Hi, I really want to change some of the theme songs on certain tv shows. Issues mostly, The quilty or just a horrible song. I want to be able to pull a song from youtube edit it. Then upload it to my server for a pacific show.
As long as your anime library uses default TheTVDB agent, this is possible.
https://support.plex.tv/hc/en-us/articles/200220717-Local-Media-Assets-TV-Shows
If you have installed the HAMA scanner, you should ask its developer.
How do i get a hold of the developer?
https://forums.plex.tv/discussion/77636/release-http-anidb-metadata-agent-hama
Thank you I’ll private message him.
Another way to get your own version of theme music is to add a file called THEME.MP3 to the shows folder. I do this on shows where I want the full version of the theme and not just the 30 second clip.
Thank you, I just tried this and it works. Your awesome man!
