Not working on atv3
This is my first time using Plex so i´m probably doing it wrong...I have followed all these steps to put plex into a not jailbreaken device and i don´t get an error code or something like that, but when i look on the ATV3 and push trailer it just..plays the trailer, It looks just like before. What am I missing??
And sorry i´m new to this and my english isn´t the best so be nice :)
Did you change your ATV dns from auto to manual to point at your plexconnect host? Use this to post your error.
https://forums.plexapp.com/index.php/topic/69410-read-before-posting/
Well, i don´t have something called plexconnect. Just plex media server. It´s the only one i found so I thought it was the same. But...it isn´t?
No, not the same.
Plex Media server is - yeah - the media server.
PlexConnect is a "little tool" to allow your aTV interfacing PMS. See WIKI on how to install/use.
No, not the same.
Okey, i have installed Plexconnect and followed the steps in the wiki.(Followed this one https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Windows)
But it still wont work, When i put the DNSserver on the atv it doesn´t show it right. It should be .00 on the end but it´s just .0 at the end. I´m going crazy soon.
is this the right thing i am posting now...?
21:53:08 PlexConnect: started: 21:53:08
21:53:08 Settings: getsetting enable_plexconnect_autodetect=True
21:53:08 PlexConnect: IP_self: 192.168.1.80
21:53:08 Settings: getsetting port_webserver=80
21:53:08 Settings: getsetting hosttointercept=trailers.apple.com
21:53:08 Settings: getsetting enable_dnsserver=True
21:53:09 Settings: getsetting enable_webserver_ssl=True
21:53:09 DNSServer: started: 21:53:09
21:53:09 Settings: getsetting port_dnsserver=53
21:53:09 Settings: getsetting ip_dnsmaster=8.8.8.8
21:53:09 Settings: getsetting prevent_atv_update=True
21:53:09 DNSServer: ***
21:53:09 DNSServer: DNSServer: Serving DNS on 192.168.1.80 port 53.
21:53:09 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.80
21:53:09 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:53:09 DNSServer: forward other to higher level DNS: 8.8.8.8
21:53:09 WebServer: started: 21:53:09
21:53:09 Settings: getsetting port_webserver=80
21:53:09 WebServer: ***
21:53:09 WebServer: WebServer: Serving HTTP on 192.168.1.80 port 80.
21:53:09 ATVSettings: init class CATVSettings
21:53:09 ATVSettings: load settings
21:53:09 Settings: getsetting port_ssl=443
21:53:09 Settings: getsetting certfile=./assets/certificates/trailers.pem
21:53:09 WebServer: WebServer: Serving HTTPS on 192.168.1.80 port 443.
Could you please explain a little, what you try to tell here? I really don't seem to understand your issue...
Oh sorry, I see now that notepad says IP_self: 192.168.1.80. In Cmd i saw IP_self: 192.168.1.00 . And the appletv would´nt take the last part. But i was wrong, but i´ve put in the right now but when i push trailer it says "trailer is unavailable, try again later" And i´m out of ideas now :(
as always... loglevel=High and logs...
That´s what i did, it says
loglevel = High in settings.cfg.
And the log is the same as the one before..
22:24:30 PlexConnect: started: 22:24:30
22:24:30 Settings: getsetting enable_plexconnect_autodetect=True
22:24:30 PlexConnect: IP_self: 192.168.1.80
22:24:30 Settings: getsetting port_webserver=80
22:24:30 Settings: getsetting hosttointercept=trailers.apple.com
22:24:30 Settings: getsetting enable_dnsserver=True
22:24:31 Settings: getsetting enable_webserver_ssl=True
22:24:31 DNSServer: started: 22:24:31
22:24:31 Settings: getsetting port_dnsserver=53
22:24:31 Settings: getsetting ip_dnsmaster=8.8.8.8
22:24:31 Settings: getsetting prevent_atv_update=True
22:24:31 DNSServer: ***
22:24:31 DNSServer: DNSServer: Serving DNS on 192.168.1.80 port 53.
22:24:31 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.80
22:24:31 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:24:31 DNSServer: forward other to higher level DNS: 8.8.8.8
22:24:31 WebServer: started: 22:24:31
22:24:31 Settings: getsetting port_webserver=80
22:24:31 WebServer: ***
22:24:31 WebServer: WebServer: Serving HTTP on 192.168.1.80 port 80.
22:24:31 ATVSettings: init class CATVSettings
22:24:31 ATVSettings: load settings
22:24:31 Settings: getsetting port_ssl=443
22:24:31 Settings: getsetting certfile=./assets/certificates/trailers.pem
22:24:31 WebServer: WebServer: Serving HTTPS on 192.168.1.80 port 443.
After some more clicking. i now get this.
22:52:20 PlexConnect: started: 22:52:20
22:52:20 Settings: getsetting enable_plexconnect_autodetect=True
22:52:20 PlexConnect: IP_self: 192.168.1.80
22:52:20 Settings: getsetting port_webserver=80
22:52:20 Settings: getsetting hosttointercept=trailers.apple.com
22:52:20 Settings: getsetting enable_dnsserver=True
22:52:20 Settings: getsetting enable_webserver_ssl=True
22:52:20 DNSServer: started: 22:52:20
22:52:20 Settings: getsetting port_dnsserver=53
22:52:20 Settings: getsetting ip_dnsmaster=8.8.8.8
22:52:20 Settings: getsetting prevent_atv_update=True
22:52:20 DNSServer: ***
22:52:20 DNSServer: DNSServer: Serving DNS on 192.168.1.80 port 53.
22:52:20 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.80
22:52:20 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:52:20 DNSServer: forward other to higher level DNS: 8.8.8.8
22:52:20 WebServer: started: 22:52:20
22:52:20 WebServer: ***
22:52:20 WebServer: WebServer: Serving HTTP on 192.168.1.80 port 80.
22:52:20 ATVSettings: init class CATVSettings
22:52:20 ATVSettings: load settings
22:52:20 Settings: getsetting port_ssl=443
22:52:20 Settings: getsetting certfile=./assets/certificates/trailers.pem
22:52:20 WebServer: WebServer: Serving HTTPS on 192.168.1.80 port 443.
22:52:25 DNSServer: DNS request received!
22:52:25 DNSServer: Source: ('192.168.1.89', 59158)
22:52:25 DNSServer: Domain: init.itunes.apple.com
22:52:25 DNSServer: ***forward request
22:52:25 DNSServer: -> DNS response from higher level
22:52:25 DNSServer: Source: ('192.168.1.89', 56715)
22:52:25 DNSServer: Domain: www.apple.com
22:52:25 DNSServer: Source: ('192.168.1.89', 61047)
22:52:25 DNSServer: Domain: EVIntl-ocsp.verisign.com
22:52:26 DNSServer: DNS request received!
22:52:26 DNSServer: Source: ('192.168.1.89', 54798)
22:52:26 DNSServer: Domain: itunes.apple.com
22:52:26 DNSServer: ***forward request
22:52:26 DNSServer: -> DNS response from higher level
22:52:26 DNSServer: Source: ('192.168.1.89', 64799)
22:52:26 DNSServer: Domain: xp.apple.com
22:52:26 DNSServer: Source: ('192.168.1.89', 53559)
22:52:26 DNSServer: Domain: configuration.apple.com
Still dont work though.
Is that the log or the output of the cmd window? They are 2 different things.
I have no idea. It´s the thing in the plexconnect.log
It feels like i´m missing something but i have no idea! I´m usually good at this stuff but this is making me feel like a 3 year old.
I have installed Python 2.7
taken home Plexconnect and extracted it to my program x86.And to here it feels right because i have the files and all.
I took iphone configuration and connected my apple tv to the computer and installed the certifikate. I layed it in truster rootcertifikate and tryed to let windows do it automatically.
I´ve put in the Ip_self in DNSserver on Atv3. But it won´t work anyway.
What am i missing? The log is still the same..
The log we are looking for a file inside the PlexConnect directory - called PlexConnect.log. With loglevel=High, it should show way more content.
Hi mate,
Is your PlexConnect detecting your PMS? If not, try installing PlexConnect 0.2 (I had this problem and going back to 0.2 auto detected my PMS. Manually specifying my PMS IP in settings.cfg didn't help either for me). Also, if you are using any firewalls, make sure you allow all traffic for PlexConnect (Again, this was another issue I had and took me ages to figure this out!). There are a number of ports that are required for various activities so if you have an interactive or learning mode on your firewall, this is probably your best option.
Good luck!
Hmm, I uninstalled everything and started over, same problem but another log.
20:06:56 PlexConnect: started: 20:06:56
20:06:56 Settings: getsetting enable_plexconnect_autodetect=True
20:06:56 PlexConnect: IP_self: 192.168.1.80
20:06:56 Settings: getsetting port_webserver=80
20:06:56 Settings: getsetting hosttointercept=trailers.apple.com
20:06:56 Settings: getsetting enable_dnsserver=True
20:06:56 Settings: getsetting enable_webserver_ssl=True
20:06:57 DNSServer: started: 20:06:57
20:06:57 Settings: getsetting port_dnsserver=53
20:06:57 Settings: getsetting ip_dnsmaster=8.8.8.8
20:06:57 Settings: getsetting prevent_atv_update=True
20:06:57 DNSServer: ***
20:06:57 DNSServer: DNSServer: Serving DNS on 192.168.1.80 port 53.
20:06:57 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.80
20:06:57 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:06:57 DNSServer: forward other to higher level DNS: 8.8.8.8
20:06:57 WebServer: started: 20:06:57
20:06:57 Settings: getsetting port_webserver=80
20:06:57 WebServer: ***
20:06:57 WebServer: WebServer: Serving HTTP on 192.168.1.80 port 80.
20:06:57 ATVSettings: init class CATVSettings
20:06:57 ATVSettings: load settings
20:06:57 Settings: getsetting port_ssl=443
20:06:57 Settings: getsetting certfile=./assets/certificates/trailers.pem
20:06:57 WebServer: WebServer: Serving HTTPS on 192.168.1.80 port 443.
20:07:04 DNSServer: DNS request received!
20:07:04 DNSServer: Source: ('192.168.1.89', 63951)
20:07:04 DNSServer: Domain: trailers.apple.com
20:07:04 DNSServer: ***intercept request
20:07:04 DNSServer: -> DNS response: 192.168.1.80
Hi mate,
Good luck!
hi!
What do you mean with the first question? How can I see that?
Yes, I maked rules for everything with plex and python so it would go through :)
Did you get the certificate installed on the appletv?
Should show up under settings>profiles.
If it doesn't, try adding it back using http://your self ip address/trailers.cer
I can see it under profiles :)
Since i changed the DNSservice on atv  netflix don´t work either on the atv. just "netflix/itunes/trailers is currently unavailable. try again later"
With PlexConnect running? You are kidding, aren't you? :-D
haha no!! That´s the sad thing, I have no idea of what i´m doing. I just guess and apparently something is really wrong when you say it like that :D
22:45:05 PlexConnect: started: 22:45:05
22:45:05 Settings: getsetting enable_plexconnect_autodetect=True
22:45:05 PlexConnect: IP_self: 192.168.1.80
22:45:05 Settings: getsetting port_webserver=80
22:45:05 Settings: getsetting hosttointercept=trailers.apple.com
22:45:05 Settings: getsetting enable_dnsserver=True
22:45:05 Settings: getsetting enable_webserver_ssl=True
22:45:05 DNSServer: started: 22:45:05
22:45:05 Settings: getsetting port_dnsserver=53
22:45:05 Settings: getsetting ip_dnsmaster=8.8.8.8
22:45:05 Settings: getsetting prevent_atv_update=True
22:45:05 DNSServer: ***
22:45:05 DNSServer: DNSServer: Serving DNS on 192.168.1.80 port 53.
22:45:05 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.80
22:45:05 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:45:05 DNSServer: forward other to higher level DNS: 8.8.8.8
22:45:05 WebServer: started: 22:45:05
22:45:05 WebServer: ***
22:45:05 WebServer: WebServer: Serving HTTP on 192.168.1.80 port 80.
22:45:05 ATVSettings: init class CATVSettings
22:45:05 ATVSettings: load settings
22:45:05 Settings: getsetting port_ssl=443
22:45:05 Settings: getsetting certfile=./assets/certificates/trailers.pem
22:45:05 WebServer: WebServer: Serving HTTPS on 192.168.1.80 port 443.
22:45:51 DNSServer: DNS request received!
22:45:51 DNSServer: Source: ('192.168.1.89', 63244)
22:45:51 DNSServer: Domain: trailers.apple.com
22:45:51 DNSServer: ***intercept request
22:45:51 DNSServer: -> DNS response: 192.168.1.80
When you launch PlexConnect, do you see anything like the below?
PlexGDM: servers discovered: 1
XMLConverter: PlexGDM - PMS: 192.168.1.80:32400 (or something similar)
