Application for viewing media information
Is there a windows application that can show video and audio information for a media folder? Similar/identical to “Media Info” in Plex. Is there an easy way to get this from Plex for all media files without having to open the Media Info for each one? Would like to be able to see which media files are encoded for example in AC3 vs AAC or the video codec used, etc.
thanks
There is a plugin that will include this info. Exports library data to a csv file. Plex2CSV
You could also get it from the database, if you’re familiar with sqlite.
thanks for the help
Any reason why Plex2CSV would only run part of the way through a library? I’ve run it 6 times and it goes through 109 media files on the low side to 629 on the high side of 1500? It doesn’t stop at the same place and Plex is running the entire time.
I don’t know. You should post your issue with Plex2CSV in the channels forum - the thread I linked to in my prior post.
Will do. thanks
