I recently had to reinstall PMS and Plexconnect on a new computer. I'm not 100% what has become messed up.
When I have the ATV3 DNS IP set to the computer running Plexconnect, accessing everything from Netflix to Youtube to PBS kids has become painfully slow. The spinner wheel spins and spins and spins until what seems like an eternity, stops and continues to the app. When I switch my DNS on the ATV3 to automatic, the box flys again but obviously trailers doesn't connect to PMS anymore. The DNS IP is the same that the router advertizes and what is programmed in Settings.cfg (198.27.106.151).
This is killing me as it makes it difficult to use and now the wife and kids are bugging me about how long it takes to do anything on the ATV. I can literally press the Netflix Icon, wait away, go to the bathroom, come back and ATV3 just presents me with the profile page. When Plexconnect is removed (No DNS change on the ATV3), there is NO delay between pressing the Netflix icon and the profile page coming up.
Please help. This used to work so well!
Your ATV model (2 or 3) and firmware version: ATV3 A1469 running 7.2 (7512)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.40
The local IP address of the device that PlexConnect is installed on: 192.168.1.40
The device and operating system (including version number) that PlexConnect is installed on: Intel i7 PC running Windows 7 PC.
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Intel i7 PC running Windows 7 PC.
The Plex media server (PMS) version number you are running (do not put 'latest'): PMS 0.9.12.4.1192-9a47d21
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.40
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. Jun 18, 2015 last commit was 88d8e134e840b196fe694c3c1c946cca7b3f4770
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.1.40
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 198.27.106.151
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = High
logpath = .
Detail on the media file if it is an issue related to playing a media file Nothing to add here.
A detailed description of the issue (the clearer you can make this the better): When using PlexConnect all the Apps on the ATV3 are very slow to start. There spinner wheel spins a very long time until finally something gives and the programs start.
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
- shutdown PlexConnect
- in 'Settings.cfg', set loglevel to "High" (note the capital 'H')
- delete the existing log file
- restart PlexConnect
- repeat the issue
- immediately close PlexConnect and post the log.
- in 'Settings.cfg', set the loglevel back to "Normal"
12:53:28 PlexConnect: started: 12:53:28
12:53:28 PlexConnect: Version: 0.5-dev-020615
12:53:28 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:03:49) [MSC v.1500 32 bit (Intel)]
12:53:28 PlexConnect: Host OS: win32
12:53:28 PlexConnect: PILBackgrounds: Is PIL installed? True
12:53:28 Settings: getsetting enable_plexconnect_autodetect=True
12:53:28 PlexConnect: IP_self: 192.168.1.40
12:53:28 Settings: getsetting hosttointercept=trailers.apple.com
12:53:28 Settings: getsetting enable_dnsserver=True
12:53:28 DNSServer: started: 12:53:28
12:53:28 Settings: getsetting port_dnsserver=53
12:53:28 Settings: getsetting ip_dnsmaster=198.27.106.151
12:53:28 Settings: getsetting prevent_atv_update=True
12:53:28 DNSServer: ***
12:53:28 DNSServer: DNSServer: Serving DNS on 192.168.1.40 port 53.
12:53:28 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.40
12:53:28 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
12:53:28 DNSServer: forward other to higher level DNS: 198.27.106.151
12:53:28 WebServer: started: 12:53:28
12:53:28 Settings: getsetting port_webserver=80
12:53:28 WebServer: ***
12:53:28 WebServer: WebServer: Serving HTTP on 192.168.1.40 port 80.
12:53:28 Settings: getsetting enable_webserver_ssl=True
12:53:29 WebServer: started: 12:53:29
12:53:29 Settings: getsetting port_ssl=443
12:53:29 Settings: getsetting certfile=./assets/certificates/trailers.pem
12:53:29 WebServer: ***
12:53:29 WebServer: WebServer: Serving HTTPS on 192.168.1.40 port 443.
12:54:27 DNSServer: DNS request received!
12:54:27 DNSServer: Source: ('192.168.1.110', 56533)
12:54:27 DNSServer: Domain: local
12:54:27 DNSServer: ***forward request
12:54:27 DNSServer: -> DNS response from higher level
12:54:27 DNSServer: Source: ('192.168.1.110', 64261)
12:54:27 DNSServer: Domain: apple.com
12:54:32 DNSServer: DNS request received!
12:54:32 DNSServer: Source: ('192.168.1.110', 56536)
12:54:32 DNSServer: Domain: apple.com
12:54:32 DNSServer: ***forward request
12:54:32 DNSServer: -> DNS response from higher level
12:54:32 DNSServer: Source: ('192.168.1.110', 64261)
12:54:37 DNSServer: DNS request received!
12:54:37 DNSServer: Source: ('192.168.1.110', 56536)
12:54:37 DNSServer: Domain: apple.com
12:54:37 DNSServer: ***forward request
12:54:37 DNSServer: -> DNS response from higher level
12:54:37 DNSServer: Source: ('192.168.1.110', 64261)
12:54:42 DNSServer: DNS request received!
12:54:42 DNSServer: Source: ('192.168.1.110', 56536)
12:54:42 DNSServer: Domain: apple.com
12:54:42 DNSServer: ***forward request
12:54:42 DNSServer: -> DNS response from higher level
12:54:42 DNSServer: Source: ('192.168.1.110', 64261)
12:54:47 DNSServer: DNS request received!
12:54:47 DNSServer: Source: ('192.168.1.110', 64261)
12:54:47 DNSServer: Domain: apple.com
12:54:47 DNSServer: ***forward request
12:54:47 DNSServer: -> DNS response from higher level
12:55:00 DNSServer: DNS request received!
12:55:00 DNSServer: Source: ('192.168.1.110', 49625)
12:55:00 DNSServer: Domain: api-global.netflix.com
12:55:00 DNSServer: ***forward request
12:55:00 DNSServer: -> DNS response from higher level
12:55:00 DNSServer: Source: ('192.168.1.110', 53968)
12:55:05 DNSServer: DNS request received!
12:55:05 DNSServer: Source: ('192.168.1.110', 53968)
12:55:05 DNSServer: Domain: api-global.netflix.com
12:55:05 DNSServer: ***forward request
12:55:05 DNSServer: -> DNS response from higher level
12:55:10 DNSServer: DNS request received!
12:55:10 DNSServer: Source: ('192.168.1.110', 65221)
12:55:10 DNSServer: Domain: secure.netflix.com
12:55:10 DNSServer: ***forward request
12:55:10 DNSServer: -> DNS response from higher level
12:55:10 DNSServer: Source: ('192.168.1.110', 60852)
12:55:15 DNSServer: DNS request received!
12:55:15 DNSServer: Source: ('192.168.1.110', 65221)
12:55:15 DNSServer: Domain: secure.netflix.com
12:55:15 DNSServer: ***forward request
12:55:15 DNSServer: -> DNS response from higher level
12:55:15 DNSServer: Source: ('192.168.1.110', 60852)
12:55:20 DNSServer: DNS request received!
12:55:20 DNSServer: Source: ('192.168.1.110', 65221)
12:55:20 DNSServer: Domain: secure.netflix.com
12:55:20 DNSServer: ***forward request
12:55:20 DNSServer: -> DNS response from higher level
12:55:20 DNSServer: Source: ('192.168.1.110', 60852)
12:55:25 DNSServer: DNS request received!
12:55:25 DNSServer: Source: ('192.168.1.110', 60852)
12:55:25 DNSServer: Domain: secure.netflix.com
12:55:25 DNSServer: ***forward request
12:55:25 DNSServer: -> DNS response from higher level
12:55:30 DNSServer: DNS request received!
12:55:30 DNSServer: Source: ('192.168.1.110', 60852)
12:55:30 DNSServer: Domain: secure.netflix.com
12:55:30 DNSServer: ***forward request
12:55:30 DNSServer: -> DNS response from higher level
12:55:30 DNSServer: Source: ('192.168.1.110', 53837)
12:55:30 DNSServer: Domain: nmtracking.netflix.com
12:55:35 DNSServer: DNS request received!
12:55:35 DNSServer: Source: ('192.168.1.110', 61721)
12:55:35 DNSServer: Domain: nmtracking.netflix.com
12:55:35 DNSServer: ***forward request
12:55:35 DNSServer: -> DNS response from higher level
12:55:35 DNSServer: Source: ('192.168.1.110', 58661)
12:55:35 DNSServer: Domain: ichnaea.netflix.com
12:55:40 DNSServer: DNS request received!
12:55:40 DNSServer: Source: ('192.168.1.110', 59127)
12:55:40 DNSServer: Domain: ichnaea.netflix.com
12:55:40 DNSServer: ***forward request
12:55:40 DNSServer: -> DNS response from higher level
12:55:40 DNSServer: Source: ('192.168.1.110', 51361)
12:55:40 DNSServer: Domain: api-global.netflix.com
12:55:45 DNSServer: DNS request received!
12:55:45 DNSServer: Source: ('192.168.1.110', 53837)
12:55:45 DNSServer: Domain: nmtracking.netflix.com
12:55:45 DNSServer: ***forward request
12:55:45 DNSServer: -> DNS response from higher level
12:55:45 DNSServer: Source: ('192.168.1.110', 61721)
12:55:50 DNSServer: DNS request received!
12:55:50 DNSServer: Source: ('192.168.1.110', 58661)
12:55:50 DNSServer: Domain: ichnaea.netflix.com
12:55:50 DNSServer: ***forward request
12:55:50 DNSServer: -> DNS response from higher level
12:55:50 DNSServer: Source: ('192.168.1.110', 59127)
12:55:55 DNSServer: DNS request received!
12:55:55 DNSServer: Source: ('192.168.1.110', 51361)
12:55:55 DNSServer: Domain: api-global.netflix.com
12:55:55 DNSServer: ***forward request
12:55:56 DNSServer: -> DNS response from higher level
12:55:56 DNSServer: DNS request received!
12:55:56 DNSServer: Source: ('192.168.1.110', 53837)
12:55:56 DNSServer: Domain: nmtracking.netflix.com
12:55:56 DNSServer: ***forward request
12:56:01 DNSServer: DNS request received!
12:56:01 DNSServer: Source: ('192.168.1.110', 61721)
12:56:01 DNSServer: Domain: nmtracking.netflix.com
12:56:01 DNSServer: ***forward request
12:56:01 DNSServer: -> DNS response from higher level
12:56:01 DNSServer: Source: ('192.168.1.110', 58661)
12:56:01 DNSServer: Domain: ichnaea.netflix.com
12:56:06 DNSServer: DNS request received!
12:56:06 DNSServer: Source: ('192.168.1.110', 59127)
12:56:06 DNSServer: Domain: ichnaea.netflix.com
12:56:06 DNSServer: ***forward request
12:56:06 DNSServer: -> DNS response from higher level
12:56:06 DNSServer: Source: ('192.168.1.110', 51361)
12:56:06 DNSServer: Domain: api-global.netflix.com
12:56:11 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:56:11 DNSServer: DNS request received!
12:56:11 DNSServer: Source: ('192.168.1.110', 53837)
12:56:11 DNSServer: Domain: nmtracking.netflix.com
12:56:11 DNSServer: ***forward request
12:56:11 DNSServer: -> DNS response from higher level
12:56:11 DNSServer: Source: ('192.168.1.110', 61721)
12:56:16 DNSServer: DNS request received!
12:56:16 DNSServer: Source: ('192.168.1.110', 58661)
12:56:16 DNSServer: Domain: ichnaea.netflix.com
12:56:16 DNSServer: ***forward request
12:56:16 DNSServer: -> DNS response from higher level
12:56:16 DNSServer: Source: ('192.168.1.110', 59127)
12:56:21 DNSServer: DNS request received!
12:56:21 DNSServer: Source: ('192.168.1.110', 51361)
12:56:21 DNSServer: Domain: api-global.netflix.com
12:56:21 DNSServer: ***forward request
12:56:21 DNSServer: -> DNS response from higher level
12:56:21 DNSServer: Source: ('192.168.1.110', 53837)
12:56:21 DNSServer: Domain: nmtracking.netflix.com
12:56:26 DNSServer: DNS request received!
12:56:26 DNSServer: Source: ('192.168.1.110', 61721)
12:56:26 DNSServer: Domain: nmtracking.netflix.com
12:56:26 DNSServer: ***forward request
12:56:26 DNSServer: -> DNS response from higher level
12:56:26 DNSServer: Source: ('192.168.1.110', 58661)
12:56:26 DNSServer: Domain: ichnaea.netflix.com
12:56:31 DNSServer: DNS request received!
12:56:31 DNSServer: Source: ('192.168.1.110', 59127)
12:56:31 DNSServer: Domain: ichnaea.netflix.com
12:56:31 DNSServer: ***forward request
12:56:31 DNSServer: -> DNS response from higher level
12:56:31 DNSServer: Source: ('192.168.1.110', 51361)
12:56:31 DNSServer: Domain: api-global.netflix.com
12:56:36 DNSServer: DNS request received!
12:56:36 DNSServer: Source: ('192.168.1.110', 62776)
12:56:36 DNSServer: Domain: nmtracking.netflix.com
12:56:36 DNSServer: ***forward request
12:56:36 DNSServer: -> DNS response from higher level
12:56:36 DNSServer: Source: ('192.168.1.110', 51576)
12:56:36 DNSServer: Domain: ichnaea.netflix.com
12:56:41 DNSServer: DNS request received!
12:56:41 DNSServer: Source: ('192.168.1.110', 51361)
12:56:41 DNSServer: Domain: api-global.netflix.com
12:56:41 DNSServer: ***forward request
12:56:41 DNSServer: -> DNS response from higher level
12:56:41 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:56:41 DNSServer: Source: ('192.168.1.110', 58179)
12:56:41 DNSServer: Domain: nmtracking.netflix.com
12:56:41 DNSServer: Source: ('192.168.1.110', 61272)
12:56:41 DNSServer: Source: ('192.168.1.110', 55290)
12:56:41 DNSServer: Domain: secure.netflix.com
12:56:42 DNSServer: -> DNS response from higher level
12:56:42 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:56:42 DNSServer: DNS request received!
12:56:42 DNSServer: Source: ('192.168.1.110', 58179)
12:56:42 DNSServer: Domain: nmtracking.netflix.com
12:56:42 DNSServer: ***forward request
12:56:42 DNSServer: Source: ('192.168.1.110', 61272)
12:56:42 DNSServer: Source: ('192.168.1.110', 55290)
12:56:42 DNSServer: Domain: secure.netflix.com
12:56:50 DNSServer: DNS request received!
12:56:50 DNSServer: Source: ('192.168.1.110', 58179)
12:56:50 DNSServer: Domain: nmtracking.netflix.com
12:56:50 DNSServer: ***forward request
12:56:50 DNSServer: -> DNS response from higher level
12:56:50 DNSServer: Source: ('192.168.1.110', 61272)
12:56:55 DNSServer: DNS request received!
12:56:55 DNSServer: Source: ('192.168.1.110', 55290)
12:56:55 DNSServer: Domain: secure.netflix.com
12:56:55 DNSServer: ***forward request
12:56:55 DNSServer: -> DNS response from higher level
12:56:56 DNSServer: DNS request received!
12:56:56 DNSServer: Source: ('192.168.1.110', 50108)
12:56:56 DNSServer: Domain: api-global.netflix.com
12:56:56 DNSServer: ***forward request
12:57:01 DNSServer: DNS request received!
12:57:01 DNSServer: Source: ('192.168.1.110', 63429)
12:57:01 DNSServer: Domain: nmtracking.netflix.com
12:57:01 DNSServer: ***forward request
12:57:01 DNSServer: -> DNS response from higher level
12:57:01 DNSServer: Source: ('192.168.1.110', 49416)
12:57:01 DNSServer: Domain: api-global.netflix.com
12:57:06 DNSServer: DNS request received!
12:57:06 DNSServer: Source: ('192.168.1.110', 50108)
12:57:06 DNSServer: Domain: api-global.netflix.com
12:57:06 DNSServer: ***forward request
12:57:06 DNSServer: -> DNS response from higher level
12:57:06 DNSServer: Source: ('192.168.1.110', 49416)
12:57:11 DNSServer: DNS request received!
12:57:11 DNSServer: Source: ('192.168.1.110', 50108)
12:57:11 DNSServer: Domain: api-global.netflix.com
12:57:11 DNSServer: ***forward request
12:57:11 DNSServer: -> DNS response from higher level
12:57:11 DNSServer: Source: ('192.168.1.110', 49416)
12:57:16 DNSServer: DNS request received!
12:57:16 DNSServer: Source: ('192.168.1.110', 49416)
12:57:16 DNSServer: Domain: api-global.netflix.com
12:57:16 DNSServer: ***forward request
12:57:16 DNSServer: -> DNS response from higher level
12:57:16 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:57:16 DNSServer: Source: ('192.168.1.110', 50108)
12:57:21 DNSServer: DNS request received!
12:57:21 DNSServer: Source: ('192.168.1.110', 49416)
12:57:21 DNSServer: Domain: api-global.netflix.com
12:57:21 DNSServer: ***forward request
12:57:21 DNSServer: -> DNS response from higher level
12:57:26 DNSServer: DNS request received!
12:57:26 DNSServer: Source: ('192.168.1.110', 49416)
12:57:26 DNSServer: Domain: api-global.netflix.com
12:57:26 DNSServer: ***forward request
12:57:26 DNSServer: -> DNS response from higher level
12:57:26 DNSServer: Source: ('192.168.1.110', 50108)
12:57:31 DNSServer: DNS request received!
12:57:31 DNSServer: Source: ('192.168.1.110', 49416)
12:57:31 DNSServer: Domain: api-global.netflix.com
12:57:31 DNSServer: ***forward request
12:57:31 DNSServer: -> DNS response from higher level
12:57:31 DNSServer: Source: ('192.168.1.110', 63092)
12:57:31 DNSServer: Domain: nmtracking.netflix.com
12:57:31 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:57:32 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:57:32 DNSServer: DNS request received!
12:57:32 DNSServer: Source: ('192.168.1.110', 63092)
12:57:32 DNSServer: Domain: nmtracking.netflix.com
12:57:32 DNSServer: ***forward request
12:57:32 DNSServer: -> DNS response from higher level
12:58:46 DNSServer: DNS request received!
12:58:46 DNSServer: Source: ('192.168.1.110', 54246)
12:58:46 DNSServer: Domain: api-global.netflix.com
12:58:46 DNSServer: ***forward request
12:58:46 DNSServer: -> DNS response from higher level
12:58:46 DNSServer: Source: ('192.168.1.110', 53017)
12:58:51 DNSServer: DNS request received!
12:58:51 DNSServer: Source: ('192.168.1.110', 49830)
12:58:51 DNSServer: Domain: nmtracking.netflix.com
12:58:51 DNSServer: ***forward request
12:58:51 DNSServer: -> DNS response from higher level
12:58:51 DNSServer: Source: ('192.168.1.110', 53017)
12:58:51 DNSServer: Domain: api-global.netflix.com
12:58:51 DNSServer: Source: ('192.168.1.110', 50819)
12:58:52 DNSServer: -> DNS response from higher level
12:58:52 DNSServer: DNS request received!
12:58:52 DNSServer: Source: ('192.168.1.110', 50819)
12:58:52 DNSServer: Domain: nmtracking.netflix.com
12:58:52 DNSServer: ***forward request
12:58:52 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
12:58:53 DNSServer: DNS request received!
12:58:53 DNSServer: Source: ('192.168.1.110', 58608)
12:58:53 DNSServer: Domain: secure.netflix.com
12:58:53 DNSServer: ***forward request
12:58:53 DNSServer: -> DNS response from higher level
12:58:53 DNSServer: Source: ('192.168.1.110', 64997)
12:58:58 DNSServer: DNS request received!
12:58:58 DNSServer: Source: ('192.168.1.110', 64997)
12:58:58 DNSServer: Domain: secure.netflix.com
12:58:58 DNSServer: ***forward request
12:58:58 DNSServer: -> DNS response from higher level
12:59:03 DNSServer: DNS request received!
12:59:03 DNSServer: Source: ('192.168.1.110', 49998)
12:59:03 DNSServer: Domain: nmtracking.netflix.com
12:59:03 DNSServer: ***forward request
12:59:03 DNSServer: -> DNS response from higher level
12:59:03 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
13:01:18 DNSServer: DNS request received!
13:01:18 DNSServer: Source: ('192.168.1.110', 59825)
13:01:18 DNSServer: Domain: ichnaea.netflix.com
13:01:18 DNSServer: ***forward request
13:01:18 DNSServer: -> DNS response from higher level
13:01:18 DNSServer: Source: ('192.168.1.110', 49761)
13:01:23 DNSServer: DNS request received!
13:01:23 DNSServer: Source: ('192.168.1.110', 64021)
13:01:23 DNSServer: Domain: nmtracking.netflix.com
13:01:23 DNSServer: ***forward request
13:01:23 DNSServer: -> DNS response from higher level
13:01:23 DNSServer: Source: ('192.168.1.110', 65430)
13:01:28 DNSServer: DNS request received!
13:01:28 DNSServer: Source: ('192.168.1.110', 49761)
13:01:28 DNSServer: Domain: ichnaea.netflix.com
13:01:28 DNSServer: ***forward request
13:01:28 DNSServer: -> DNS response from higher level
13:01:28 DNSServer: Source: ('192.168.1.110', 64021)
13:01:28 DNSServer: Domain: nmtracking.netflix.com
13:01:34 DNSServer: DNS request received!
13:01:34 DNSServer: Source: ('192.168.1.110', 65430)
13:01:34 DNSServer: Domain: nmtracking.netflix.com
13:01:34 DNSServer: ***forward request
13:01:34 DNSServer: -> DNS response from higher level
13:01:34 DNSServer: Source: ('192.168.1.110', 49761)
13:01:34 DNSServer: Domain: ichnaea.netflix.com
13:01:39 DNSServer: DNS request received!
13:01:39 DNSServer: Source: ('192.168.1.110', 64021)
13:01:39 DNSServer: Domain: nmtracking.netflix.com
13:01:39 DNSServer: ***forward request
13:01:39 DNSServer: -> DNS response from higher level
13:01:39 DNSServer: Source: ('192.168.1.110', 65430)
13:01:44 DNSServer: DNS request received!
13:01:44 DNSServer: Source: ('192.168.1.110', 49761)
13:01:44 DNSServer: Domain: ichnaea.netflix.com
13:01:44 DNSServer: ***forward request
13:01:44 DNSServer: -> DNS response from higher level
13:01:44 DNSServer: Source: ('192.168.1.110', 65430)
13:01:44 DNSServer: Domain: nmtracking.netflix.com
13:01:49 DNSServer: DNS request received!
13:01:49 DNSServer: Source: ('192.168.1.110', 49761)
13:01:49 DNSServer: Domain: ichnaea.netflix.com
13:01:49 DNSServer: ***forward request
13:01:49 DNSServer: -> DNS response from higher level
13:01:49 DNSServer: Source: ('192.168.1.110', 65430)
13:01:49 DNSServer: Domain: nmtracking.netflix.com
13:01:54 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
13:05:11 DNSServer: DNS request received!
13:05:11 DNSServer: Source: ('192.168.1.111', 51309)
13:05:11 DNSServer: Domain: init-p01st.push.apple.com
13:05:11 DNSServer: ***forward request
13:05:12 DNSServer: -> DNS response from higher level
13:05:12 DNSServer: DNS request received!
13:05:12 DNSServer: Source: ('192.168.1.111', 60674)
13:05:12 DNSServer: Domain: init-p01st.push.apple.com
13:05:12 DNSServer: ***forward request
13:05:17 DNSServer: DNS request received!
13:05:17 DNSServer: Source: ('192.168.1.111', 51309)
13:05:17 DNSServer: Domain: a1441.g4.akamai.net
13:05:17 DNSServer: ***forward request
13:05:17 DNSServer: -> DNS response from higher level
13:05:17 DNSServer: Source: ('192.168.1.111', 60674)
13:05:17 DNSServer: Domain: init-p01st.push.apple.com
13:05:22 DNSServer: DNS request received!
13:05:22 DNSServer: Source: ('192.168.1.111', 51309)
13:05:22 DNSServer: Domain: a1441.g4.akamai.net
13:05:22 DNSServer: ***forward request
13:05:22 DNSServer: -> DNS response from higher level
13:05:22 DNSServer: Source: ('192.168.1.111', 60674)
13:05:22 DNSServer: Domain: init-p01st.push.apple.com
13:05:27 DNSServer: DNS request received!
13:05:27 DNSServer: Source: ('192.168.1.111', 51309)
13:05:27 DNSServer: Domain: a1441.g4.akamai.net
13:05:27 DNSServer: ***forward request
13:05:27 DNSServer: -> DNS response from higher level
13:05:27 DNSServer: Source: ('192.168.1.111', 60674)
13:05:27 DNSServer: Domain: init-p01st.push.apple.com
13:05:32 DNSServer: DNS request received!
13:05:32 DNSServer: Source: ('192.168.1.111', 60674)
13:05:32 DNSServer: Domain: init-p01st.push.apple.com
13:05:32 DNSServer: ***forward request
13:05:32 DNSServer: -> DNS response from higher level
13:05:37 DNSServer: DNS request received!
13:05:37 DNSServer: Source: ('192.168.1.111', 56010)
13:05:37 DNSServer: Domain: push.apple.com
13:05:37 DNSServer: ***forward request
13:05:37 DNSServer: -> DNS response from higher level
13:05:37 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
13:05:42 DNSServer: DNS request received!
13:05:42 DNSServer: Source: ('192.168.1.111', 56010)
13:05:42 DNSServer: Domain: push.apple.com
13:05:42 DNSServer: ***forward request
13:05:42 DNSServer: -> DNS response from higher level
13:05:42 DNSServer: Source: ('192.168.1.111', 59273)
13:05:42 DNSServer: Domain: 29-courier.push.apple.com
13:05:47 DNSServer: DNS request received!
13:05:47 DNSServer: Source: ('192.168.1.111', 51354)
13:05:47 DNSServer: Domain: 29-courier.push.apple.com
13:05:47 DNSServer: ***forward request
13:05:47 DNSServer: -> DNS response from higher level
13:05:47 DNSServer: Source: ('192.168.1.111', 59273)
13:05:52 DNSServer: DNS request received!
13:05:52 DNSServer: Source: ('192.168.1.111', 51354)
13:05:52 DNSServer: Domain: 29-courier.push.apple.com
13:05:52 DNSServer: ***forward request
13:05:53 DNSServer: -> DNS response from higher level
13:05:53 DNSServer: DNS request received!
13:05:53 DNSServer: Source: ('192.168.1.111', 59273)
13:05:53 DNSServer: Domain: 29-courier.push.apple.com
13:05:53 DNSServer: ***forward request
13:05:58 DNSServer: DNS request received!
13:05:58 DNSServer: Source: ('192.168.1.111', 51354)
13:05:58 DNSServer: Domain: 29-courier.push.apple.com
13:05:58 DNSServer: ***forward request
13:05:58 DNSServer: -> DNS response from higher level
13:05:58 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
13:05:58 DNSServer: Source: ('192.168.1.111', 59273)
13:13:01 PlexConnect: Shutting down.
13:13:02 WebServer: Shutting down (HTTP).
13:13:02 WebServer: Shutting down (HTTPS).
13:13:03 DNSServer: Shutting down.
13:13:03 PlexConnect: shutdown
