Audio Enhancements: Boost Dialog & Normalize Loudness
Hey all -
We’ve all had this evening: you nudge the volume up to catch a whispered line, and three seconds later an explosion wakes the entire house.
Today we’re bringing two new audio playback options to Plex Pass subscribers — Boost Dialog and Normalize Loudness —available now with Plex Media Server 1.43.4.
Boost Dialog
Isolates the frequencies where dialog lives and brings them forward, so quiet conversations are easier to follow without turning everything else up with them.
Normalize Loudness
Keeps audio at a comfortable, consistent level and takes the edge off very loud scenes — no more reaching for the remote every time the score swells.
How do I turn them on?
There’s nothing to set up on the server — both are ready to go. During playback, bring up the on-screen controls and select Playback Settings (the gear icon), then Playback Options, and switch on whichever you’d like to use.
Note: enabling either option will cause the audio to be transcoded.
Don’t see Normalize Loudness yet?
Boost Dialog works on anything. Normalize Loudness needs the audio analyzed first, and if that hasn’t happened for an item yet, the option won’t appear for it.
Your server handles this on its own. Two settings control it, both already enabled by default:
  • Settings > Library > Analyze audio tracks for loudness, set to As a Scheduled Task
  • Enable Loudness Analysis in the advanced settings of each movie and TV library
Analysis runs during your server’s scheduled maintenance window, so Normalize Loudness will show up across more of your library over the coming days. If you’d rather not wait, you can analyze items on demand — the contextual menu in Plex Web, or Manage Settings in the mobile apps.
A large library means a lot of analyzing, and you may notice higher CPU usage while your server works through it. If you’d rather it didn’t, set Analyze audio tracks for loudness to Never. And if you want new additions analyzed the moment they land, switch it to As a Scheduled Task and when media is added.
Curious whether a specific track is ready? An analyzed audio stream shows true in Media info and canNormalizeLoudness="1" in the stream info in the XML.
Requirements
Plex Media Server 1.43.4 or newer, and one of:
  • Plex for Mobile (Android & iOS) from 2025.28.0
  • Plex for Android TV from 2025.28.0
  • Plex for Apple TV from 2025.28.0
  • Plex for Amazon Fire TV from 2025.8.0
  • Plex for Roku from 9.0.31
  • Plex Web (Coming Soon)
  • Plex for Smart TVs (Coming Soon-ish)
* Plex for Apple TV and Plex for Android TV require the new experience apps. The App has begun the public rollout on Apple TV with the public rollout of Android TV coming soon (In the meantime it is available in preview
** Gaming consoles use the ‘Plex for Smart TVs’ app and will be available when it is released there
*** Desktop Apps will be updated soon after the Web release, HTPC will be updated shortly after the Smart TV release.
About Plex Pass
Loudness analysis runs on servers whose admin has an active Plex Pass. Using Boost Dialog and Normalize Loudness during playback needs a Plex Pass on your own account — or membership in a Plex Home whose admin has one.
For the full walkthrough with screenshots, see the Audio Track enhancements for video support article.
If you run into any bugs or have feedback, create a topic in the Plex Media Server category and tag it with audio
