Artist info is appearing in a different language not English
I have noticed that when I select an artist in my Musix Library the description regarding date of birth and info about them is appearing in a different language. Even though I have English set as my default language.
There are quite a few locations in Plex where you can select a language. The one responsible for the artist biographies is in the properties of the music library.
Edit your music library to see it.
I checked that and it shows as “English”
Please, could you send me a screenshot of the artist info page in Plex
and the contents of the Plex XML info of one of the tracks by that artist?
I notice inthe XML it shows DE as languaage but I have set English as shown on attachments
Also, some BIOs are in English and some are in German
At the time when the artist was added to the library, it must have been set to german.
You can only change this matching by performing the Plex Dance “light” (meaning: omit step 4) with all albums by that artist.
(Alternatively, you could try to ‘Fix Match’ at the artist level. But I’m not sure this will work with an older library.)
