I’m planning to batch-encode a few series I ripped from DVD. Each of them were filmed, mostly widescreen. I’m planning to encode the episodes to HEVC MP4’s via Handbrake. I want to make sure I nail the proper frame rate at the best quality. I’d rather do this once, so I wanted to bounce a few questions off the community. Here are the settings I’m planning:
Detelecine: Default
Deinterlace: Decomb | Preset: Default | Interlace Detection: Default
Video: x265
FPS: 23.976, Constant (I’ve run into issues in the past with variable frame rates, and I see no reason not to use Constant)
Encoder preset: Medium
Encoder tune: None (none of my content contains much grain)
Constant Quality: 20
Audio: Auto-Passthru AC3
A couple questions here:
- Is there any reason to consider Deinterlace mode of Yadif/Default instead of Decomb/Default? Any advantages? (Yadif/Bob is out because it keeps the pulldown)
- Is it really worth re-encoding AC3 to 5.1 AAC? The size savings are not hugely significant. Are there Plex-related advantages I should consider? In terms of later transcoding, it seems to be a wash, because many of my clients need AAC, but my receiver requires AC3. So either way, it’ll have to transcode audio at times.
- Anything else that I haven’t thought about, but should?
Thank you!
