Server Version#: Latest Plex Pass
I just upgraded my server CPU from a Xeon D-1541 to a Xeon E5-2680v3. Now my background transcodes (Mobile Sync, Optimized Versions) are crawling and my CPU usage is less than 10% during the process. Why would Plex not use more available CPU power?
FYI my Background transcoding x264 preset is set to Super Fast.
EDIT: I’ve narrowed this down to only files with EAC3 audio. It doesn’t just affect the background transcodes of said files, playback of them does not work at all either.
Logs shows:
Feb 13, 2019 14:59:46.240 [0x1496105df700] DEBUG - Beginning read from two-way stream.
Feb 13, 2019 14:59:48.000 [0x1496129f4700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-51a441f8-2a29-4efc-b1d3-815ea2eb75e6/EasyAudioEncoder/Convert to WAV (to 8ch or less)/im5r3t14xdgms4aef2yl4534_466-0-3.wav'
Feb 13, 2019 14:59:48.001 [0x149593dfe700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] error reading output
Feb 13, 2019 14:59:48.001 [0x1496105df700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 13, 2019 14:59:51.000 [0x149593dfe700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-51a441f8-2a29-4efc-b1d3-815ea2eb75e6/EasyAudioEncoder/Convert to WAV (to 8ch or less)/im5r3t14xdgms4aef2yl4534_466-0-4.wav'
Feb 13, 2019 14:59:51.001 [0x1496105df700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] error reading output
Feb 13, 2019 14:59:51.001 [0x1496129f4700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 13, 2019 14:59:54.000 [0x1496105df700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-51a441f8-2a29-4efc-b1d3-815ea2eb75e6/EasyAudioEncoder/Convert to WAV (to 8ch or less)/im5r3t14xdgms4aef2yl4534_466-0-5.wav'
Feb 13, 2019 14:59:54.001 [0x1496129f4700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] error reading output
Feb 13, 2019 14:59:54.001 [0x149593dfe700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 13, 2019 14:59:57.000 [0x1496129f4700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-51a441f8-2a29-4efc-b1d3-815ea2eb75e6/EasyAudioEncoder/Convert to WAV (to 8ch or less)/im5r3t14xdgms4aef2yl4534_466-0-6.wav'
Feb 13, 2019 14:59:57.001 [0x149593dfe700] ERROR - [Transcoder] [eac3_eae @ 0x7d1840] error reading output
Feb 13, 2019 14:59:57.001 [0x1496105df700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
