Basic Database Management Feaures
For the love of all that is holy, can you put a simple delete option for elements of the database? Like delete an old user and their play history? Seriously… This has been requested forever.
Some of us have Plex running on a NAS or in a Docker environment. This makes the ability to edit the database using an external editor painful, or outright impossible.
I agree. In fact I would argue that when you remove/delete a user it should delete everything associated with that user including watch history. etc.
Those of us that add/remove users a lot end up (presumably) with a lot of useless data in the database.
Or make a way to manually purge it in the UI so I don’t have to mess with the DB directly.
