BBC Red Button on Freeview
Can anyone in the UK with freeview get the BBC red button channel to work. Its on channel 250 and i cant record or play it. I know the channel works on my homerun tuner as i can stream direct from it.
Server Version#: 1.25.5.5492
Player Version#: N/A
Tuner Make/Model: Homerun HDHR5-4DT
Guide/Lineup name: Freeview
Using XMLTV?:
Channel number/Name: 250 / Red button
Probably not much help but it works for me running and old Plex server version 1.24.2.4973.
I don’t update my server very often because of Plex history of updates often breaking more than they fix.
Working ok here, only difference to your setup is i’m using server version 1.25.6.5545
Thanks for the feedback gents, made me look through the channels and found the red button on 601 aswell as 250, 601 is working.
