SMB path for thumb
I am currently working on a plugin/channel.  When populating a directoryobject I am trying to use an image that via the SMB share.  The image/thumb never shows up.  Is this supported or am I doing it wrong.  Below is a sample format of what I have it do.  The object builds fine and functions as designed.  I just can't get it to pull the thumb image from a smb share.
oc.add(DirectoryObject(key = Callback(Info, ID=ID),
                                       title = Name + '(' + ID + ')',
                                       thumb = smb://username:password@SERVER/path/file.png
Thanks for any help you all can give.
Will not use SMB as I don't think Plex will work with it.  My only other option would be UNC paths.  Is there a way to pass unc paths for the thumb images and fanart?
Making some progress but stuck here now.
For the thumb image I pass file://server/public/images/image.png and it works on the Server.  When the channel is accessed from a client it makes the request look like :
http://127.0.0.1:32400/file://server/Users/Public/images/image.png
This returns a 404 error obviously but when it is accessed from the server it makes a call like this:
and this works.  I can access it from the client with the above path so my question is, what triggers plex to add http://127.0.0.1:32400/ in front when accessed from the client?  Can this be removed or triggered to not happen?
Even when the URL wouldn't include the 127.0.0.1 part, it still wouldn't work, because file:// always refers to the a local resource and the image is not available on the clients. For thumbs, the only way to get it working is to have the images available over http.
Thanks for the reply sander.
I have another option but I am not sure if this one is possible.  Is it possible to write and delete to the resource folder from within the plugin?  If so, I can receive the file via the socket connection I am making to the backend source and feed the images that way.
