So my movies play subtitles for foreign language films but not for English I’m hoping for some help converting unknown audio files to English but only the unknown files.
I have had a look at several programs and through the forums but I cannot find an answer to my problem.
Ideally I want to scan through all my movies and change any audio tracks that are unknown to English also without having to remux every thing as it goes.
all the tools/scripts i have seen will just change the first audio track to English even if it was meant to be in a foreign language.
I have manually edited all my Foreign films already so all that should be left is unknown English tracks.
Is there a command to check the language first then only change if it is unknown?
Also my films are a mix of mp4 and mkv so again some thing that would do both at the same time.
Thanks in advance
