Does anyone know if it's going to be possible to display this image, or if i'm out of luck?
Thanks a lot for any and all help.
M
There doesn’t seem to be anything within the channel framework to do this directly, but I suppose you could try to decode it with the python base64 lib.
So something like:
import base64
thumb=base64.b64decode(thumbdata)
http://docs.python.org/2/library/base64.html#base64.b64decode
The problem is then I’m not sure if DirectoryObject can handle passing the actual binary data or if it only works with a path (I’ve only ever used it with a path before). From what I just read here it doesn’t look like it:
http://dev.plexapp.com/docs/api/objectkit.html?highlight=directoryobject#PopupDirectoryObject.thumb
I think you can do it like so:
oc.add(DirectoryObject(<br />
key = Callback(...),<br />
title = title,<br />
thumb = Callback(GetThumb, url=url)<br />
))<br />
<br />
# ...<br />
<br />
def GetThumb(url):<br />
<br />
try:<br />
# Lookup the image data (via an xpath query in this example)<br />
base64_img = HTML.ElementFromURL(url).xpath('//img/@data-image')[0]<br />
# Decode the base64 data. String.Decode is a framework function: http://dev.plexapp.com/docs/api/utilkit.html?highlight=base64#String.Decode<br />
decoded_image = String.Decode(base64_img)<br />
# Return the image as a DataObject<br />
return DataObject(decoded_image, 'image/jpeg')<br />
except:<br />
# If anything fails, return the default icon<br />
return Redirect(R('icon-default.png'))<br />
Hey. Getting back around to looking at this again, hoping you could break down your example a little bit.
In your example, this line in particular confuses me: base64_img = HTML.ElementFromURL(’//img/@data-image’)[0]
Doesn’t HTML.ElementFromURL() need a URL? Or is HTML in this example storing a connection somehow from somewhere else? Also - you pass ‘url’ to your GetThumb(url) method, but i don’t see it being used anywhere else in the method.
Hoping you could just help break it down a little and clear it up a bit. I have setup this URL for testing: http://thorsonmscott.com/base/index.html Index.html contains only a single element with a base64 encoded image of a delicious pizza. Maybe you could rewrite your example using that URL?
EDIT: I wrapped the single element inside a
Hello Max!
My example contained an error, sorry about that! Here is the example code again (fixed) with your demo url and pizza image:
<br />
title = 'Delicious Pizza',<br />
thumb = Callback(GetThumb, url='http://thorsonmscott.com/base/index.html')<br />
))<br />
<br />
# ...<br />
<br />
<br />
try:<br />
# Lookup the image src (via an xpath query in this example)<br />
base64_img_src = HTML.ElementFromURL(url).xpath('/div/img/@src')[0]<br />
<br />
# The img src attribute contains the base64 encoded data, but it also contains the text 'data:image/jpeg;base64', which we don't need.<br />
base64_img_data = base64_img_src.split(',')[-1]<br />
<br />
decoded_image = String.Decode(base64_img_data)<br />
<br />
<br />
except:<br />
Oh, awesome! Thanks so much for your reply. I’m going to give this a shot right now but the example looks like it’ll work.
Thanks again, the help on this forum is always appreciated.
EDIT: I just noticed that we’re both drinking out of mugs in our avatars… developers, am i right?
Ok, I feel like i’m making progress, but still not getting the results I’m hoping for. In your latest example:
