Audio transcode on LG G2 and Sonos ARC is stereo only
Server Version#: 1.42.1.10060
Player Version#: 5.93.2
Hi Everyone,
I am using a LG G2 connected via eARC to a SONOS Arc which is working fine. Supported formats are directplaying, e.g. eAC3 with Atmos is working great.
What I cannot get to work is transcoded multichannel audio (e.g. DTS / TrueHD). The transcoder chooses 5.1 AAC, but it is only played back as stereo (showing “Stereo PCM” in the SONOS App, also confirmed with surround test file). I first thought was that SONOS might not support multichannel AAC, but if I transcode e.g. DTS-HD → AAC 7.1 first using Tdarr, it playbacks fine in Plex using directplay and all channel information are there (showing “Dolby Multichannel PCM” in the app).
I looked at the log, and that also seems fine, choosing AAC with 6 channels (see below).
Does anyone know why this is happening. Somehow directplay of multichannel AAC works, but transcode of multichannel AAC ends up in stereo.
Any help is greatly appreciated. Please let me know if I should post the whole log file (I was not sure which files would be needed)
Server log:
Sep 02, 2025 03:08:04.541 [22706704051000] DEBUG - [Req#d792/Transcode] Streaming Resource: Reached Decision id=843 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=1498 part=(id=1498 decision=transcode container=mpegts protocol=hls streams=(Video=(id=7219 decision=copy width=1920 height=1080) Audio=(id=7223 decision=transcode bitrate=774 encoder=aac channels=6 rate=48000))))
