
New Fantasy Island series pulling OLD series metadata
Voice activity analysis (for Auto Sync Subtitles) not working
Plex can't identify a movie on PMS
Plex can't generate video & chapter thumbnails for one specific movie
Frustrated with borked listings that do not match TVDB (SpongeBob SquarePants)
Recently Added TV Shows (Two Shows constantly at top of list)
Editing XML file - Need to change recording info
Changing tag information without deleting the library?
Plex showing wrong TV Episode names
How do I get Plex to see second disk/part to movies?
Plex not finding one single movie
Dialog that prompts to delete metadata and/or file, not just file
Doctor Who Specials Again
Can someone explain this matching logic?
Can anyone read Plex log's It crashed while i was in Phoenix this time
Music Videos show up twice under artist even though there is only a single music video mp4
X-Men - The Animated Series - TheTVDB - Reihenfolge der Folgen in Plex passt nicht
Movies WILL NOT match
TV Media showing RELEASED as January 1,1900
Zwei verschiedene Filme "Ava (2017)" unterscheiden
File deleted
Cosmos Possible Worlds not showing up in Plex
TV show not naming correctly at all
Plex agent idiocracy
Suddenly .LRC files aren't showing up
Enhancement to allow for enable/disable of 3rd party reviews in the Roku client
Is there any way to view the library that the plex tv agent is using?
Is this a labeling issue?
Guide to getting Plex to properly recognize and sort Star Trek shows
Metadata for songs is empty and unable to save edits to correct
DVD Extras showing up in the Movie & on their own
Refresh All Metadata NOT working
TV Show Archer S3 Episode Titles and Description Mismatch
Plex Dance
Show named correctly, but Plex will not pick up in scan - Reno 911!
Album artist incorrectly set as AC/DC for thousands of tracks
[Solved] ALL movies no longer play after update to PMS v1.15.3.835 (s1001 error)
Unable to delete a collection
PMS Analyze not creating preview thumbnails, detecting intros
Missing TV Agents
Multiple locations for 1 library
Bad matching
Help with a movie not adding to Plex
Metadata for episode incorrect after renaming the file
Disassociate File with Movie Title (Two Files Matching Same Title)
Plex does not recogze subtititles (.srt) file
TV Shows Library - need to rebuild
Serie vises ikke i plex
Group Multiple Plex Servers
Duplicate unrelated files turning up
TV shows not matching correctly
Why "Library Upgrade Required"?
I cant get plex to recognize a TV show added to my library
Local Metadata Not Loading Production Order of TV Show
Artist fields with ampersands - "Someone & Someone Else" - confuse artist categories!
Show metadata wrong
Long running TV show won't Scrape
TV Show Titles do not update using Episode - Refresh Metadata, but they do if Refreshed at the Show level
Re-added a TV Shows Folder (oops), now much of the art is missing
Plex not detecting chapters on some files
Plex edition tags no longer automatically adding edition
Prefer Local Metadata and Album Art do not work
New Plex Guide Very Poor in UK
Grouped Episodes
Why can't Plex distinguish between movies that have the same name but are named correctly with the year in the filename?
Sharing:Hide content based on video format
Server is completely ignoring sXXeXX convention for two episodes
Cutting&Pasting a new folder with two VERSIONS into a Plex-managed folder only displays one version
Error code: h4 on every video
I don't understand why
[Runtime-Bug] Library Match Cannot Differentiate Media of Same Name
Unable to Retrieve Metadata for Shows
Why do some tv shows have no Poster and it removes Fix Match etc
Put IMDB and or Rotten Tomatoes rating on my Plex
Not refreshing movie posters
Plex poster blank on duplicate movies?
Pulled metadata for remake instead of original
TV Series "24" will not be recognized by Plex
Adding movies to my library
Add "edition" support to TV-Shows
Can't seem to get Weezer (Blue Album) to load in plex
Music Metadata - Odd Performance of Compilation Albums
Not getting folder thumbnails
One video doesn't show?
Star Wars: Episode IX – The Rise of Skywalker metadata not updating
Star Wars Metadata
Renaming has only made things worse
Plex Music (Scanning a mess)
External subtitles (.srt) troubleshooting checklist
Clear metadata option
Nicht erkannter Film
Plex is picking the title for episodes always from the file properties
Music Metadata (local posters and release type) not ingested after PMS 1.43.1.10540-3972d551c
Scanner not adding a certain movie
TVDB down? Not adding any metadata to TV and website is inaccessible
One season of a show not recognized
Multiple TV shows in one library
Star Trek Picard misreporting as Star Trek Voyager
Marvel's Agents of S.H.I.E.L.D not being detected by PMS, Dropping the H from the title
Missing Episode Titles on TV Series
What is this behaviour?
Plex Media Server Windows - Displays duplicate items in error
Plex doesnt update library correctly after updating MP3 tags, unless i do the plex dance!
Dora (2024) Series Metadata Issue
Can't record a show after an attempt previously errored out
Metadata Plex TV series
Incorrect artist title on unmatched album, in combination with matched compilation album
Multiple Episodes in a Single File (naming) -not working
Libraries not updating
Learning to PlexDance
Plex Dance
Deleted icons on some TV and video files - persist even after library scan
Weirdest music metadata identification problem!?
Library Upgrade from TheTVDB to PlexSeries agent makes 11 of my shows disappear
Plex not tagging TV shows correctly, even when named correctly
Plex Dance
I am having issues adding a TV show to my Plex server
Missing albums
Forced Subtitles Not showing up automatically
Scanning library overwrites custom metadata of existing films - please help
Scanner issue
Folge einer Serie wird nicht erkannt
Sonic Analysis finishing, but features not available for all tracks of one album
Impractical Jokers is not being managed properly
Popeye the Sailor (1933) Metadata
LG Webos (nor Tizen Samsung TV) not loading Subtitles , but iOS plex and Webplayer do OK
Missing specific seasons of TV series but present in database
Cleaning up plex/files?
Clear / Delete / Remove Corrupt Metadata Posters
Folge 264 und 265 werden nicht erkannt
Yet Another Local Media Assets Not Working Thread (Movies, 2020)
Multiple-episode per file still not working
Missing NFO agent and local assets not being used
Plex series
Plex merging two folders together
Doctor Who (1963) episodes are getting bad metadata
Documentary Series Naming - Flat Folder Structure - Natural World vs BBC Documentaries
Episode Ordering Option Missing
Having a problem sorting music
Why are my two Kill Bill movies merging into one movie?
Need help with displying movies and seasons correctly within a single series
Episode Titles not showing up only episode number
Is there a way to prevent file joining?
Can't recognize duplicates movies anymore
Low Plex quality and some films not found
Need to dance for ALL new media
Not getting updated metadata on one show only
Plex cant find a second season of a show even if its named correctly
Can't get TVDB to pull all of my tv show episodes are any of my tv show specials
How to add Kill Bill - The Whole Bloody Affair to my Plex server
Error s1003 (Network) for just one specific movie
Trouble loading libraries
How do i fix the 3 dots. they arent working on each movie etc
Plex not finding Episodes
Plex Album Matching Appears to be Broken - July 2nd
Plex Media Server doesn't update Metadata for some episodes
Problems adding TV shows
Release dates on music albums resetting to January first of the year // disappearing entirely
Removed album still shows up in library
The Three Stooges not showing up under Plex TV Series in Agent
Movies showing screenshots instead of posters
TV episodes get merged together but can't split?
Ogg music shows up as individual albums and other oddities
Seasons added to incorrect parent folder won’t update after move
Set all items in a library to use the same poster
Inconsistent and problematic results with meta data (multiple issues)
Unwanted Stacking of TV Shows with season name for year ie. "S2012E01"
Plex Keeps Auto-Correcting to Wrong Band Name
Plex libraries show the wrong files inside the folders
TV Show Only Matches first episode each season
Server showing duplicate files
TV Episode Titles Correct but Descriptions from Different Similarly-Named Show (Voltron)
Audiobooks - Im unable to get an author's(artist) books(albums) to show in library
Library Folders no longer updating
Matching issue -- Movies and TV Shows
Music CDs: Multidisc Album
PMS not scanning TV shows
Cannot add .hack to plex
TVDB DVD Order Not Pulling Correctly
Most of my media files no longer appear
Where is commercial offset data stored
Plex splits a single-disc album
New movies added to server do not show up on home screen
Episodes match to wrong show
Content
TV Shows not updating
I have 1 movie, that plex refuses to recognize
4400 Not showing up
Modern Marvels Episodes Not Showing Up Correctly
4400 Not showing up
Secondary movie folder NOT pulling in metadata
Plex wrongly matching TV episodes with multiple versions
Plex Dance
Plex Server can't find TV series based on the series ID
TV Show missing from Plex Series
.plexmatch Not Working ... Sometimes
Artist poster blank/not finding for last added artists/albums
How is that possible? Trouble organizing library
Fix 2036 Date
Add option for Recently Added to be based on File Creation Date
Unable to delete file on Plex server from Web interface
TVDB - No matches were found using this agent
2 Friends episodes are being dropped into a "Specials" season. WHY?
Button "Zuordnung Korrigieren" fehlt
Plex finds and then deletes one TV show (Log attached)
Still waiting on a fix to TV shows
Different shows merged to one
Removing videos from Music library
Simpsons - why do some series not populate fully?
Potential bug new update Version 1.22.3.4392
Incorrect artist tag for audio files
Plex not finding tv show
Show remembering wrong starting episode
Managing Theme Music, Posters, and Art with the WebuI and API
Server keep "crashing" since last few beta updates
Library scans result in wildly varying content results for movies, tvshows and music
Will not recognise a TV show
Trouble with separating two films with same name: Ambition (1991)
[BETA] New Plex TV Series Scanner
Plex scans TV show totally incorrect
Plex sorting of episodes
Force credit recognition
"Editions" for Series no longer works
Film not being identified correctly
All My Elton John and Phil Collins albums are showing up under the artist 'Disney.'
'Fix Match' doesn't appear anymore. Only 'match'
HDR tag on non-HDR media
Unable to find newly added movies
Downloaded movie from server is missing english audio stream
TV series uploaded to library not showing up
Popular tracks
Plex detecting two different series as one
Meta Data Issue
Meta Data Issue
Cannot get one TV show to re-appear in Plex after some tag shenanigans
Manque des films ou episodes
Trailer Park boys 1999 movie showing up as 2006 movie
Movie extras not being seen (new Plex Movie agent)
[Bug] Android TV and Mobile - TV extras appearing multiple times
My folder layout is exact but the scanner is skipping the file after a metadata mismatch with my Nas
Plex is referencing two folders for one movie
Posters are not appearing on other remote and local devices except on localhost
Matching SuperFan series
Naming Series with Multiple
Improper Library Labelling & Metadata in Music
Force PMS to refresh XML metadata?
Previously Added Albums Reappearing in Recently Added Playlist
PLex not finding my TV series
New Plex Movie agent not changing metadata properly on "fix match"
Movies being skipped when adding folders
Show "Sunny (2024)" getting incorrect metadata and has multiple tmdb ids
Can I manage to make PLEX recognize properly my season folder?
Plex not following TVDB DVD order for In Living Color
Random rating showing up
Album is split into multiple entries even with the exact same metadata
Searching a track with ' in it using the API doesn't work. [BUG]
Local Extras Display Name Problem
Why did some of my Artist metadata in Music change?
Cannot Match with TVDB - Even After Plex Dance
Total chaos after adding new files
TV show only showing 1 season out of 4
Penelope (2024) Pulling in Children's Show
TVDBdvdorder agent not working?
Plex not recognizing many of my MKV files
"Recently Added" shows movies added in the far future
Naming BSG Mini-Series Files
Not all Files Recognized / added after data relocation
Does the Plex Dance cause library to re-run thumbnails, credits, etc?
I wish Plex would quit displaying prompts for me to upgrade my libraries
The Case of the Missing Seasons & Episodes
TV show episodes all lumped into the same series
Intro detection no longer working
DVR does not wake up PC for recordings
File Naming for TV Series in Plex folders
Plex edited metadata for the wrong TV shows
TV show extra naming conventions not behaving as expected
Having multiple movie cuts and extras
[Forum Preview] Credits Detection for Plex Media Server
Plex isn't scanning new TV shows - Shows are named correctly
Not picking up some content and misnaming/labeling others
Bug: Replacing a media file with a new file and filename, does not update meta field "updatedAt"
Missing movie that was there before
Plex not adding certain episodes of the same show
Title cards for TV series
Music library incorrectly saving ratings
Plex refuses to use local metadata
All of my "Various Artists" albums changed Artist name
Only Some Named Seasons
Plex adds some episodes of a show but not others
Unmatch removes TV season from viewing
TV Shows some show as Seasons some show as episodes - WHy?
No auto match after last update
Music Files Not Found in Scan
Conserve Intros when change directory
Issues with DVD orders not pulling metadata
NCIS episodes showing up under NCIS
FIle Not showing
TV Series poster art?
FIle Not showing
FIle Not showing
Plex movie stuck at same start point
Not determining season of show correctly
Plex Dance
Monty Python Almost the Truth (The Lawyer's Cut) won't add
Sailor Moon Cosmos The Movie Part 2 not being added
Pilot episodes not showing on plex
Plex does not list any other files
Lots of Metadata of Season episodes doesn't show - Need help!
Wrong Metadata for new shows
Plex is badly mangling import of a Music library
Unavailable content
Can't remove corrupt movie
Zuordnung Traumschiff S01E65 inkorrekt
After rescan with new agent, can't find some movies
"How It's Made" Show Titles in Player are Incorrect
Plex Series agent keeps matching me to the wrong for for this one title
Having Issue With Adding Movies
BUG: Naming in Plex is still in the 1980's, why doesn't it respect non-us letters?
Plex created a third season for a TV Show that's supposed to only have two
New Agent pulling themoviedb episode naming when tvdb is selected
If unmatched, prefer local metadata. Else, DON'T
Duplicates without duplicate filename
Naming a two disc movie
Can no longer update library database with sqlite3
I actually like watching rolling end credits
TV episodes not being recognized even though other episodes are recognized correctly
Plex Database Corruption issue
Recent issue - Episodes duplicating to show part 1 & part 2 despite only 1 file
Plex combining different shows into one (fullmetal alchemist and fullmetal alchemist brotherhood)
Local Media Assets Not Working New Plex Movie Agent
Missing posters
Update and clarification using Plex Dance
Dexter New Blood S01EP03 show as own series
Bulk Library Update Needed, SQL Maybe?
Plex won't "forget" a movie after it is deleted (so I can re-add it with new chapter stop names)
Stargate File Naming Convetion - SG1 and Atlantis files mixed/recognized as an SG1 episode
Saved by the Bell series from 1989 and 2020 are being mixed
Just added a Tv Series and it won't show at all ! How do I fix this ? Thank you!
Matching TV-series not possible, even though found on IMDB, and named correctly
The Office (US)/Specials/Threat Level Midnight.mkv not working
Penelope (2024) matches correctly but includes metadata for episodes of Penelope (2006)
The connection to the server is not strong enough to play this movie
Plex wont recognize episode 1000 (or 1000+) of One Piece
Plex TV Series Metadata Source
Incorrect episode thumbnails
Why is my plex identifying all of my 168 shows and then slowly removing them one by one?
Plex TV Series Agent not pulling Season/Episode metadata for Mad Men (2007)
Issue with new Plex TV series agent / scanner
The Great (2020) season metadata not pulling through
Plex categorizing one episode in wrong season
TV Show missing from Plex agent?
Posters not generating on PMS 1.25+
Unable to obtain tvdb metadata for prison break
Issues with Automatic Merge and Plex Movie Agent
Movie names beginning with number show up as weird TV shows (and as movies)
Problem with two movies called "Ride (2018)"
Wild Kratts and Word Girl episode information a mess
Plex Suggestions for Movies/TV Shows/Actors
TheTVDB metadata - V3 API and related issues
Plex and Music Media Management is Dead
Plex Hates id3 tags
Plex created tv show for another show's episodes
Struggling To Get My Server To Recognize TV Series
Plex will not add file to library
Tried to add movie to PLEX, PLEX said already there, searches cannot find movie
Some episodes of a TV series are messed up
How to correct Master List, TV Episode name
One Movie will not Add to Movie Library without Changing Name
SOLUTION: Conversion failed. The transcoder exited due to an error
Turn off the auto-MERGING of video files
Weird matching with partial similar show name
Movie Soundtracks: Do they exist in the Plex world?
TV Episodes not showing correct title
Everything in library is Aqua Teen Hunger Force?
Trying out (and failing with) URL commands
Intros not always automatically detected, Force Analyze doesn't always work, Plex Dance does
Metadata Not Syncing Correctly
Movie will not scan in
How to configure new plex agent
One video file not being found in one PMS, but shows in the other
Files with tags don't show up
Finding an Incorrectly Linked File
Tokyo Ghoul Re
Playback pausing when playing MKV files
Incorrectly naming TV shows
Synology running Plex will not even recognize .mkv files in my TV directory
Artists still exist after removing all files from Music, emptying trash, and cleaning bundles
I believe Thetvdb.com is wrong for this series
Creating a new Library Section
Can not add the movie named 9
Naming my media
New Tv Agent not importing aired date from Local embedded Metadata
Falsche Sortierung Zuletzt in Serien hinzugefügt
Louis Theroux documentaries not found...I tried everything!?
Server not recognizing some files
Plex TV Series show not found, But it is in TVDB
4k TV folder location
Not scanning and adding new Videos of certian types (Maybe)
What's the latest on multiple episodes in the same file? So frustrating!
Tv series metadata mismatch - need to fix naming
Adding additional notes or comments in [square brackets]?
Delete poster
Plex Showing several movies as same
Album Artist being indexed incorrect when Various Artists
Unmatch Duplicate Episodes in TV SHOW
(big) show not getting a poster/episode names despite being matched
Plex Media Server 1.27.2.5929 - support for release type embedded tags
TV spin off series issues: 2 file paths for some reason
Plex can't find the metadata for one of my movies
ALF (1986) Season 02 - TV series not matching episodes correctly
All shows won't load onto PMS
Having a hard time getting plex to recognize certain movies
Not detecting TV media
Plex is creating new/duplicate Tags for Directors and Actors that are already in my server
Single release type not recognised
All players show incorrect/missing filenames
Missing album/artist arts after last update - Shield TV Pro
Trouble with Movies from my media library appearing in plex
Plex is using two files for the same show, but only plays one
Show matched but ALL episodes unmatched
Show recognised but some episodes are unmatched
Specifically True Blood is only showing season 2
Unable to force Plex to see TV episodes from different shows as non-duplicates
Plex Server 1.27.2.5929 (Win11) erkennt nicht alle Dateien
Multiple listings for same actor! Movies not even trying to Match
Multiple Credited Artists (not various artist) -- how best to handle with plex?
New Plex-server doesn't find all TV Shows
Missing Content
Missing Content
Plex will not add episode names to Personal Series
Cannot find/match episodes under folder on some series
A Nightmare on Elm Street - cannot get it to add to my library
How can I found out why Plex only adds one episode of the full series?
Plex not finding meta data for "The Late Show with Stephen Colbert" or "Stephen Colbert"
Trying to add movie but plex still isn’t seeing it
Deleted track still displays in Plex
Files added not showing up or possibly merging
Plex new Matching logic is not working correctly
Moving Metadata from windows to Linux question,
Media Scanner kann nicht auf neuen Content zugreifen
Plex TV Series Matching
Play all in folder and subfolders
Episodes not recognized, "bundled"
Manually add a folder to an Existing TV Show
Plex Server not scanning certain files/folders on QNAP NAS
Mediafiles on synology nas not added in library
Analyze media creates video thumbnails but fails to set them
Certain Plex Shows Buffering
Personal Media: selectively "forgets" posters and portions of metadata
SUPPORT: Plex Is Refusing To Add Media
Local Posters not loading for multiple edition movies
Local artist artwork not used when prefer local metadata is disabled
Issues with fetching updated metadata from TheMovieDB
Songs simply missing and miss identified
Library not uploading most of movies
Stop forcing stuff on us!
Personal media not recognised
Cannot Add "Batman - The Animated Series" OR "Batman (TV Series)" to Library
Library updater does not manually update library media
Plex not recognizing TV shows
Plex creates new albums per newly created track
Anime not being pulled properly
Blank titles in Plexamp, Plex Library has title, edit page does not
Editions and Split Apart movies lose all local extras
Artist Artworks Disappears upon Metadata Refresh
After upgrading certain shows need manual metadata refresh after every scan
New Music not appearing in recently added after being ripped
MyCloud Home and TV Shows
Shows not detected in Folder
Can't replace an old movie
File with weird (doubled? tubed?) audio on Plex for Windows. PMP plays it correctly
No posters or thumbnails using local media agent
Photos no longer displaying thumbnails properly
Plex no me reconoce ningun archivo nuevo
Show is stuck in recently added
How to change the thumbnails
Corrupted cached posters of music artists and albums
Music Matching -- multiple Eminem artist in Plex
Cannot fix match no show to fix match on
Ghostly echo of a TV episode that thinks its a film
Separating discs with different names
Plex won't scan/see just 1 TV Series
Plex Auto Match not working but manual matching works
Plex 1.23.3.4707 not processing Album Compilations with Various Artists anymore. Assigns Track Artist to Album Artist
BUG: Special Features (Extras) are not sorting properly (alphanumerically)
Some movies show in Collection but not main Library
Discussion of Multiple Editions
DVD Order
Plex doesn't always read media with multiple channels as anything other than stereo
Bug plex scan. Help plz
Sometimes a SRT subtitle will not be available even though it is in the correct folder
How do I fix this hot mess of seasons for Pokemon?
Files not showing
Pex not scanning from theTVDB series that are "locked"
Cannot change metadata - Plex defines wrong series etc
Unable to match Astro Boy 1963
Plex is ignoring a media file in the library
Little rascals show / Plex TV agent
Plex isn't finding all the movies in a folder of movies
Plex TV Scanner broken since 1.28.xxx?
How to repair the library on Synology NAS
PLEX Not Scraping All Files
Plex TV Series always Wrong - Always the same false Series
Seeing Same Movie twice in Library referencing same movie file in library
Plex won't pull all my Media onto my server
Music Videos inside The Music Libary
Episode Name when Numbers appear in Title
Titles and Descriptions of Episodes in different languages or missing
Plex can't "see" the episodes
Plex not indexing tv serie
How to deal with diffent series that are belonging together
Wrong listings on some TV shows. Episodes out of order, wrong title
Plex Server adding Japanese Anime as any TV Shows
The Shield and Marvel's Agents of S.H.I.E.L.D are being combined in the latter
Metadata is Wrong Even though Matched with the Correct Show
Synology Server not showing certain files
Not scanning all show level TV Extras
Incorrect album release dates
Unable to un-merge original album and remastered version
Music Media Won't Line Up Correctly For Me
Warum bekomme ich für eine Serie 10 Einträge?
Help with file not being discovered
Plex Server Database
Having trouble getting Plex to show album cover art
Plex no longer detecting a season it previously detected
Plex scanner skipping an episode
Remove ad markers for media items
Plex music categories (Pet Shop Boys)
How to Split Apart episodes
Triaging Sonic Analysis problems?
Why isn't Plex respecting file names for titles?
Tumbnails are screen shots
House of the Dragon Open Intro Theme
Plex web not playing a TV show
QNAP - TV Shows not displaying
Can plex pick up the pictures of my music build into the ID?
Help!? Star Trek TNG Season 3 appears as TOS Season 3
How to remove Sonic Analysis results?
Manage DVR copy and Downloaded copy of TV Show
PlexAmp not following any assigned metadata / track numbers
How Do I name and Organize Pilot episodes
Music file naming conventions issues
Issues with adding files to library and matching
How do I unmatch metadata on a TV show?
In the scanner phase it does not recognize me several MKV movie titles
Plex does not index albums where the first track has a different Artist from the main AlbumArtist
.plexmatch not helping scanner mismatch
Extras not showing up for one movie
Photo timeline order breaked down after some time
Plex doens't find anything inside folders
[Rel] HTTP Anidb Metadata Agent (HAMA)
Find where to watch something with "Discover" and your "Watchlist"
Plex thinks everything is Samurai Cat
Choosing one episode, playing another, trying to edit date, it won't let me
Seasons of TV Show Not Syncing
TV Show not listed in Plex
Music is all lumped into one album named "Various Artists"
Plex TV Series Scanner results in wrong names for Multi-Part Episodes in 'The Weekenders'
[Bug] in Matcher tt0061563 vs. tt0063308
New show the kardashians
Can we disable the reminder to 'upgrade library'?
Plex fails to do Movie - "Scan Library Files" - Quits prematurely
Changed Password And All Worked, Now Everything Is "Unavailable"
Is there an error when "upgrading library" constantly reverting back to
Plex removed one season of Breaking Bad
TV shows not scanning featurettes and other subdirectories
"Fix Match" Won't Let me Search IMDB, TMDB, or TVDB
Plex showing a different date than how file is named ( Custom date-based TV Show)
Changed Music Scanner, Metadata doesn't refresh
Plex fails to detect series (or only one episode per season)
PLEX Not finding random TV seasons
Some shows no metadata yet others have it
Tipps: How I deal with media in "other videos"
Won't play season 4 of Better Call Saul
Sometimes, Plex doesn't download an episode poster, sometimes, it downloads it three times
PMS Has Suddenly Changed "Various Artists" to a Randomly Chosen Artist's Name
TV series split apart not shown in recently added section
Plex analysis triggers incorrect recoding
I've got like five glitches happening at once so here's a video
Library issue
Plex not showing video generated thumbnails for TV shows
Problems in organizing seasons and anime OVAs
Handful of seasons not matching correctly
How do i reset the plex?
Newer PMS versions not adding content
Music Media Move to new location -> Move Media Content to a New Location
Plex not adding previously deleted shows
Shows Missing from Recently Released Episodes
Episode numbers showing up for some episodes but not all in TV Shows Library
Plex is making collections of all 1 movie movies though it is set for 2 or more
PMS not opening on Mac
Single episode not showing any media information
Media library entry
Seems to think s4e14 is the first episode?
Cannot get Split Apart to show up for original Star Trek series
SDH Subtitles in plex showing as "Southern Kurdish"
Plex agent can't find wright tv SHOW
Duplicate Clean-up of Movie Library
Season names are fetched with the wrong language
Not displaying episodes 100 through 199
Episode name is changes to the series name after metadata refresh
Plex shows Music album year one year earlier than the tag
Plex Music Agent Not Honoring Embedded Album Artist Sort Tag
Where to correct metadata on PLEX SERVER
Renamed TV episode files to add "-01" and "-02" on the end - they disappeared from Plex
Adding local extras to a movie not working
Keeps trying to generate chapter thumbnails for a deleted extra
TVDB ordering does not match TVDB for Frontline
Two different Plex servers on same data - one sees episodes, other doesn't
Plex server in Synology NAS not recognizing new content movies
Movies showing unavailable but they are
Thor 3 only works with the wrong file name
Wrong meta data from TMDB
Plex not recognising changes to music files in folder
Deleted Library by mistake... now can't re-add any of those files
Plex Music Agent doesn't show all tracks of an album
Super Sentai TV (meta)series no longer matching
Posters and backgrounds not loading for certain items
When I change my scanner and agent, perform a plex library upgrade, settings do not save
Subtitles Conversion Failed. Transcoder Exited due to error
Plexamp merging artists with similar, but different, tagged artist fields
Does Plex Dance lose music ratings?
Subtitles with foreign audio doesn't work
Editions and Source tags not read by Synology Plex Server Version 1.41.3.9232
Movies not being recognised
Movie Metadata Lost when Deleting Duplicates
Meta Data is randomly wrong
Plex no longer automatically removing TV show episodes
TV shows not showing up correctly
What to do when even the Plex Dance doesn't work?
Plex Series Scanner has serious flaws
Library Scan not recognizing video files after update
Reverting from custom to file metadata
Plex Agent no longer working and Add to Watchlist option is also now gone
My library content is not updated, automatically or manually
Plex Won't Properly Identify Movie File ("A Christmas Story")
First step in Plex dance not working repeatedly
Video preview thumbnails not being created with Scheduled Tasks
Multi-image Collection poster only uses three posters
New episodes imported from Sonarr are not recognized by Plex
A show is in library but plex won’t find
TheTVDB Change Not Being Reflected In Plex
Plex keeps merging one set of content despite proper naming
BUG: Plex Server Bug for Rating Music
Movie file doesnt show
Plex Agents Issue: Can’t Find Metadata for "Brothers" (2024)
Detecting New Added Movies
Some Recently Released Episodes are MISSING
Cannot seem to get a TV show recognised
Library.db size more than doubled in latest version
Subtitles not showing up for tv shows
Plexamp suddenly can't play music from phone/iPad. Browsers can play fine. Anyone else?
Serie "Österreich I (2013)" kann nicht zugeordnet werden
Fix 2036 Date
Plex showing duplicate albums
Mark for rewatch
Plex TV series agent is missing Popeye the Sailor 1933
Plex Server forgetting Edition information and Ignoring {edition-[Edition Name]} naming convention
Plex not detecting some new TV shows I added
Plex matching stopped working suddenly
Help with movie and shows
Garbage Icons on Movies and TV shows
"The Dark Knight Returns (Deluxe Edition)" (2013) refuses to match with anything other than "Part 2"
Plex Database tables seem to contain no data
Baseball season 2 can't Fix Match
Series Unavailable, but Get Info correct
Duplicate Music Albums
Tracks retain their ratings but dissappear from playlist
Plex keeps grouping two different movies as one, even when using {tmdb-id} in directory name
Plex Music - No Unmatch option + Wrong match is forced - C'ect ci ne pas DJ FRESH
Folder removed from [Library] still has content show up under Recently Added in [Library]
Plex not updating metadata from TVDB
Editions not recognized from filename
Plex not reflecting the metadata from the audio files
Missing DVD
Music tracks not showing up in plex music library
Plex Not Sorting Documentaries
Roku Preview has now been updated to the new experience (Plex would love to hear from us)
Tell me what's wrong with my file sorting method
Bug(s): not getting critics' ratings for all TV shows
BUG [v1.41.4.9463] : PMS does not add anymore removed/missing titles to the trash
Can't get Subtitles to work Foreign audio only on one movie
TV watched status and date added being continually reset
Disappearing Episodes in TV Seasons
Not updating from tvdb since updating to 1.32.0.6918
Plex Home Member not Inheriting Plex Pass Benefits - Account Entitlement Bug (Ticket #555604)
Changing Cast and Crew
How to find missing shows in library
Episode Title Not Loading Even With Matched Show
Can't get Plex to recognise a TV show
BUG: Local lyrics not matching for file names with 255+ character paths
Heads up - Generate credits video markers is now live
When changing posters, loading them has been extremely slow for months
Plex Scanner
Name of episode and summary text for TV shows - not consistent: sometimes works, sometimes not
Issue with local theme songs on new PMS update; Season backdrop weirdness
Unable to match specific show
Metadata refresh deletes all posters for certain movies
QNAP - match stops working after 1.41.6.9685
[BUG] Can no longer play any movie without age rating
Ending Credits starts prematurely
1.32.1.6999 not adding new episodes/shows for TV
Issues With Dune and Children Of Dune
The Alfred Hitchcock Hour (1962)
Is music playback history preserved after Plex dance?
This is an odd one... Series disappearing from library, not filesystem. But with a twist!
New movies not getting auto matched, and no luck manual matching either
Scanning anomally
Always the same episode under Last added in series in first place
Plex doesn't pick up newly added videos in my library
[Solved] Files automatically merged, no option to split
Dino Hunters S02E04 will not load Meta Data in Plex
Posters keep using movie scenes
Multiple versions of one TV-show not showing up correctly
Movies in collections take 15 seconds to load extras
Best practice for 'Various Artists' compilation albums?
Some recorded TV shows have the wrong description
Plex Editions/and Version
Plex Won't Order MP3 Tracks Properly (Filenames follow protocol)
New Files Not Appearing After Library Scan
Weird issue with uploading and renaming episodes. Help!
Updating MP3 Tags
TV showing Merging in one
Several issues with uploading ripped media
How should I name these AEW folders so they can all sit nicely in one library?
FLAC Sorting Tags
Scanning TV libray finds episodes, but removes others
Turn off Auto-Collection
I have 2 seasons of dark angel, it's see's 1 season, 1 show only
New Album Releases won't match correctly in plex
Metadata "stuck" on a tv series
The Pink Panther Show wrong metadata
Shows not identifed seperatly
TV Show Deleted Scenes not showing in Plex
Unraid Plex not detecting new episodes
Bug: Chapter metadata not updated when a file is replaced
Unable to recognize Anime file for Demon Slayer
Plex not recognising all my TV shows
Plex Agents
Plex deleted my movie?! Can't add it back
Default Audio Track - Player Defaults to Surround Sound track!
Is there a way to look at the Plex TV scanner database?
Hugh Plex Bug that no one wants to fix
Indian Jones Not listet in movie selection
Plex will not add all my new folders and shows series i long since deleted. Despite scanning library
Denying access due to session lacking permission to transcode key
Shield: Some albums have "disc -1"
Shared Library only listing a single file (even though there are more)
Thetvdb.com series id79173
Some seasons of some TV shows are marked as deleted but all files are present
Missing Movie from Library in Actor Summary
Plex Scanner not working
Multiple groups of Various Artists - is there a way to consolidate?
Lost in Space vs Lost in Space 2018
Server not recognizing media, server mislabeling recognized media
Metadata won't sync for some shows
TV Shows - After adding a new series on my NAS, Plex is not bringing it in when I scan library in Pl
Plex library with links to Prime Video purchased content
FYI... Changes at TMDB with Buffy the Vampire Slayer S03 Episode Order
Plex ordnet Folgen falsch zu
Unable to Update Episode Description Via Agents
Files not found in PLEX
Some content comes and goes when scanning, some content is simply skipped
Video buffers on 3mbit/s but Transcodes fine to 8 Mbit/s?!?
Plex not matching the Survivor (2023) British reboot
Plex sometimes doesn't generate episode thumbnail
Plex sorts properly named media under show i do not have
MasterClass metadata
Plex HTPC/Web slow item loading
[SOLVED] Episodes not recognised when SxEx is in [ ] brackets, possibly due to #13419
Battlestar Galactica - trying to get 1978 and 2004 series into library
Episode Names and Metadata Wrong despite TVDB and IMDB being in agreement
Loudness analysis of tv shows doesn't update after exchanging files
Custom Theme Music Not Working
Request to fix Beavis & Butthead new seasons
Plex Media Server 1.43.5.11079 (Synology DSM 7.4.1) completely ignores a specific 2026 movie ("The B
Playable TV show existed in my library although I never had its source media
Plex Server not updating correctly Synology
One file, 2 seasons, 2 different episodes
Content
PMS doesn't recognize several files download from Youtube
Personal mkv files show in library, but not personal MP4 videos
Why am I transcoding?
Incorrectly Labeled Episodes - Love Hina
Not auto-matching movies
Plex - Not respecting series option of Episode ordering - Plex TV Agent
MusicBrainz and AllMusic Metadata Scanning
How to add Albums with multiple CD's?
Featurettes subtitles
Absolute Series Scanner (for anime mainly)
Is there a way to change the episode order not based on air date?
Does Plex support FLAC "discnumber" tag?
Naming all of MST3k
Plex not importing srt subtitles after indexing library with "\\?\ extended length path prefix"
More than 100 seasons in a show
Naming Of TV Series Gomorrah
Custom metadata not loading
Duplicate movie metadata, problem with smart collections
hunter x hunter 2011 will not show metadata
MP3 tags not recognized - audiobooks
Transcode Error
Can't seem to split TV shows with duplicate matches anymore?
Missing Trailers
Batman: The Animated Series Specials REFUSE to have correct name and metadata
How do I add multiple versions of the same TV show i.e. aired version, extended version, uncut version?
TV Series matching mismatch
Problem with naming formt
Plex not scanning all episodes
METADATA: Why Can't I force a Match?
Plex Not Fetching Metadata or Subs
Not Using Poster Art (Movies - Plex Agent)
Season 3 not showing up in Plex but Season 1 and 2 are fine
Plex TV Series not detecting extras
Metadata not loading for new movies
Plex Fragen allgemein
Plex won't use Filebot named files
TV Show - Missing episodes
Attack on Titan Season 3 showing only the first 12 episodes
Deleted movies not appearing in Plex after re-adding the file
Episodes showing duplicates
Twin Peak and Sabrina Teenage Witch
Playback Error after recent update
Plex not finding some seasons of shows after struggling with it for a while
TV Shows naming odd
Plex server not loading posters and banners properly
WORKAROUND FOUND: Unable to retrieve metadata for a particular show (Star Trek: Short Treks)
Music scanner ignores artist metadata and dumps everything under "Various Artists"
DVR | General Feedback & Issues
Storing movie extras in subfolders doesn't work?
Movie title displays file name even though everything else is matched properly
Plex zeigt für ein File keine Beschreibung an
[REL] TGC (The Great Courses) Metadata Agent
Problem with EXTRAS folders for movies
Can't add new Movies or Tv Shows to Plex
Plex having trouble gathering metadata from daily shows only
Incorrect Rotten Tomatoes Ratings
Another 'please help me find my movie extras & Local Media Assets' post
Unable to match any new items
Plex TheTVDB cache bad?
Movie not being added
Completely remove ALL metadata from videos
Force Generating Thumbnails
TV posters won't download...depending on the PMS
Media compatibility - what could cause a movie to not appear on plex ...?
Origin of the "Plex Dance"
Missing DVD
Frustrated ex-kodi user with episodes/seasons not showing up.
Multiple folders of other shows being added to different show
How to add Unaired pilots or episodes
File nameing
Getting a "Conversion failed. Transcoder crashed or failed to start up" error
Small percentage of files will not pull IMDb metadata
Unable To Find File - File Is Named Right
Library scans always regenerating video chapter thumbnails of new items added since 8502 beta
Ad skipping scans
Help with subtitles
File Matches But Metadata/Poster Doesn't Download Automatically Until PMS Restart
Bug? "Date Added" Display is Incorrect for Separate Album Versions
Multi-version movies split during scheduled task
Cant add a show to my server
What's the trick to ripping a DTS-CD for Plex?
Force Refresh Metadata
TV Show matching issue
Plex Music matching doesn't work except for directories with 1 file
Music Videos not showing up in album - used support article 205568377
Plex Server Not Showing Episode Name
A way to force PLEX to use ONLY my metadata?
Plex Music Artist Picture Question
Directly connect a TV show via url?
Plex not picking up external subtitle files.
Movie (local) Extras and its mysterious ways of not working
Plex intermixing TV shows
Plex not finding shows brought in by Sonarr
No metadata updates
Did the plex dance on my movie library and lost the majority of my metadata
TV Show matching Red Dwarf
No Metadata found in Agents for Some Particular Foreign Movies
Some mp4s not showing up
[Solved] PMS 1.6.1 - Music library & TV Show library refresh
PMS only showing half of my episodes. All episodes named properly.
'Specials' for TV Series not showing up.
New upgrade
Refresh does not actually refresh the metadata
TV Shows not showing what I have
Delete extra uploaded media files
Library duplicates are not removed although the file is deleted.
Battlestar Galactica 2003 & 1978 being consolidated
Plex doesn't identify some episodes
Change to DVD order from Aired order not working?
Removing items from drag and drop poster options?
Assistance with Knight Rider
Downloading Metadata for Things it Already Has Data for?
Subtitled/Dubbed series in two different folders (intentionally) but show up stacked/versions
Meta data and posters missing
2 TV Shows with the same name- help please
Metadata agent changes not sticking
After Password Reset Plex doesn't work on any TV Androud device. Phone and web work fine
Movie agents not fetching metadata
Unable to match ANY film added using all agents
Organization of Recently Added in Shows
The Office Uk and Eastbound & Down
Hundreds of split music albums
Files missing Thumbnails&titles wrong
communication about issues
Episode titles are not adapted to how to fix
BUG: Plex 1.27.0.5897 Erases Track Artists when Album Artist is set to "Various Artists"
Dad's Army (1960's), Dad's Army Lost Episodes (2000)
How do you split a two part movie?
TV shows not being detected
Meta Data
Recently added in Movies
Plex Music Scanner & Matching with Embedded Musicbrainz Tags
Seasons not always showing but already checked naming and permissions
External subtitles not showing
The wrong episode is being played
TVDB Episode Sorting Creating Duplicates
Plex removed artist from my music library after I added "Poster Art"
All of the sudden tv show metadata not loading
Plex Files Unavailable but they’re not missing
Music library refuses to update Artist
Consistent Metadata and Local Extras Issues
Global Music Videos not working properly
Plex series agent not working
Change Movies Date Added to file creation date?
TV Episode shows hundreds of files that do not exist. Cannot remove them
Jeopardy! not scraping correctly
TV show episodes in wrong season
TV shows episodes mixed
Server "crashes" randomly
Trouble matching show with IMDB only
Can't get media to play on either web or Samsung TV
Plex won't recognize new season
South Park Metadata
Library issues with tv shows - Plex is mixing 2 shows into 1
New Albums not showing up in Recently Added Albums
Plex Music scraper naming every album as "Unknown Album]"
Sorting music artists by surname using ALBUMARTISTSORT not working?
There is a bug causing incorrect movie matches during the matching process
Movie naming for a movie with double names I.E. Beetlejuice Beetlejuice
[SOLVED] How to correctly add The Twilight Zone (2019)
Multiple issues with plex
Can you do the Plex dance on your entire server at once?
2 different movies but considered duplicate of 1 movie how you fix?
PLEX movie issue - CPU death spiral
Linus tech tips - The WAN show - Plex issues making Linus considering jellyfin
Wanted to share a trick i figured out with the 100 episode issue
Can't find proper album match
Ran out of storage during Sonic Analysis -- how to clean up?
How to Troubleshoot Ad Detection Problems
Playback Error
Plex Music agent gives no results
Correct Movie Match but incorrect Tags and Crew (Plex Agent)
Replaced items show a 2nd persisting file path as "Unavailable"
Different productions of a movie in library
Music matching not finding existing MusicBrainz entries
The Wolf of Wall Street link cannot be found on Plex
Option to refresh music album metadata
Subtitles not being loaded/found
How find mismatched TV-Series?
Single artist "compilation" routinely recognized as soundtrack
Albums appearing with incorrect artist and unable to change it
Server update has removed TV series cover art
Missing album
Problem with two different editions of The Dark Side of the Moon (Plex dance doesn't help)
Adding a new file...not seen
Plex won't change the agent in the librairies
Movie "49th Parallel" shows up as "The Invaders"
Incorrect image for the actor "John Payne"
Music: Anyway to get Originally Available to use embedded tag date rather than originaldate?
Movies not getting added to Plex
Struggling with Metadata for Looney Toons, lots of episodes
Metadata Vanished - Must Manually Match Now
Plex Amp wont play M4A media anymore
Missing posters: How to force select posters after database restore?
BUG Report: BIF Generation Fails for Replaced Media
New Movie Libary Metadata Not working
Splitted albums
Show Matches, but Episode Titles are Missing
Episode ordering "TheTVDB (Aired)" not fetching latest metadata
Wrong season info
Couldn't load requested content on Roku
Newest files will not play (error message dependent on client used)
Japanese Language issues
Mom TV series
Why the same resource get different episode metadata?
Libraries - Movies and/or Folders Setup
Problems with extras
Episode info not fully loading
Cannot find indexed media after scanning folder
Wrong Title TV Show
TVDB Metadata not populating for shows with many episodes
The Twilight Zone (2019) Season 2 has wrong metadata
Forky Asks a Question not showing up
Plex excluding movie from library despite multiple attempts to force recognition of title
Metadata wont change
Cannot kill link to wrong movie file!
Season 1 episode appearing also in season 2, causing whole season to be off by one
TVDB use DVD order?
Metadata won't update for TV shows
Removed folders from Library - They're still there
One library merging show's with similar titles
Show showing as On Deck, even though not started
[Solved] Plex not processing shows that don't exist in TheTVDB
Missing Files! A lot of troubleshooting done!
Is there a way to know why Plex prefers the wrong metadata?
Different Edit Boxes show different Metadata
STar Trek Picard S00E01 Short Trek is appearing as Star Trek Voyager S00E01
Trying to back up Plex Media Server database on Windows 11
Plex not finding a few movies in my movies folder
TheTVDB Agent not auto matching shows released in 2020
How to manually add optimized versions?
Plex cannot find new srt subtitles
Fix match using TMDB or IMDB ID number
Show metadata wrong
Turn off Automatic collections
Plex Movies
Plex doesn't add Scream (1996) to library
Confused matching after manual match
Music albums broken/unmatched after MusicBrainz schema change (May 11, 2026)
About Plex Scanner and Agent
Plex Not adding a TV show after update
Make media analysis stop wasting CPU on duplicate/repeated analysis
Cosmos: Possible Worlds ep 3,4 no metadata
Getting Plex to use IMDB titles instead of file properties
Movie not downloading meta data (but is matching)
Any chance that plex scanner recognizes a very special show?
Episode order in Plex doesn't match TheTVDB
Manually adding a missing movie?
Sequel of a movie being considered a different version
Thumbnails missing
Start System Scan for Intro and Credits
Can someone from plex team reset my account?
Subtitles (SRT External) still showing on player, even without .srt files in directory
The Larry Sanders Show Season 02 incorrect for me even on tvdb
Thumbnails missing
Not adding media from TV folder
Plex is not showing Old tv series (A Date with the Angels) Betty White 1957
Naming of TV shows does not seem to affect the name inside plex
Same name program. Different episodes
Movies Staying At Frount of Recently Added Movies
Plex Movie Agent not working today?
Scanning match Algorithm needs work
Nonexistant duplicate movie with no option to delete
En mappe under SERIER har delt sig?
Scan library files constantly misses out one specific film
Serien Kapitel Bilder ausschalten
DBRepair development
Plex keep adding entries of the same movie in my library, now more than 400
Hardlinking Files for Graceful Rename, Plex doesn't show any duplicates as I expect
Music Metadata, Artwork, and Scanner Options
Can not detect MKV files
Plex Dance
Skip Intro Status & Stats?
Binhex-plex on UNRAID - new movies/tv shows not adding
Incorrect episodes shown - Saved by the Bell
One FLAC album not added by Plex scanner. Metadata issue?
Multiple subtitle issues
Music: Plex clients do not read albums with Release Date of 1969-12-31 or 1970-01-01
New album for existing artist shows as duplicate artist
Plex finds some files but not others
How to get rid of some details in properties
Plex UI not displaying content
Simpsons S00E78 metadata not populating
Plex Not Creating Chapter Thumbnails for Extras Grrrrr!
Metadata for TV Show Specials That Are In thetvdb.com
Incorrect/Missing DVD Order for The Office (US) Season 4
Missing pictures
Restoring deleted TV shows from library - how to?
Plex does not see/scan Subtitles on some of my libraries
Need assistance on how to fix title of TV seasons
Plex Series Agent Provides wrong data for Wonderoos
Why does PMS run "Plex Commercial Skipper.exe" randomly for hours at night?
How do you force the Plex scanner to see a file?
Showing Dup Episodes on my plex player
Can't add BBC Documentaries from TheTVDB (Named w/ Plex formatter and FileBot)
Troubleshooting TV Show Editions feature on "Doctor Who (1963)" animated media
TV show not showing up
How to remove all missing files from library?
Remove show from "Recently added..." list
Specific movie pages won't load on new FireTV UI
Specific show/file has incorrect resolution/aspect ratio
Other media changes to same name when one name was changed
TV Shows Not Adding to TV Show Library but adding to Other Library's Without Issue
Probelms with .plexmatch and unrecognized shows
Episode info for Fringe, Jonathan Strange not handled
Plex thinks David Byrne did all Peter Gabriel albums
Mismatch Meta Data - Option to Fix Mismatch in dropdown menus missing
4400 Not showing up
Once again, frustration with Plex Music
Plex Using Metadata Title Instead of Movie Title
Elite S00E01-E03 not assigning properly
Missing Files
Some Albums do not let their Artist be renamed, won't sync
Please help a complete amateur fix my Night Gallery folder!
Cannot match "The Umbrella Academy"
Pride and Prejudice TV Mini Series
MetaData & library issue
Certain 4K UHD Bluray titles showing as Unknown on Plex with Shield Pro
Plex getting confused on NCIS metadata
TV show is spontaneously "unmatching" itself
Library Issue
Video thumbnails not being generated for one set of files
TV Show file size limitation
Popular tracks
Why do the developers hate "Other video" users?
Player won't add media, makes no sense
Plex Embed Episode titles in non matching media
Forget Audio and Subtitle Selection after XXX days or Watched
Avett Brother vs. Everly Brothers - Metadata are WRONG and edits do not stick
Plex is not identifying items in my library
Some of the shows eiter show more seasons that there actually is and some shows combine 2 or seasons as one
Movie Verified On Hard Disk - Plays In Media Player - Completely ignored by Plex?
Trying to add a folder to a Library without success
TV Shows Not Found
How to add Concert Movies?
Impossible to remove the trailer from the film file
The TVDB File Renamer for Plex (no API key or FileBot needed)
Error code 1001 on all new material
Trash can icon? Not sure why I'm getting it
PLEX doesn't recognize my TV series. Why?
Editions not working as advertised
Local files for Trailers and Extras being counted as Movie duplicates/parts using Extras Subdirectory method
Plex Media Server 1.30.1.6497 keeps crashing and restarting
After upgrading movie quality, it shows both instead of the new one
How is HDR filter determined?
Plex incorrectly merging different series
Undeletable movies/shows/trailer/extras in plex
Plex Messing Up TV Show Titles + Details
The Media Server doesn't scan SSA/ASS external subtitles
Star Wars - Attack of the Clones: Won't recognize behind the scenes content
Plex Combining separate TV series
TV Series-Scanner mal wieder (Lindenstraße)
The Traitors New Blood not being picked up by Plex
Combining different tv shows
Optimise database and clean bundles saves 200GB
Plex doesn't see my Anime
Bug: changing an item's file name does not update the metadata field "updatedAt"
Conversion failed. The transcoder failed to start up (external subtitles *.srt)
Skip Intro
After updating the button plex to display the trailer location disappeared
Plex and also Filebot are not getting naming correct
New Feature: Albums / Single & EPs / Live Albums
Requested a part that does not exist:337787
Plex not displaying seasons
Moving files from Movie to TV Show
Bug in legacy localmedia agent prevent year based seasons from pulling in subtitles
Music - Artist Missing After Merge - Tried almost everything to fix!
Cannot change episode thumbnail after episode number correction
TV Scanner returning incorrect result
Plex Server Won't Recognize Specific Folder
New Plex Movie agent gets wrong title if it’s non-English(latin) movie
Plex TV Series agent has some issues with anime
Missing folder
Is "Into The Dark" tvdb id matching ever going to be fixed
Plex Absolutele refused to detect TV show "Snagglepuss"
Trouble getting PBS Baseball by Ken Burns to be recognized
Plex Dance
Plex Not Naming Episodes
Multiple "Various Artists" listed
Audio Track Loudness Analysis Slow - loudnorm vs. ebur128
Tosh.0 Not Importing
Please bring Skip Intro to Chromecast - hundreds of millions devices out there
Posters/Background not showing
TV Show episodes being detected as Movies
Category disappeared on users laptop
General full upload help
Shows stuck in 'recently added'
Plex on QNAP can't catalogue New Doctor Who even with tmdb ID in file name
Photo Timeline Out of Order and Photos in Wrong Date
Says "No content" but folder has video files inside!
Force Title & Sort Title to same as Original Title
Unable to locate local assets, unable to match
Plex does not recognize mkv and avi files I have added to my server in the past few weeks
How do you erase library when Happy Dance doesnt work anymore
Scanning Library not finding "Specials" folder after making changes to a TV series
Forced subtitles default behavior not working
Plex's File Matching is Really Broken
Is there a way to force Plex to use the metadata?
Music Library Scan Does Not Pick Up New Files
Multi-version movie not working for me
How do I get my music library correct after many changes to meta data?
Plex keeps combining 2 different versions of same album
Issue with Chefs Table - rename detected - unable to add season 08 completely
Wrong tv Shows metadata
Inquiry on File naming issue
Importing different versions of same album title results in tracks mixed randomly between albums
Pokemon is getting the wrong show titles for Season 1
Odd problem detecting TV Shows (does not appear to be the usual naming problem)
Trouble showing Sub-Episodes (eg. E15, E15a, E15b)
Media Center Upgrade does not index any newly added episodes or series
Three movies don't show in dash when playing
Tokyo Ghoul Re
Refresh Metadata grabbing wrong metadata
New TV Shows not having meta data added
Plex won't fetch some metadata for some episodes of a series
Why one of the episodes is displayed separately from the whole season? And how to fix it?
Stop matching shows as "sifir bir"
Plex server has decided to mix my files together screwing up several cd folders
Playing One Movie, Two Different Versions Showing in "Continue Watching"
Movie Unavailable after adding local extras
TV Shows not appearing
Loudness data and Waveform data disappeared on library move
Problem adding Terry Pratchett TV Shows
Shows missing in watch.plex.tv database
Track 0 Music Tracks not getting a plex track id
Plex Not Differentiating Between Two Different Shows
Scanner Removing Match
Re-ripped album will not display in Plex library
Scanning Library Files refreshed all Metadata causing unmatching to occur
External subtitles disappearing from Plex
Replaced files in a TV series, all episode art is different
[Solved] Photo Timeline Out of Order and Photos in Wrong Date
Not generating video preview thumbnails
Plex erkennt gleiche Folge, zwei Dateien mit zwei Sprachen nicht
Exception assimilating media item
Update and modify collection
Missing TV Shows
Losing newly added media and not a full library
Plex is not reading proper tags
Loss of Library control after recent update
Artwork Switched to Low Resolution in Some Cases
My plex server don't recognize some videos files storing in my NAS
Other Editions of [movie] - section missing
How to Clear Cache on Synology?
20% of my movies are not being recognized
Delete from library option gone
Messy Dr Who Universe
TV Episodes Duplicate Bugs
Plex hiding video because of the name of the band
Problems with TV Shows associated to wrong series
Can't get .plexmatch to work for NCIS
Plex recently added items stuck
Plex doesn't recognize files?
Starting out from scratch
(Music) Read in album-sort tags
Tried everything but Plex always misidentifies artist!?
Missing seasons that once were present
PMS database is not updating Version 1.28.2.6151
Update unable to find certain shows (named correctly)
Closed Captions with Unknown (Closed Captions) Seen But Won't Start Automatically
TV Shows appear in one Library fine but missing episodes in different Library
Plexamp - Album Collections point to the wrong collection on mobile & mac
Disney Animated Shorts (1921) not pulling season/episode metadata
Certain recorded episodes not added to library
Diiferent Extras/Featurettes for Different Versions of a Movie
Why manually entered metadata are not sticking to the file
Consistently Tagged/Stored Files Albums By Artist are still sorted inconsistently
Sonic Analysis keeps getting stuck
Library Not updating/ adding new files (synology 920+ DSM7)
Can't redetect deleted TV Series
Impossible to get a match for one of my shows over multiple years, even though the metadata is available and up to date on theTVDB
Any Way to Turn Off the "Upgrade Libraries" Notification
Disappearing seasons
Error loading lyrics
Struggling with SpongeBob Season 2 episode listing order
Plex Scanner Season not showing up
How to add again deleted movie titles in the library?. (I don't remember which movie files they are)
Using Rclone to Google Drive for Plex library… not pulling everything into Plex library
Meta data not showing up
Rather complicated mess up
Plex showing season "unavailable" but it is available and I can play the episodes
Aaargh cannot add music
Plex wont load/see pilot episode but will see other episodes of the show (ep2, 3, etc) in same dir
Actor Metadata
What is my naming mistake?
Fix Match not showing for some shows
Search Plex DB file for album in library other than Music
Delete poster
Metadata Error - Missing parameters for match request
Cannot fix, remove or unmatch movie
Live TV EPG - The update you’ve been waiting for
Plex randomly missing episodes
Bug: Music Library: separate album when adding additional files
File Name Corruption
New TV Episodes Only Show Up Under Recently Added
TV Shows not choosing Images (Poster/Background/etc) on Synology NAS install
Recent addtions not loading on home page
TV Show not being seen by Plex at all
Analyse process freezes
Sever not recognising TV show season
Theme Music, Renaming TV Shows, and Extracting uploaded posters and covers
Mac PMS 1.29.1.6276 Crashed (First Ever), Seems Corrupted Library & or Host Files—1.28 Now Unstable
SOLUTION: DVR recordings not showing up in library
Finding a misallocated file
Plex not seeing Season 3 of Brady Bunch
Season Level Extras are not showing up on iOS
Newly added movies don't appear in Plex
TV meta data not correct
Plex music agent(s) Suck
My Series matching hasn't worked in over a year
PLex I love ya but sometimes your Metadata finder is just broken
Lyrics could not be loaded
Plex can't see files in one music folder
New TV Shows and Movies going into a new index or database issues, search issues and visual glitches
Deleted titles still shows after physical deletion
Re-scanning previously deleted library items
Tvdb changed/updated order of episodes, but Plex is still showing old order, even after Plex Dance
Interpret posters and album covers are all wrong
Plex Scanner not picking up episodes from the directory
Titles Never Get Put in the Trash
Bug with episode naming
All new shows adding with a date of 2036-02-07 (Plex TV Series Agent)
Naming movies
Not all my photos show
Wrong released date on tv episodes
Plex Agent TV Series - keeps miss-matching for new file in a folder, where already match fixed
Cannot fix match
Does Plex TV Series agent have a database?
Plex only sees episode 1 of ripped DVD
Plex refuses to fetch episode artwork
Poor Plex metadata for Battlestar Galactica
Incorrect artist art coming by default
WCW Thunder Not Scanning All Episodes
Moving to Smart Movie Collections
Some files are not detected
No matter the setting Plex wont detect credits
Scanning is not updating a single TV Series (entire show just stopped showing up after Plex Dance)
Plex mergeing Unrelated Files
Issues scraping TV shows with correct naming and valid IDs” o “Half of TV episodes not matching desp
The same number of albums queued for Sonic Analysis
Movie and sequel match correctly but won't both show at the same time
Various Artists getting split (almost) per song
Artist picture replacing album art
Mother (2017 Short) and mother! (2017) unable to split apart
Manche lokale Cover in Musik / Hörbuch Mediathek werden nicht angezeigt
Where are the logos sourced?
Help Tv shows not showing properly
Same three shows stuck are front of Recently Added TV Shows
Seasons and episodes still assigned to a deleted series
Transformers: War for Cybertron: Kingdom merged with Siege
Issue with Series not being reckonized
Can't make editions to work
Incorrect Metadata for a Show
Plex randomly stopped detecting new media that's added, but a scan of the library will see it
Plex not matching TVDB order for Bizzare Foods series
Add to Watchlist button missing for movies
Plex is not using local metadata for Album Artist and Artist
Please Add 'Scan Library Files' Option to Plexamp
Music Album Repeat
Plex Agent seemingly ignoring TVDB ID forced matching
Sdh in sub folder issue
Sort library by critic ratings multiple issues encountered
Is it possible to force Plex to use only my metadata?
Plex not seeing new path after folder moved
Genre Tags Don't Update
Credit Detection not working
Plex not showing a lot of movies in some folers
Plex doesn't match movies or tv shows
Falsche Filmzuordnung
Episodes matching between TvDB and TMDB failes across seasons?
Not possible to differ two movies
When adding a new folder to library (Tv Shows) getting "Your changes could not be saved."
Incorrect trailer for movie "No Deposit, No Return"
All media libraries populated except one...and a question about "upgrading libraries"
Metadata episode ordering does not follow the library settings
Plex splitting album despite same album artist
End Credits Button Disappears Way Too Quickly!
PMS - Synology - not picking up all files
Plex not picking up any matches as of 3 days ago
Posters constantly changing is infuriating
Multiple File Names for 1 Episode
Placement of New Movies on Home Page
Connection to NAS
Plex Not Respecting Audio Language Tag
Plex errors after Server migration part 17
Delay in Pulling Info from TVDB
Disappearing Music/Artists
Metadata issue
Backup and restore Accounts table when wiping out DB to avoid resharing?
Plex doing what it wants
Movies disappearing then reappearing
Plex not adding or removing files
Plex TV Series Agent issues matching
Plex Music - album is matched, but shows up as wrong type
Errors when I have a DVR TV Show library and separate TV Shows library
Plex refuses to allow a particular artist to exist in library, always retags it as Various Artists
Brooklyn 99 is always at the front of recently added?
Difficulty adding show with more than 100 seasons
Displayed title not matching TMDb title
Music Library: 'Split Apart' option not there?
How to correct 'Recently Added' not reporting correctly
Transcoder failed to start up. No posted fixes worked
Plex says direct play, however it's being transcoded and video is skipping
Some movies are uniquely recognized
Lonesome dove 4 part TV series will not load
Plex server re-install lost 99.9% of cover graphics
Plex DVR lost episode after I messed with it
Can't Mark Episode Watched
Duplicates
Duplicates
Plex Agent unable to match movie
TV Show Extras not showing up
Can't Load V 1983 mini series in TV Shows
Old/Wrong Metadate from tvdb and tmdb
Unable to separate files
Skip Intro Button won't show on all shows
Merged Movies show as bit rate not name
Adding home media as a tv series with my own titles
No skip intro on certain seasons of a show ? help
Plex tags two Frasier episodes as episodes of "La Cloche Tibetaine"
Help - show coming up as wrong season!
Not pulling all track artist information for Various Artist albums
Match does not work for new file
Issues with improper match for Traitors AU and Traitors UK TV shows
Older Version
Shows not adding to plex
New shows not coming up
Less than 1/4 of a series that I imported show up in PLEX but are in my PLEX folder
[HELP] Album not going into the correct category
Plex not playing nice - Highlander 1992 TV show
Plex won't generate video preview thumbnails for television shows after turning the settings on
My agent plex media is not working
Sorting and matching not working
[SOLVED] Tracks listed in wrong album
Problem loading Marvel Netflix shows [solved]
BUG: Sorting Artist Name
The show 'xxx' has unmatched leaves, and show was matched
Plex Media Scanner CLI tool issue: Always Abort
Music scanning fails to update/rescan metadata when media updates
Moved PMS to new system and now cannot add movies to library
Sort by title setting changes automatically
Fixing metadata on two OTA shows that always fail
TV Shows naming odd
How can I force Loudness Analysis on a movie or episode?
What to do if an artist doesn't show up?
Watched status for 100+ episodes not working
Same/similar movie names, HELP!~
File deleted
Problems getting my TV shows to play
Tokyo Ghoul Re
Metadata not working / incomplete
Local TV Extras Agent
Want localized titles and fully update a library to get new data = don't work
Yet Another Local Media Assets Not Working Thread (Movies, 2020)
“Recently Added” randomly showing a specific episode that was NOT recently added
Metadata not downloading for new episodes. Please help.
Plex won't change / adjust Title or Sort Title
Plex won't load a TV show, with the Episode name 'Sample'
File Names
Some TV Shows Not Downloading Artwork
Tv Shows Metadata and Scanner - Somes series not coming up
Doctor Who (series 14) 2023/2024+
Bug: Plex scanner may ignore or destroy directory depending on contents
Two TV shows with same name (different years) - one not showing
Plex Media Server not adding episode 3 of TV show's
Plex Not Reading Proper TVDB Metadata
Episode names/metadata not loading
Magnificent Seven (old & new)
Can't Get "Digimon: Digital Monsters" Metadata
Can't change the case of Director's name
Handbrake: What am i doing wrong on Audio and Subtitles
Plex Not Recognizing TV Shows
TV Show not adding despite being formatted correctly
Where do we report 'Plex Movie' Agent Problems - Dumb and Dumber
PlexKodiConnect: Kodi Plex Integration Done Right
Viewing music library by *my* embedded genre
Video content only show half of it in plex
Two TV Series with same name but different years - cannot get both to show in Plex
All tracks on unrecognised albums named the same
Matching Albums - Not including correct info
Tv Shows Not Recognized
No "Match" of "Fix Match" option in TV shows section
Changed file dates, but still at the front of recently added
[REL] YouTube Metadata Agent
Plex shows no content after doing the Plex Dance. Server cannot be found
How to show title of Looney Tunes episodes
Library scan not scanning all photos
Plex on qnap server - TV library grouping all under one name
Metadata are not set for Movies on Synology
Plex for Music – small wishlist
Plex not detecting TV Shows! Please HELP!
Plex Not Downloading Metadata For TV Show
After renaming movies, ~250 share exactly same metadata
TV series with each episode in multiple parts e.g. S01E01P1
Only audio with blurred visuals on some mkv files
PMS hittar inte text trots att de heter samma *???*
Music Library Doesn't Get Artist or Album Artwork
Using Plex SQLite binary to update added_at field
The Movie Database wont pull content ratings
LG Webos (nor Tizen Samsung TV) not loading Subtitles , but iOS plex and Webplayer do OK
X-Files episode names not matching
Plex Hates id3 tags
Plex is selecting forced subtitles over regular subtitles
Plex Music showing a specific artists name instead of "Various"
Nvidia Shield 2019 4K Dolby Vision+Atmos direct play buffering
Done the dance etc - cannot get "Tin Star" to show up
[Ubuntu 16.04.6] Inconsistent matching of TV Episodes despite consistent naming schema
Plex Music indexer - FLAC artist albums indexed incorrectly as 'Various Artists' - BUG?
Classic Doctor Who No Metadata
TMDB episode name is not reflected
Plex is not listing the artist in my music library for some tracks
Plex matching a new show/ episode to another shows episode (x2)
New Plex Media Server TV show/series scanner and agent preview
TV Show artwork refusing to show
Naming Files for Plex
One single movie not matched?
Musik-Alben zusammenfassen
Show titles not matching thetvdb's titles / order
Subtitles shown as "None" if i dont refresh metadata
Tokyo Ghoul Re
BUG - Audio problems during playback
PLEX Movie Agent
TV Show Tagging is all mixed up!
issues with episodes not displaying for three specific TV series
Better support for albums and tracks with multiple artists
Plex Folder View - folder.jpg not recognized?
Plex not naming the subsequent episodes of multi episode files properly
Rescan ID3 Tags?
Rescan ID3 Tags?
Movie listed many times with multiple parts and different sources
Part 1 and Part 2 showing as one file.
"Plex Dance": Should the Plex Team spend the time to fix this?
Problem with library files
Movie Metadata Not Downloading
Various Artists and Kiss
Naming convention with HD and 4K with different file extensions
How to Remove or Disable 'Popular Tracks'
Matched but some episodes were not named
PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
Plex cant find my movie
Metadata not updating!
Plex Library
Odd matching with Mp3 Files
Problems with multipart naming of miniseries
Deletes "Gotham" Every Night
Wrong movie indexing
New Experience Public Release Feedback
PMS and MKV Header Info
Plex gets the file names wrong... its reading the XMP/IPTC data NOT the file name
Plex doesn't recognize some movies / TV shows on a fresh install
Unable to frefresh Meta Data
Plex will not download meta data for some movies
Fixing Unmatched Movies
Léon: The Professional (1994) Not indexing
Why is the 'Plex Dance' even a thing?
plex can't find Spartacus - Gods of the Arena
Avatar The Last Airbender Not Showing Up
Wrong/Old Tvdb ID for "Alien: Earth" Show
Metadata no longer being updated / downloaded
PMS Version 1.12.3.4973 won't empty trash?
New photos "Places" feature?
New upgrade
TV media naming: will using year instead of season number work (e.g. 1976 instead of 01)?
How can I correct Plex not finding a TV Show On Disk
Plex just said f**k all my local music metadata - help!
Is there a way to scan a single tv show instead of the whole Tv Shows library?
Music Issue
Music Issue
Archer is being shown as Doctor Who in Plex library
Plex + Nas AS3104T, subtitles not recognized
Plex recognizes a docuseries as movies, but not a tv series, leading to organization issue
Plex Mix completely stopped working
(UPDATED with VIDEOS) December Plex Pass Community Roundtables
Plex - Fails to update after updating tags
Wrong movie metadata showing up
Playback Error occurs when trying to play video after editing its file name
Plex can't find Luther Metadata
Plex changing movie title even though it's locked
Plex displaying incorrect metadata for TV shows
Why is Plex only recognizing some of my Tv show episodes (files are named correctly)
Feature I'd love to see (Win + PS4)
Plex Not Pulling Movie Posters For Newly Added Movies But Is Still Finding Metadata
TV Show Naming Conventions
Missing episodes
Wrong Metadata on Series (TV-Show Series)
No matter how I name them, not a single part of a tv serie, from dvd, is shown in Plex
TV Shows getting mixed together
Plex and TMDB
Music collects by track artist. not album artist
How to mirror tags update to library?
DVD Ordering not working?
Deleting Library - Didn't add library properly
Edi cast
Library scan keeps marking shows as unwatched, and removing seasons
Verständnis Frage zu Serien Episoden
Have SILLY Question of Movie Structure
Plex TV Agent Pulling Data From Wrong Season (Super Friends)
Refresh Metadata by Folder?
Films not showing up in Plex
Subtitles - Help Please
New music items not showing in Recently Added
Issue with TV extras
How do I clear a music library of all albums/tracks?
Plex confusing two shows as same show
Auto Play Apple TV
Possible New Bug in file name detection?
Unmatched episodes from specific season, why?
Plex mixing my shows
Trying to add Show - Not appearing/matching
Space- 1999 (1975) Season 1 Not Reading
Many various artists compilations showing up with artist as Gas
Deleted content still showing in player not certain if it is the player(s) or Server
What is the best way to fix comma separated artist names for a huge library?
Certain Default Artist Images Kill my Plex Server
Anomalies in Plexamp's Tidal Artist Sonic Recommendations
SOLVED: Slow Show Loads in 'Continue Watching'
Metadata to list album as „live album“?
Scan Library Files suddenly does not pick up new videos
Intro and credit detection
Fbi series incorrect match
TV Show Not Scanning In - "Haha, You Clowns"
Plex Music library won't find newly added content
Fix-match & Tvdb
Narcos mexico season 1 not being picked up by plex
Lord of the Rings Pathing
Compilations not recognized
Removed a show - Did The Plex Dance ™ and more - Nothing changed
Only 1 sub-subfolder showing up
Attempting to create a separate library for music mixes/various artists
Space Above And Beyond Naming Issue
Plex local posters not applying to media
Plex uses search results instead of metadata tags (like title)
Split ROMs
Subtitles not working with TV Show extras?
How do so many mis labeled movies happen?
TV: Plex will not add/recognize TV show despite hint to TVDB
Matching but no posters or metadata
TV series grouping issue
Skip intro outro not working after turned on
Option to remove / delete files from Plex without deleting it from disk
Sonic Analysis, do folks bother with it?
Local asset selection priority has changed?
Plex giving movies old movie titles even after I change them
[BUG] Untold (2021), Season 2, Episodes 1 & 2 are misnamed
Movie not showing up in library
Plex won't add a show
Sortierung von Serien und deren Bonus/Pilot Filme
Plex Media Server won't add TV shows
Plex Update 1.24.0.4930 plays wrong file
Plex refuses to get metadata for a TV show
Multi-episode naming now broken?
Files not being picked up even with correct naming conventions
Modern Marvels: Modern Marvels (1992) S01E03 Panama Canal is showing up wrong
Still having problems with Doctor Who files
Buffer overflows in Plex Commercial Skipper
Shaggy is Being Listed as Adele (Can't Change)
TVDB Aired Date Order Being Ignored
Adding TV shows disc with multiple episodes(4 per disc)
Plex re-recording existing episodes
TVDB isn't matching my show correctly
Pinned support topic for metadata in Plex TV Series agent that needs fixing?
Wrong season info
Wrong season info
TV Shows not showing names or posters
Wrong season info
New Movies not showing up in library
How to ignore TV directories with .plexignore?
Audiobook wrong metadata
Collections shows single movies as "Collections"
Why my files will not be read by plex media server
Plex can't see embedded or external local Album cover art ever since updating to 1.43.0
TV Show Stopped adding metadata mid way through season
Unable to obtain tvdb metadata for prison break
Why doesn't LOCK mean LOCK when editing content details?
Movies WILL NOT match
Same media constantly "Finished Processing" over and over
TV Seasons disappearing
Does Plex have something against Willie Nelson or is something wrong (Solved)
Is there any way to view the library that the plex tv agent is using?
Metadata missing on some shows no matter how many times I refresh it
Plex in Music Libraries in 2023... updates?
New media in the movies library matches to wrong existing movies
Guide to getting Plex to properly recognize and sort Star Trek shows
Macgyver and Macgyver 2016 not in 2 different series
[BUG] Seasons not showing in Library
TVDB DVD Order Not Pulling Correctly
Anybody else have the movie "The 33" disapear
How to resolve / force improper naming?
Problem downloading artwork from TMDB (Argentina Users)
Cross Season File Duplication Problem
Scanner ignoring partial scan settings, rescans all 4k movies
Disassociate File with Movie Title (Two Files Matching Same Title)
Missing Tron_2.mp4 movie file
Coming Soon trailers in separate library
Doctor Who (1963) not differentiated from Doctor Who (2005)
Can't match poster of the movie Back to Black (tt21261712) with Plex Movie Agent
Issue with TV Show Stuck (US) (2022): TVDB 416590
Metadata for episode incorrect after renaming the file
Cannot fetch artwork metadata for one item only, text fetches correctly
Unable to match show for Tintin
Single Video File Containing Two episodes
Help - Nvidia Shield - corrupted database, and web app is unusable
Alias Grace TV show not adding to plex-broken link when clicking on episodes list
Refresh Metadata does not work. Unmatch & Rematch does work and brings in new metadata
Show metadata wrong
Recently Released Episodes (for TV Series)
Having trouble getting a new movie, Emma (2020), to shop up in my library
Server not fetching TVDB metadata for specific shows
Refreshing folder doesn't match entries despite .plexmatch file
Can't for the life of me get Tom and Jerry added 4.22
Plex not picking up on a few seasons of a show I have
I don't understand why
I need help resetting my server
Incorrect episode thumbnails
Optimal file type for PLEX
Recently added movies strange behaviour
Music albums are shown as individual songs
Is there a limit to the number of extras for a movie?
Title does not stay when edited
Digimon Adventure: 2020 naming
How to add missing actor
Two movies showing as one in Plex
No Movie Metadata for new Files
Plex isn't pulling season titles from TVDB
Trying to upload Star Wars 9 to server and after scan of library, plex doesn't port movie. Suggestions?
Series split on Plex homepage
Renaming has only made things worse
Unable to play second part of episode
External subtitles (.srt) troubleshooting checklist
Metadata for TV Series Motherland: Fort Salem
Bordertown (2016) vs. Bordertown (FI) (2016)
New metadata agent options not being used
Way to fix theTVDB matching directly in the data? which table?
Episodes messed up on DVD order of show
Plex not pulling metadata for "His Dark Materials (2019)"
Show "Sunny (2024)" getting incorrect metadata and has multiple tmdb ids
Any way to set default poster for unmatched content?
No poster art for movies
Default All Clients to Max Internet Streaming
Samurai Jack - Titles not matching with TVDB listing
Library shows data which no longer exists
Plex Dance
Plex not tagging TV shows correctly, even when named correctly
One season of a show not recognized
Metadata not updating/reading properly
Having issues finding seasons for a series
Music-Single Artist with multiple tracks under single album show as individual albums
Episodes won't show up in search for weeks?
Renaming files -- do I need to completely re-import my library?
Not getting metadata on titles include a ":"
Movie Library Help
Naming convention for original tv series
Change Metadata
Issue with new Plex TV series agent / scanner
Episode Naming Issues vs IMDB/TVDB?
Server problems
Missing NFO agent and local assets not being used
Two Part TV Show Only Playing 2nd Part
How best to manage Music?
Need help with displying movies and seasons correctly within a single series
[CreditsDetectionManager] Mis-matching media items detected, skipping
Plex Media Sever does not recognize series correctly
After changing the TV ordering plex://season dashboard gets all messed up
Not able to match specific (adult) films from TheMovieDB
Metadata Language is mixed
New TV series Bug
The Three Stooges not showing up under Plex TV Series in Agent
TV shows won't show up on Plex
Plex server not adding videos
Can't see "Blue Planet II" TV series, but "Planet Earth II" works
Plex Album Matching Appears to be Broken - July 2nd
Plex can't find file associated with this item - just created a new library
Meta data not being picked up automatically
French film "La Grande Bouffe" is not recognised
Artist not listing all albums
Arrow Blood Rush issue
Set all items in a library to use the same poster
PMS. Linux Server Random Crash/Unavailable
Setting up a new computer as a server and not generating thumbnails for old files only new ones
Is there a way to prevent file joining?
Plex Keeps Auto-Correcting to Wrong Band Name
Actualizar identificación
Matching issue -- Movies and TV Shows
Plex won't "forget" a movie after it is deleted (so I can re-add it with new chapter stop names)
Random bits being labeled as ads
PMS not scanning TV shows
Plex Music - wrong artist showing?
Yet another duplicate album topic
3 artists with the same name; only 1 is in MusicBrainz... How to set up metadata?
Random photo thumbnails missing since May 2021
TV program with metadata ONLY in the first season
Files not matching whats actually there
Unable to detect a replaced file
Plex splits a single-disc album
Some content not appearing on my server
Wrong Movie Title
[BETA] New Plex TV Series Scanner
[implemented] Hide Plex "Skip Intro" and "Skip Credits" buttons as a Player setting
Plex Match Always to TMDB Despite ID and .plexmatch file
Plex sorts different things as "Challenge of the Superfriends"
TVDB - No matches were found using this agent
Still waiting on a fix to TV shows
Tracks still in Library after "Scan Library Files"
Simpsons - why do some series not populate fully?
Plex completely unusable .. slow .. crashing .. loads forever
"Hardcoded" metadata not scanned
Incorrect artist tag for audio files
Movie Soundtracks: Do they exist in the Plex world?
Plex Not Using Local Metadata
"Can't find or access the media file for this library item..." iOS only
Force credit recognition
Can we make the shuffle more random?
Sealab 2020 vs 2021
Madagascar 3
"Editions" for Series no longer works
Naming convention problems
Plex merging the wrong series
Star Trek impossible to get right
Popular tracks
requiredBandwidths == 2147483647 for files with attachments
New Personal Video Folder Not Finding Files
Bambi is missing!
Plex not following TVDB DVD order for In Living Color
MKV file only accessible in computer Hard drive but not accessible when it's in external hard drive
Plex server won't recognize new files recently
Issues with the New Plex Series Agent
New Plex TV Series Agent not matching episode metadata for War of the Worlds (1988)
Improper Library Labelling & Metadata in Music
PLex not finding my TV series
Multi-Disk Albums are broken
Extra step for "Match" to appear in three dot menu.
Specials not picking up name
Songs in album showing up twice (and only one is playable) - question and solution?
Quantum Leap - Blu-ray Order isn't pulling in all titles
Use local thumbnails for episodes
Series shows as unavailable but all episodes are present and playable
Movie Posters are being Changed
Different number of movies depending on sort order
Remove poster lock in database
Extras not loading in PMS
Plex not recognizing many of my MKV files
Does the Plex Dance cause library to re-run thumbnails, credits, etc?
TV show episodes all lumped into the same series
Externe Untertitel -> Fehler - Couldn't find the file to stream
[Solved] Plex Isn't Adding Spider-Man Far From Home
Removing videos from Music library
Missing or wrong metadata Plex TV Series
Some movies not added to library, most are
File Naming for TV Series in Plex folders
Wrong cast/actor/person showing
How to batch poster artwork. 20+ episodes at one time
[Agent] [Matching Bug] Plex TV Series Agent has matched Doom Patrol with VICE News Reports
Saved Updates Not Visible Without Page Refresh
Missing movie that was there before
PBS NOVA Wonders being added as NOVA S01
Title cards for TV series
Plex refuses to use local metadata
How can i match tenacious d tv show it only matches the movie
Help needed: How to file 'TV Specials'
Plex Dance
CSI Immorality naming for TV SPECIAL
Photo timeline order breaked down after some time
Converted Video Not Showing in Library
[Rel] HTTP Anidb Metadata Agent (HAMA)
TV Series poster art?
Can't remove corrupt movie
Can not add media after deleted
Miss Marple (1984) - Not matching as a series
Why Don'tn things end up where I want them?
The New Scanner "Plex TV series" BUG
Popular Tracks - How does it work and what am I missing?
File association in Series TV directory
Wrong Metadata for new shows
Unavailable content
Matching doesn't work properly
TV episodes not being recognized even though other episodes are recognized correctly
Can't properly match the show Travel Man: 48 hours in
Plex Series agent keeps matching me to the wrong for for this one title
Plex TV Misidentifying episodes
Custom Metadata Agent isn't reading episode NFO file
Setting up tv series on plex... HELP!
TV shows not getting latest metadata
LoudnessAnalysis for Movies & TV running when its disabled at the library level
Various Artist issues
Library not updating
Server crashing - Windows Event Viewer shows ucrtbase.dll as faulting module
Movie with Multiple Sub-Movies or "Specials"
Recent issue - Episodes duplicating to show part 1 & part 2 despite only 1 file
Plex suddenly won't fetch Media info data (missing streams)
Recently Added Bug
Update and clarification using Plex Dance
Plex won't recognize seasons 1&2 of "Twin Peaks"
Agent and scanner when adding TV Shows?
Stargate File Naming Convetion - SG1 and Atlantis files mixed/recognized as an SG1 episode
Scanner can't find a movie
Saved by the Bell series from 1989 and 2020 are being mixed
TV Metadata not populating last few days, last worked 11/22
Info on Episode shows TWO exact same files. Only one exists
Track times being misreported + files don't play in Plex Web
The connection to the server is not strong enough to play this movie
Dexter New Blood S01EP03 show as own series
8 movie files in seperate folder but 1 shows up
Server replaced having issues discovering new media
The new TV Agent and Jeopardy
Newest season of a show not detected by library scan
Reading video file metadata
How do I remove the 'Upgrade Libraries Notification' from Plex Media Server?
Artwork slowly disappearing from libraries
Plex Splitting Albums - Each Song is Becoming its Own Album
Combining 2 NAS devices into 1
Archiving movies to NAS, Plex thinks they're newly added
TheTVDB metadata - V3 API and related issues
Plex not categorizing correctly
Struggling To Get My Server To Recognize TV Series
No metadata from TVDB and MovieDB
Unable to Delete Subtitles
How to correct Master List, TV Episode name
Made for TV Movies
Audiobook Guide
Sorting TV movie miniseries
Something went wrong
DVD Order Agent
Plex not grabbing TVDB Episode Info
Plex TV Series scanner assigns subsequent shows to first match
Continuing Metadata not updating even after forcing refreshes . . .
How to configure new plex agent
Trailers & Extras Mismatches
I want a definitive solution to naming singles in Plex
Cannot match tv series
Dekalog (1989) TV series not matching episodes correctly
Help Getting TV Show to Show in Library
Issues with Naruto (2002) after updating to new metadata
Plex Agent Issue
New Plex Agent not Finding match but it displays with the Legacy Agent
Plex findet einige neu hinzugefügt MKVs nicht und spielt einige MKVs nicht
Local media assets (movies) ist die entscheidend für interne cover?
Media Server skipping a single file
Duplicate Plex entry for one file
What's the latest on multiple episodes in the same file? So frustrating!
Episode showing in wrong season despite being named correctly
TV-Serie "Dick und Doof" wird nicht zugeordnet
Ghostly echo of a TV episode that thinks its a film
New movie files not added to library list
Unmatch Duplicate Episodes in TV SHOW
How Do I name and Organize Pilot episodes
ALF (1986) Season 02 - TV series not matching episodes correctly
TV spin off series issues: 2 file paths for some reason
Can't get Plex Media Server to match Spartacus: Gods of the Arena!
Plex Media Server crashing intermittently on Synology DSM 7
All shows won't load onto PMS
All players show incorrect/missing filenames
Library Not Populating Accurately - Ask for one show, get different show
[BUG] Fantastic Four (2005) will not show up in Plex
Mediafiles on synology nas not added in library
Lost a tv show - its gone in plex - files there
Chapters from splitted apart movies
Specifically True Blood is only showing season 2
Recommendations on music scanner & agent
Unable to find/add to lib: Dexter new blood
Unable to force Plex to see TV episodes from different shows as non-duplicates
PLEX not showing Rambo 1 first blood (1982)
New Plex-server doesn't find all TV Shows
Missing Content
Trouble with Movies from my media library appearing in plex
Help!? Star Trek TNG Season 3 appears as TOS Season 3
I have a show that has been remade and Plex server is showing both shows as one
Plex identifying different shows as the same
Plex no longer detecting a season it previously detected
All RiffTrax suddenly unmatched from TVDB
Moving Metadata from windows to Linux question,
Plex TV Series Matching
Resolution problem index tight order titles tv series
Do you need Series/Episode numbers to add shows or can Plex add with Episode names? Or .properties files?
Finding database entry for file
Plex Server not scanning certain files/folders on QNAP NAS
Personal media not recognised
Bug: Non-contiguous multi-episode files scan as duplicates due to interpreting ep. number as range
Recording issues where part 1 and part 2 of episode have same episode number
Library not uploading most of movies
Music agents missing?
Metadata
Adding TV Show
Help for fixing incorrect album categorization
I can't seem to get the extras to be recognized in Plex
Reset Recently Added date following Plex Dance
Corrupted cached posters of music artists and albums
Not detecting new episodes
Music metadata not showing properly on some FLAC files
Plex TV Scanner broken since 1.28.xxx?
Plex crashing in Synology nas
Plex TV Series scanner is broken finding media files since v1.26 when using TVDB Ids to match items
Plex doesn't always read media with multiple channels as anything other than stereo
Music disappeared from plex
TV shows Library
Problems with matching Files
Sometimes a SRT subtitle will not be available even though it is in the correct folder
Windows 11 and my TV shows
Plex 1.23.3.4707 not processing Album Compilations with Various Artists anymore. Assigns Track Artist to Album Artist
Multiple Version Frustrations
PLEX Not Scraping All Files
Plex keeps changing rating key number
Plex grouping all the season together
Music Videos inside The Music Libary
Episode Name when Numbers appear in Title
Mixed Libraries
House of the Dragon Open Intro Theme
Matching error for "Suicide Squad (2016)" and "The Suicide Squad (2021)"
Plex Media Server is no longer picking up newly added TV shows
Re-encoding broke all matches
Metadata is Wrong Even though Matched with the Correct Show
Incorrect album release dates
Help with file not being discovered
TV Series Tagging Isue
How to Split Apart episodes
Warum bekomme ich für eine Serie 10 Einträge?
Unable to un-merge original album and remastered version
Cannot add Looney Tunes correctly
Popular Tracks broken
Remove ad markers for media items
How can I get Plex to refresh this artist and their albums?
TV Episodes Not showing on Plex
Issues with TV Show: Detail (TVDB-415087)
Plex is ignoring local artist posters
Lost all movies from plex suddenly
A Nightmare on Elm Street - cannot get it to add to my library
Plex cannot see that this 1 video exists
Problem with recently added TV series on Amazon Fire Cube
How to remove Sonic Analysis results?
Plex TV Series Scanner results in wrong names for Multi-Part Episodes in 'The Weekenders'
Intros not always automatically detected, Force Analyze doesn't always work, Plex Dance does
Loudness Analysis on Songs Gone
The Scooby-Doo Show and The Scooby-Doo/Dynomutt Show are merged
DIsappearing dates
Season 2 is identified as Season 7. Why?
Plex Server Hanging on Detecting Intros
Sonic analysis stuck on 6 albums forever + several issues on the log file
Plexamp Not Showing Waveforms - Tracks Imported into Plex on August 16th
Plex won't match show
Extras not associating with correct movie after splitting apart a duplicate
Rebuilding Collection Photos after massive file renames
TV shows not scanning featurettes and other subdirectories
TV Shows do not show up or only some seasons
Plex continually delivers wrong album art work
New TV Show folder appear as empty
Automatically merge albums that imported split?
Issues since update/upgrade to plexpass - Windows to Chromecast
Fix song matching without losing ratings
PMS Has Suddenly Changed "Various Artists" to a Randomly Chosen Artist's Name
DSM 7 - Plex listing issues
Every TV show ID's as "The Season"
MP4 TV Show Files Displays Incorrect Episode Thumbnails
PMS not using the metadata embedded in my MP4 files
Formula 1 Racing recording failures
Move DVR media
I've got like five glitches happening at once so here's a video
Episode Ordering Issue
Forcing metadata download for a single folder
Can't Change Artist
Missing casts with Plex TV Series agent
Renaming/Updating a File in Plex
Newer PMS versions not adding content
Plex isnt removing deleted files
Artist sorting weird
Love Death and Metadata, Season 3
Repeated albums showing up with only 1 song each
Loads of compilation albums matching as "Joy Division"
[REL] Extended Personal Media Shows Agent
Transcoder & Analyze TV Shows to Find Intros Don't Appear to be Working Correctly
Not displaying episodes 100 through 199
Problem with Linux "seeing" MP4 movie
Plex Movie agent fails to match anything
[HowTo] Configure Popular Tracks Section to Prioritise Albums over every other release type!
Renamed TV episode files to add "-01" and "-02" on the end - they disappeared from Plex
Some episodes are now missing
Two different Plex servers on same data - one sees episodes, other doesn't
Keeps trying to generate chapter thumbnails for a deleted extra
Plex server in Synology NAS not recognizing new content movies
Movie file missing in library, but it's in the folder and it plays directly. How do I find out why?
Plex TV Agent is unable to match media
The Orville (2017) is not picked up
Plex no longer matching using new Plex Agents
When I change my scanner and agent, perform a plex library upgrade, settings do not save
[SOLVED] How long does it take for Plex to update a TVDB change?
Does Plex Dance lose music ratings?
Music sort by album not sorting properly
Show not recognised
Movies not being recognised
Loudness analysis
Folder removed from [Library] still has content show up under Recently Added in [Library]
Library Scan not recognizing video files after update
Movie Collections
My library content is not updated, automatically or manually
Synology running Plex will not even recognize .mkv files in my TV directory
Edition field locked and unable to edit despite Plex Pass
Plex Scanner Problems Since Upgrade
First step in Plex dance not working repeatedly
Video preview thumbnails not being created with Scheduled Tasks
Metadata for Worlds Strongest Man
"Fix Match" for album show tracks grayed out?!
Force refresh of photo thumbnail - not all metadata
Plex not matching TVDB order for Ray Bradbury Theater TV series
Detecting New Added Movies
Two editions of Star Trek II only show up as one movie
Two different movies register as partially watched when you only have watched one
Apple Player Update Beta Testing
Plex TV Series Agent mixing data from two series
Need help sorting albums with same name
Another missing movie post
Files not being recognized
Mismatched German metadata/titles for 'Allo 'Allo (1982) special episodes
Plex doesn't "find" the movie in the folder
Plex server not seeing a movie
Missing item from Library
Automatic subtitles change
Plex only recognises 1 episode
Can't fix match on one season of a show
Can't find metadata
Duplicate Music Albums
Plex cannot find a show
TV Series only showing some of the episodes.. LA Law TV season 1 only showing 13 episodes- I have 22
Plex Media Server 1.41.7.9717 causes problems with custom agents
Certain show not matching correctly/duplicate entries
Generating New Intro Markers on Existing Show in Library
Thor (2011) not matching with Plex Movie
Plex forces artist name change
Incorrect Audio Plays for Selected Track on Movie
Editions not recognized from filename
BUG [v1.41.4.9463] : PMS does not add anymore removed/missing titles to the trash
Unable to Split Titles
New movie files are not able to be matched
One episode of a TV series is ignored when scanned
Clarification on multiple movie versions and how to title them?
Some things not showing up in library
Wildly wrong Match: Common Side Effects
What would cause Plex to show the exact same file as a duplicate?
How to find missing shows in library
Ending credits refuse to detect
PMS bug: something went wrong in photo library
Where have my movies chapters gone?
Name of episode and summary text for TV shows - not consistent: sometimes works, sometimes not
I'm completely flummoxed. Some TV episodes will not show up in Plex library
Metadata refresh deletes all posters for certain movies
Can't get Plex to recognise a TV show
Movie library switching languages when changing sort
Metadata not showing up correctly in plexamp
Sorting movies so that the title is alphabetical including "The" or "A" at the start
[BUG] Bad Show Title Match: Azure Lane
This is an odd one... Series disappearing from library, not filesystem. But with a twist!
New Files Not Appearing After Library Scan
New movies not getting auto matched, and no luck manual matching either
Scanning anomally
Plex doesn't pick up newly added videos in my library
TV Shows not showing up after being added as a library
SOLVED: "Editions" support not appearing after Plex Pass purchase?
Cant get data for old V the final battle series
Best practice for 'Various Artists' compilation albums?
Some recorded TV shows have the wrong description
Problem playing (naming?) Multi-part documentary
Multi Episode Files
"MISSING DETAILS: Pardon our dust. This item is lacking a details page."
Plex keeps grouping two different movies as one, even when using {tmdb-id} in directory name
TV showing Merging in one
Fixing mismatched season 5 of Arrested Development
Meta.plex.tv and other metadats servers only respond with "o hai"
Plex Is Unable To Recognize Two Versions Of Same TV Show
Trying to set up music library of ~15000 radio broadcasts, albums/artists not showing up correctly
Plex Library Agent - Not Matching Correctly
Yet another case of "File named correctly, but Plex names it something else"
Wrong year
Plex scanner not finding matches
Plex scanner can't be chosen
How do you restore Continue Watching for a show manually removed?
Move to new folder and metadata breaks
Plex deleted my movie?! Can't add it back
Unable to clear trash can icon from certain series
TV show in a new library but not the usual library
Indian Jones Not listet in movie selection
Still problems with Colons in TV series and getting Matches Waco: The Aftermath
Plex will not add all my new folders and shows series i long since deleted. Despite scanning library
Plex not playing any new files I add
Some seasons of some TV shows are marked as deleted but all files are present
Recent added Tv Shows Stay FOREVER
Movie isn't seen in plex
Plex scanner matching wrong series
Merged files
My Poster Not Showing with Downloaded Movies
Some Posters aren't showing up
Friends 15th Anniversary Specials (Season 00) not matching TMDB
Metadata Stopped Downloading
Plex ordnet Folgen falsch zu
Plex refuses to see old TV series "Daniel Boone"
Some content comes and goes when scanning, some content is simply skipped
Plexamp, sharing link option disappeared
Plex stopped fetching metadata
MasterClass metadata
Je ne vois pas un de mes repertoires de serie
[SOLVED] Cannot delete or replace Movie Extras
Scanner permanently trashes library items after transient SMB failure breaking "recently added"
TV Show - No audio on nvidia shield client. Works on others
Custom Theme Music Not Working
Shows do not display in normal UI but shows in "Folders" view
Uploaded show not showing
TVDB metadata being removed issues
[Help Needed] Strange behavior on PMS Version 1.5.1.3520
Content
Repairing a corrupt library - receiving error
Anyone else having trouble getting Plex to name ThunderCats episodes?
Episodes being categorized incorrectly
