AVI is transcoding, Direct Stream not working
I have an AVI file without subtitles. It tries to transcode this on the AppleTV. I'm only using Direct Play/Stream so i can't play this AVI file. An AVI file could be used for direct play/stream right?
Video
Codec MPEG4
Bitrate 2997 kbps
Duur 1:31:28
Frame Rate 25.000 fps
Height 720
Width 1280
Audio
Codec MP3
Kanalen Stereo
Bitrate 320 kbps
Bitrate Mode CBR
Duur 1:31:28
Sampling Rate 48000 Hz
Stream Identifier 1
Anyone knows why this cannot be used for Direct Play/Stream?
Here are the formats supported by the ATV. AVI's can play directly but only M-JPEG video, which is not the above case.
The embedded video/audio codecs are important: MP4/MP3 codecs should not need a full transcode - "direct streaming" (i.e. only swapping the AVI container) should work fine on that file.
Yes, you are right, but it will need a remux from AVI to MP4 or M4V in order to be tested.
