Hoping someone could help me. My Plex Server specs are GTX 1050, Ryzen 5 1500x, and 16 gigs of RAM. Windows 10 Pro. My server is fully up to date.
All my networking gear is gigabit. and cat6.
I have plex signed in on PS5 and that is connected to a 4k tv. I have attached some screens below of the files I’m playing. If you need any other info or know of settings that I should be changing that would be nice.
Video does not stream at a steady rate. It is normal to see traffic spikes as the client buffer empties and it asks the server for a refill. The refill happens as fast as possible, not at the rate the video is played. You will see large spikes at the beginning of a movie, when moving between chapters, etc. The peaks for LAN attached equipment will be higher since wired Ethernet typically has greater bandwidth than WiFi attached or remote clients.
Direct playing Blade Runner 2049, 4K HDR using Plex for Windows. PC using gigabit Ethernet. First spike to 300 Mbps is at movie launch. Second is jumping between chapters.
Direct playing same movie on my phone connected via 2.4GHz, 802.11n WiFi. The peaks are not as high but are sustained over longer periods. This is expected since the WiFi connection does not have the same bandwidth (~70 Mbps) as wired Ethernet (1 Gigabit), so it takes longer to transfer the same amount of data.
Some clients are a bit daft about downloading/caching/streaming any poorly-formatted files. If the audio and video in the file aren’t perfectly muxed together, the client can download a bit, throw it out, download another bit, throw it out.
Remuxing can often greatly improve this. Disabling Direct Play in Plex will allow Plex to remux it on the fly. Or manually remuxing will permanently rebuild the file contents in a “good” order.
