Astra 19.2 All Channels Germany dosn't work
Server Version# 1.18.2.2058:
Hello,
I wanted to set my Live TV up in Plex, because I use a Satellite Dish I wanted to use the Astra EPG. But When I want to assign the Channels I only see one Channel in the dropdown… Can anyBody help?
Same problem here with server version 1.18.4.2171
As workaround I`ve choosen another EPG, but so I’m missing some channels (no Cable provider has many channels as Astra)
Very annoying.
Did anyone make this work?
Short answer no.
But the Problem exists since mid-2019, so there is a good chance it will be fixed soon.
Well, I’m not so optimistic. After all, there are a lot of posts here in Forum that were automatically closed after 3 months without ever hearing anything about it again.
I would like to see this feature working. I think that many small providers are using Astra 19.2 channels but will never be directly supported by Plex DVR.
@Devs: Is this issue known and are you working on it?
It is not an issue - the current position is still the same as stated here
https://support.plex.tv/articles/community-supported-tuners/
Satellite : Currently we do not have Satellite support. It’s something we are investigating, but there are some issues we will need to overcome, so likely you will run into issues with Satellite.
For Astra 19.2 there are channel numbers so channel mapping can be made to work but getting the tuner to tune channels may not work and has not been looked into
Ok, good to know. Thanks for your reply.
