Just wondering if an Auto Play Feature is available yet for TV series?.
Playlists are working for any content I have used so far for example tv shows & movies.
How do I make a playlist?.
Plexweb (Pms settings). Just tap a show or movie and on the left there is a option to add to playlist.
I am only talking about on the Apple TV
Also, if you start a TV show from Unwatched etc, it seems to to a play all on the other episodes in that season (or at least it was in the original version that introduced continuous play on playlists, but I have not done this recently), but it doe snot do this from On Deck.
At this time you must add content via plexweb to a playlist then using the playlist tab on the atv you can play the entire playlist.
Unless this is a plexpass feature or I am overlooking the option to add content I don’t see the option to add content whatsoever via the ios app(s). You can mange playlist such as deleting content but everything else you had suggested I cannot locate.
you tap and hold on an item (be it episode, season, series, movie etc) then you get the option to add to playlist. And you can also add a new playlist on this screen. It’s not plexpass at the app level as I did it signed out (maybe plexpass at the server)
i am having an issue using subtitles in the episode view.. then i press play for continious play.. the subtitle won't load..i must enter through the pre play for the subtitle to loads.. any thoughts on this ibaa?
Yes, known - at least for the later episodes.
Connected (but even more complicated...) to the issue "auto-played episodes are not marked as watched".
Alright then ur aware of the issue :)
just wanted to se if i was the only one with this problem
cheers
You are.
Usually I don't use subtitles. So I have no issues... :-D
The iOS app does not add playlists correctly, at least in my experience. Plexweb does a much better job adding them by season 1 list, season 2 list, etc.You can add through any client that allows for management of the playlist, this includes iOS (iPhone/iPad)
I have added some music videos into a playlist, but they don`t play continuously on ATV3 plexconnect. Playlist shows up and I select it to play but it plays one video and then stops. What I am doing wrong?
EDIT- Please ignore, its working now.
