Just setup my first RasPlex using version 1.37.
It's picked up the remote using CEC/Simplink.
Everything work's apart form the Skip Forward/Backward/Return/EXIT button.
The TV is a LG 32LH2000.
How can I get the Return/EXIT button working. maybe map it to another button? I'm a noob when it comes to SSH so I'd prefer to do it via modifying the SD Card via PC if possible.
This is what the remote looks like:
I feel your pain. I could not get my Back button working reliably either. It would seem to go in spurts where it would work for a bit before not working. More often than not it would not work. Not sure if it's an issue with my TV or Rasplex.
In that case can a anyone recommend a reliable mini-Bluetooth dongle and a Bluetooth remote that'll work with RasPlex out of the box?
It’s not Bluetooth, but the flirc.tv dongle works like a charm and let’s you use any Remote
It's not Bluetooth, but the flirc.tv dongle works like a charm and let's you use any Remote
£24.99 That's pretty damn steep considering it's only $22.95 which should be £14.61.
I feel your pain too.I had the exact same problem with a similar model TV. Just recently I picked up a Windows Media Center remote with a USB IR receiver. Worked like a charm out of the box
Not ideal to have two remotes, but at least its functional
Hey. I had this exact same issue literally a few days ago. I have the exact same TV model. Looks like its a known issue with the back button not working as expected with CEC on that TV model. I had to reprogram the "stop" button on the remote to act as a "back" button instead of "stop".:
Enable SSH in RasPlex
Open new Terminal window and type:
ssh root@192.168.0.1
Enter password: rasplex
Type:
cp /usr/share/xbmc/system/keymaps/remote.xml /storage/.xbmc/userdata/keymaps/
then cd /storage/.xbmc/userdata/keymaps/
nano remote.xml
Change the following line
Stop
to
Back
Save & Quit
Reboot Plex
This remaps the Stop button to perform the back function as the Back button does not work through CEC on my LG TV
Hope this helps.
