best setup?
Hi all,
i’m looking at building a nas server, no synology, qnap etc; i would like to be able to transcode h265 1080p or a 4k without any problem.
i need help on deciding which setup is the best and what i could improve. budget 300€.
first setup with intel:
CPU-intel i3 6100
MB-Gigabyte GA-H110M-S2H
RAM- HyperX Fury 2x4Gb ddr4
SSD adata premier pro sp600
PSU- be quiet BN220 schwarz 300W
other setup:
CPU-AMD FX6300
MB- ASUS M5A78L-3/USB3
RAM- HyperX Fury 2x4Gb ddr3
as OS i think i will install ubuntu, and obviously i will use plex for transcoding the movies.
which is the best setup for transcode h265 and 4k?
thanks a lot. if you have suggestions i will appreciate them
@cicciogdg said:
Hi all,
CPU-intel i3 6100
other setup:
CPU-AMD FX6300
you will not be able to transcode h265 unless you go for a very high price CPU.
In order to transcode an x265 1080p, you need a passmark of 8000 for one stream.
The CPU you selected will not work for x265 transcode.
For 4k, it depends on the video codec, which one would you consider ?
How many streams at once do you expect ?
@starbetrayer said:
@cicciogdg said:
Hi all,
CPU-intel i3 6100
other setup:
CPU-AMD FX6300
idk about the 4k, i thought that, in future, i might need that, but i really don’t know.
about the cpu, are you sure that the fx6300 can’t handle a x265, because i read online that someone with the fx6300 can trancode h265 fine.
btw will be the fx8300 able to transcode x265?
@cicciogdg said:
@starbetrayer said:
@cicciogdg said:
Hi all,
CPU-intel i3 6100
other setup:
CPU-AMD FX6300
4K you shouldnt worry about that yet.
for the fx, no
https://www.cpubenchmark.net/cpu.php?cpu=AMD+FX-6300+Six-Core
@cicciogdg said:
@starbetrayer said:
@cicciogdg said:
Hi all,
CPU-intel i3 6100
other setup:
CPU-AMD FX6300
side comment, if your client does not have the capability to red natively x265, plex will transcode that stream in x264.
this is why I am mentioning that number of 8000.
