I know you can go to Play Version, but it doesn’t give any more details if the there are multiple movies with different versions available. I am talking normal (theatrical), Unrated, Extended, Remastered, Director’s Cut, etc. It would be great that either the Play Version would list the version of the movie when selecting, or even better, when you click the Play button, it gives you a choice of versions to select from. Blade Runner is a perfect example of this.
I suppose you’re late to the show… better like/promote the already existing requests in this context:
- https://forums.plex.tv/discussion/46113/very-popular-multiple-cuts-of-movie (I believe this is the godmother of that kind of requests)
- https://forums.plex.tv/discussion/306764/feature-request-edit-multiple-file-versions
edit: I removed the similar ones which had already been closed as they’re duplicates
