Automating TS File Compression
After testing the plex OTA recording compression and commercial removal options without much success and getting tired of doing it semi-manually I created a simple powershell script that makes a list of ts files in the libraries, copies them to the workstation, calls handbrakecli to convert, moves the converted files the source library and deletes the sources. It has been running for a few days and I can’t see any issues. Anyone else doing something like this?
