Hi
Since I installed the new version of Plex on my Xbox One yesterday, I cannot use the French Track. Either I select French or English Track the audio is on English.
Any clue what’s happen ?
Hi
This appears to be a bug in the app that has secondary audio not being used even though it is selected. The developers are aware of the issue and trying to recreate it so they can trace back where it is coming from.
A few questions:
Do you have language settings set to autoselect french?
Have you tried audio selection during playback?
Have you tried audio selection on the pre-play screen? (The screen you hit the play button on)
Same for me, in some movies it worked but i need to activate subtitles before being able to switch audio track.
to answer questions,
yes language settings is french,
xbox french too.
audio selection tested before, and during playback.
moreover subtitles disapeare during playback, have to reload play to make them reappear.
every tests done on differents movies in different library.
That is pretty interesting.
xbox french too.
Thanks for the quick feedback, I have forwarded it on to the developers to hopefully get something rolling quicker.
This is a known issue that the developers are tracking down. It has been seen over different clients so the developers are still actively troubleshooting it as well.
@jepeto said:
Same for me, in some movies it worked but i need to activate subtitles before being able to switch audio track.to answer questions,
xbox french too.
audio selection tested before, and during playback.moreover subtitles disapeare during playback, have to reload play to make them reappear.
Same here with german
Same here with Spanish. In tv is correct but in Xbox one dont work…always in english :\
answer to the questions,
Do you have language settings set to autoselect french? YES
Have you tried audio selection during playback? YES
Have you tried audio selection on the pre-play screen? (The screen you hit the play button on) - YES
Nothing help me to get the French Track
Eric
Hi folks. We’ve identified the issue and will have a fix in the next update. For now you can work around the issue by going to the app settings -> Video -> and setting Allow Direct Play to false.
@Moussa said:
Hi folks. We’ve identified the issue and will have a fix in the next update. For now you can work around the issue by going to the app settings →Video→ and settingAllow Direct Playto false.
In app in the pc or in app on xbox one?
In the Xbox One app.
Thanks for the workaround, it worked
hope this gets fixed soon in next version
Hi Moussa,
Disable “allow direct play” work with 90% of MKV, but a few still playing without sound. Sometime activate subtitle may the sound work again, sometime not.
(I’m french, sorry for my bad english).
v2.0.4 should now be available to you all, which includes a fix for this bug.
