I’ve been putting my PC to sleep for the last few months after 11:00pm. To do this I had to programmatically turn off awaymodesupported before the PC would go to sleep. When it woke up, I would turn the option back on. The last couple of day the system would not go to sleep it would only go into away mode. Which only cuts power draw by 50%. Now when I try to turn off or on the option the request does not give an error. But the option value does not change.
where is the other one? When I look at my posts before I did the second post I didn’t see my post.
Here’s your first post, at 9:53am US Central: What is the deal with awaymodesupport
Closed it to avoid replies split across both, which can lead to unintentional misleading info, etc.
50 lashes with a wet noodle. ![]()
the only reason I reposted is becasue it didn’t show up in my posts.
