autossh
Hi all,
It is great to see that an awesome application such as Plex was ported to raspberry Pi, however, I have a question:
Is it possible to install autossh on RasPlex? This would be great since I need to use the Pi to control a few servers and I need to have permanent ssh tunnels between them.
Cheers,
Lucian
The /storage partition can be used to put anything you wan't there. But you need a arm/raspberry version of autossh...
Thank you for your answer! You mean that I can simply install autossh like I did in ubuntu? apt-get install autossh?
No - RasPlex has no apt support. But you may just use the rasbian package (extract it and copy the binary to storage)
Cool! I'll try that! Thanks
