I am having the same problem after upgrade to 1.18.x. Plex will crash after startup most of the times or after about 10 to 15 min when processing the repo…
I using it on docker with linuxserver/plex and I just tried the 1.18.4.2164-2aa83397b version but I am still having the same issues:
One common thing I get in the docker logs is this message:
Exception AttributeError: "'ZipArchive' object has no attribute '_zip'" in <bound method ZipArchive.__del__ of <Framework.components.data.ZipArchive object at 0x7fc9083653d0>> ignored
Resource is not a problem, the machine has 32 threads and 128GB of ram and the container has no restrictions. I can see that plex is doing something since CPU utilization goes between 400 to 900% but it is unreachable (through a browser and the app) …
I get as well a lot of:
WARN - SLOW QUERY: It took 84640.000000 ms to retrieve 0 items.
WARN - SLOW QUERY: It took 124450.000000 ms to retrieve 0 items.
DEBUG - It took 108190.000000 ms to retrieve 1123 items.
You mention “Container” - I need details for this too. This thread is about the native app. Docker (supported) or OMV (which isn’t supported) can carry a whole host of problems unto themselves.
DB : 717 327 360 Dec 19 20:37 com.plexapp.plugins.library.db
Wal : 734 023 424 Dec 19 20:39 com.plexapp.plugins.library.db-wal
Blob: 84 631 552 Dec 19 09:00 com.plexapp.plugins.library.blobs.db
Container: running LinuxServer.io (for quite a few years, latest version) https://hub.docker.com/r/linuxserver/plex/
Docker version 1.12.1
Linux 4.4.0-169-generic #198-Ubuntu SMP x86_64 GNU/Linux
I can kill it, delete everything and start from the begining if you think it may help.
unraid had some serious issues recently with kernel versions causing sqlite problems.
I run unraid and I use a cache drive which is SSD.
I read about it for a while and it seemed to affect users that used the array as their config folder for a docker where I use the cache drive so it doesn’t get written to the array until after hours.
this didn’t just impact Plex but affected any docker with sqlite such as sonarr and others.
Do you have any other dockers like sonarr, sickbeard, sabnzbd that use sqlite?
