Anything to worry about?
Was watching the wonderful text stream by in terminal and once the atv was cruising along i would get a weird dns request, being from the same place on different ports i think. Is this usual? The url changes every time I restart PlexConnect. I have attached a text file of what was coming up.
Really?
sorry dont know what went wrong. Now cant figure out what to do, sorry for the text dump about to happen.
192.168.1.89 - - [05/Jun/2013 00:09:14] "GET /scrobble.js HTTP/1.1" 200 -
ATVLogger : atv playing.
DNSServer : DNS request received!
DNSServer : Source: ('192.168.1.89', 60840)
DNSServer : Domain: b._dns-sd._udp.0.1.168.192.in-addr.arpa
DNSServer : ***forward request
DNSServer : Source: ('192.168.1.89', 51556)
DNSServer : Domain: db._dns-sd._udp.0.1.168.192.in-addr.arpa
DNSServer : Source: ('192.168.1.89', 52851)
DNSServer : Domain: r._dns-sd._udp.0.1.168.192.in-addr.arpa
DNSServer : Source: ('192.168.1.89', 63824)
DNSServer : Domain: dr._dns-sd._udp.0.1.168.192.in-addr.arpa
DNSServer : Source: ('192.168.1.89', 56973)
DNSServer : Domain: lb._dns-sd._udp.0.1.168.192.in-addr.arpa
DNSServer : Source: ('192.168.1.67', 49152)
More information is needed before what is happening would be clear.  The most pressing questions are:
  • what are the IP addresses of:
    • the Apple TV
    • the computer you are running PlexConnect on
    • the machine running PMS
  • what do you have the DNS set to in Settings.py (by default it is Google DNS but some customize it for performance or services like Unblock-US)
  • is the Apple TV still responding normally as if PlexConnect was running without issue?
PlexConnect can only be logging traffic from a device that has been told to look at that machine's IP address for DNS (which should only be your Apple TV(s)).
