"API rate limit exceeded" When Getting Certificate
Thank you! Certificate was obtained.
Hello @ChuckPa , i’m having the same issue in my Online server. Is there any way to reset the certificate?
Your server certificate is stuck in “Generating” status.
We’ve seen this happen before. It shouldn’t happen.
Operations is looking at it now.
I’ll let you know as soon as they either reset it manually or fix it
@JJMrs
Would you restart the server and check it please?
Operations found something they didn’t like, reset your certificate, and are now going to address the root problem.
Hi @ChuckPa I just restarted and it works great again :smiley:
Hello ChuckPa, I’m having the same certificate problem, from plex console error message is: "CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> ". Could you please investigate and let me know how to proceed? Thanks in advance!
Same problem here after I moved my plexcache to a different mount and had to wipe the cache. Now I get the cert rate limit as well. How can I fix this?
@BaRB9
certificate reset
You may restart the server
@MikeBr
Einstein … lobotomy … Restart :wink:
@ChuckPa Thank you so much! I can finally access app.plex.tv. Now I need to work on fixing my remote access, but certificate issue definitely helped me a lot to reach the app! Thanks again
Thanks! That fixed it!
I’m also getting this exact error. I had a short power outage last night and it hasn’t been working since. @ChuckPa , could you help me look into it?
Error message:
Apr 07, 2021 14:27:01.590 [23478] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
@deeechun
Certificate reset.
It was stuck in “Generating” mode.
I’ve just chatted with the operations team.
They deployed a support tool which now runs in the background and monitors for these situations.
Anything that is stuck for more than 1 hr will be automatically handled.
Hi @ChuckPa
It looks like I’m experiencing the same issue:
Apr 18, 2021 00:39:09.639 [14799] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Is there anything you can do to help?
I’ve just gone combing through my log file to find I’ve hit the same error.
I’m planning on keeping the server offline for over 24h as you mentioned before but you also touched on some people’s servers acting “weird” and as I recently transferred my W10 server to Linux I’m a bit concerned there might be something else afoot here. I’m hoping to get some manual intervention juust in case :crossed_fingers:
@leo632
I have reset the Shield’s certificate. You may now restart it.
@PieDar
I have reset the certificate. You may restart the server.
I did see a hard ERROR generating the certificate. If this persists, please notify me immediately.
Hi.
I’m also having the same error message.
I have migrated from Windows to Linux and the logs shows
Please help me solve the problem.
Thank you!
Thank you very much for your prompt and thorough assistance.
I still saw a few errors in my logs, but everything’s working perfectly and hopefully it’ll stay that way!
Thanks again Chuck, it feels great that my first little server build is up and running :grin:
