Backup Strategies - 300GB Plex Library Folder
Hi All
I’ve been slowly building my Plex library before Plex even existed (started with XBMC on the original Xbox way back when). After more than a decade collecting and using Plex (along with media indexing), my Plex lIbrary folder has grown to about 300 GB in size with about 600k files within the Library folder. I’ve also started sharing my library with family, having about 6-7 family members in various time zones using Plex almost 24/7.
This unfortunately has had me scratching my head a bit on how to regularly backup the Library in the event of data loss / corruption. Note this is just the library, not the media itself.
Plex has a great KB on how to backup, essentially saying to backup your entire Library folder, but when this is 300 GB, it poses some interesting challenges:
  1. To get a consistent database backup, you should really stop Plex before executing the backup task.
  2. Using tar or tar / gzip (or zip, gzip or other compression mechanism) can take about 3-4 hours.
  3. Using rsync to a remote host can take 12-24 hours in my experience
  4. Using sometihg like rclone to backup to Amazon Drive/Google Drive is even worse, taking about 40 hours (with subsequent incrementals taking about 4-8 hours).
  5. Excluding the .bif files will significantly reduce the size, but the .bif files only account for about 2% of the total number of files. It’s been my experience that the sheer amount of data Plex stores within the Library folder (excluding the Caches which can be rebuilt) causes any kind of activity requiring action on all the files to take an enormously long time (when your LIbrary is 300GB).
Bandwidth isn’t an issue (250mbit pipe), but still, uploading a backup can take hours.
Ideally, I’d have a daily backup for 2 weeks and a monthly backup for 12 months. I can’t imagine having to rebuild this were I to lose it (I also have a lot of custom metadata that I’ve edited in Plex over the years).
Anyway, just curious if others with big libraries such as myself have a regular backup strategy for their Library folders (again, not the media, just the Library folders).
Thanks!
My library is a good bit bigger than what you are looking at, but I use a external USB 3.0 hard drive and FreeFileSync to ensure a “copy” of what is on the media server drive is also on the USB backup hard drive. Works great.
Mine is 80GB (1.5 million files). Quite a difference from yours.
I find myself not really caring all to much about my Plex database. Damn near everything in my libraries was added automatically with no manual changes. Because of this, I can just recreate my database with a few clicks of the mouse. Of course, I do realize it will take time to rebuild but it’s a ‘set it and forget it’ thing.
But, If I was going to… I’d go with backing up on a USB drive every week or so… That is, if I wasn’t adding content all that often. Though, if I made changes constantly, I’d probably go with some sync program to sync newly added via USB every couple of days on multiple drives…
