whats the best way to store the movies and show on google drive and add that “folder” to the plex library?
Just a hint: that must be the dumbest statement ever.
Ofc there is a better and a worse way of doing things. One solution perhaps is old and buggy. One maybe are very new and workes perfect. And so on…
So if thats all you have to say. I recommend for you til next time. Don’t say anything.
Haha, are you for real?
So, to ask questions, one must first know everything about the thing that one are about to ask?
If not, they are just making “nonsense” posts?
So, if one already knows everything about that thing. why ask?
isnt the whole concept about asking, to learn something one dont already know?
you should really consider changing your attitude about people asking questions…
i really miss a block user function on this forum.
stop wasting my time and go do something else instead please.
I suggest you utilize your googlefu, the answers are already out there, you just have to find them.
Googlefu?
Naaw so funny…
Well i gotta admit I found the replies a little harsh.
Generally you can as mentioned you can use
GitHub - TechPerplexed/Gooby: Gooby: The ultimate infinite Plex media server using a VPS and Cloud service which is very easy to set up.
Plexguide doesnt exist anymore as its called PGBlitz https://pgblitz.com/press/
Far less easy to set up but worth it.
Beyond that you could get a seedbox to physically get the files up to Google and then use a local mount to Google and add that mount to your local server. I believe Netdrive (for the mount) works OK or another option is rclone running locally…even more complicated for anyone who isnt savvy with the set up.
Or of course the seedbox may have capabilities to run Plex? But any discussions about seeboxes are not something for discussion here on the forums.
So PM me if you want more help.
